Do I need to worry about this kink?
dscheidt
My minisplit was attacked by a falling thing, which damaged the lineset cover, and resulted in this kink in the bigger line. It continues to work, so I don't think it's leaking. Do I need to get it evacuated and replace the line? or is just replacing the insulation (with what?) and ignoring it okay?
mm08822
Fix it proactively otherwise you will be paying for a full charge of freon along with the rest of the mentioned steps above.
And you know it will fail on the hottest day.
mngundog
MN, in the sticks, U.S.A.
This is the very reason electrical tape was invented.
karoc
Hemphill Tx
Restrictions like that will indicate your under charge, which means charging unit only be guess. Freon coming back to compressor is what cools compressor. Tubing cutters and coupling fix that, but still time consuming
