Need air conditioner recommendation
bluedog225
Texas
This is for a workshop with living area loft above. Hoping some of you can point me in the right direction.
I have been chasing this for a while. Want to throw it out there for ideas before I start calling commercial HVAC contractors.
I would like the unit mounted high on the wall with a wall sleeve, serviced and replaced from the inside. Place is remote, on acreage, off-grid, and theft is a problem. A ground-level unit would be a problem. And servicing this from the outside is not something I’m interested in at my age. Or the expense/hassle of hiring outside service 20’ up. Mini splits were the original plan. But I’m wanting to avoid servicing and replacing them more frequently than a better quality unit. No place for an air handling unit inside. Poor planning on my part.
I see this kind of unit on portable buildings and commercial buildings— narrow, wall-mounted, self-contained box. That is the form factor I want (I think). But it is outside the mainstream residential stuff online and I would like to be better educated before I start making calls.
Structure is a 24x24 foot workshop in Central Texas on acreage. Three levels, about 30 feet to the loft ceiling. Concrete first floor garage, open second floor work area, loft above. Flat roof with 14 inches of cellulose going in. Walls are double 2x6 Timberstrand on 12 inch centers, so I can knock out two stud bays and install header for a 33 inch rough opening. Walls have 3/4 inch polyiso and radiant barrier, medium-well insulated.
Volume is around 17,000 cubic feet. Central Texas means 100 to 115 degree summer days in full sun on a flat roof. Need a unit that reliably cools above 100. Compressor location will be shaded. Back-of-envelope cooling load is 30,000 to 36,000 British Thermal Units. Rough guess. Planning for more than one cooling source for the worst weeks and for redundancy.
Off-grid solar with Schneider inverters that handle a decent surge, but inverter-driven variable-speed compressor would still be ideal. Power is 240 volt single-phase American residential. Wood stove for winter, so primarily a cooling problem. Heat pump would be a bonus, not required.
Friedrich Kühl does the slide-out chassis I want at 36,000 British Thermal Units. This would be a decent solution that would handle 90% of my need, But the warranty is ****.
I have moved off mini-splits. Thinking I want commercial HVAC solution. I’m guessing a realistic budget probably $5,000-$10,000 for a quality unit?
I’d appreciate any thoughts on firming this up so I don’t waste people’s time.
I’m thinking it would go on the upper left of this photo. Next to the narrow window. Accessible from the loft. This wall is also available lower down for another unit as needed. Or the backup mini split.
MovingAlong
Most larger HVAC companies will have an experienced estimator on staff. Their job is to evaluate your requirements, analyze your needs and make recommendations.
You won't be wasting anyone's time. :thumbup:
bluedog225
Texas
Agreed. But I’d like to be better informed.
And not get sold what they are familiar with instead of a better solution.
I figure you guys know a lot about the options and I’d like to take advantage of that experience.
MacMcMacmac
canada
We have a bunch of pretty compact Mitusbishi, Mr. Slim units at work that run 24/7. I have never seen a failure in the 13 years I have been there. They have been in service since 2003 or earlier. They air condition rooms with HMI control stations and servers, so they don't get a rest even in winter.
HVAC guys can probably recommend something similar from any number of companies I'm sure.
manwithtools
Lebanon, TN
Just use a good quality mini split mounted up high. Have you seen how they use them in Asia? If you get 15 years from one, how many will you replace in your lifetime. The efficiency and quietness alone would force me to a mini vs a noisy PTAC.
bluedog225
Texas
Just use a good quality mini split mounted up high. Have you seen how they use then in Asia? If you get 15 years from one, how many will you replace in your lifetime. The efficiency and quietness alone would force me to mini vs a noisy PTAC.
What‘s the deal on annual maintenance on a mini split condenser? Just spraying the fins? Or is there more to it. Going forward, time on a ladder isn’t ideal. And I hate to bake in having to hire a service call every year.
And do you think the splits will last 15 years? I could get on board with that. But I thought they were much shorter lived.
And yes, in Asia they are installed all over the place, literally. The lines are like spaghetti.
manwithtools
Lebanon, TN
Yes, a quick search says 12 - 20 years for a properly installed quality unit. I know several that have units over 10 years old and no issues. No maintenance required to the outside units as far as I know. I guess you could hose off the fins if you desire.
jjrbus
Florida
Google cleaning mini split blower wheel, mine need to be done at least once a year. If they are not bad, I clean them in place, cruddy and I remove the bower wheel to clean.
bluedog225
Texas
Snapped-off
Indiana
I’ll probably end up with 2 or 3 mini splits. But.
The best alternative I could come up with something like this. There’s a dealer not too far away and I’ve got a call into them.
It seems pretty ideal in terms of longevity and repairability. And 36,000 BTU is a pretty good guess at my need.
Somebody talk me out of it. Though the price may be unrealistic.
I've got 3 of those Bard ptac's at work. Mostly trouble free, and run almost 24/7 for both heat and cooling.
Only real issues we've had are the economizer actuators failing, and some proprietary board issues.
danski0224
Near Naperville, IL
You are looking for something called a "Magic Pack". There are variations.
Good luck with that.
A mini split condenser on the roof and heads or ducted systems inside would be the most theft resistant solution, but roof access is needed.
Those Bard units are likely serviced from outside and probably can be stolen or vandalized easily. They (or similar) are common on portable jobsite trailers or conex boxes in my area.
bluedog225
Texas
The published specifications are pretty impressive. Unlike most of the consumer grade mini split stuff I’m looking at. I’m sure the price is going to be remarkable.
Keep working and keep writing checks.
