Mildew on wood
billconner
Thousand Islands NYS
I'm going to "refinish" these spindles. Should I do anything extra for the mildew or just pressure wash, lightly sand, and prime and paint? I was also thinking about setting bottom end in a pail with an inch of preservative before priming. It will be sitting on a 2x5.
PCustoms
VT
Is there a picture?
Hank11
Tennessee
I would spray them with some bleach bathroom cleaner all the way around let them sit five minutes and then take a scrub brush with soapy water. Rinse well.
PCustoms
VT
Yes. All pressure treated. 1994 - was that before CCA ban? I think that was after 2000. Some splintering but I have extra.
My experience here was the old PT developed green mildew (it was super damp here) and looked "0k". Anything I cleaned up seemed to rapidly accelerate the decay. While solid, wasn't cosmetically acceptable.
Mine was bare, maybe the paint will help.
yhprum
Brisbane Australia
Here is what google ai says
While both are fungi thriving in damp environments, mildew stays on the surface as a flat, powdery growth, whereas mold burrows into materials, appearing fuzzy and in various dark colors. Mold is significantly more aggressive, causing deeper property damage and more severe health risks
PCustoms
VT
What's the value in posting AI answers from a Google search?
rlitman
Long Island
Huh?
Chlorine bleach will absolutely kill mold.
It kills living mold, but does a poor job at killing mold spores. The chlorine evaporates before the water, allowing spores to absorb water and emerge after the chlorine is gone, leading to a new mold bloom shortly after chlorine treatment. Chlorine bleach is great for washing off mold, but only when followed up with a more permanent mold killing chemical.
In this situation, I'd recommend either a mold killing primer, or a mold killing additive to the paint (or both).
PCustoms
VT
North shady side of house. Probably should cut trees back so corner of porch is more exposed and beyond drip line.
Yep, same problem I had. Tons of oak trees overhanging everywhere and brush to within 10' on 2 sides. Cut everything back, and for the most part where I washed everything (bleach/soap) it's not coming back.
Hank11
Tennessee
Agree with the last sentence for long time success.
What the OP showed are loose spindles — easily sprayed and kept wet. But they can be dumped in a bucket and submerged in chlorine water, and it’ll kill the mold and everything else. There are obvious bad places not to use chlorine bleach for mold killing. One of them is under a house. You might gas yourself before you get done. They’ll find you a few weeks later when it starts smelling.
PWC Repair
Arkansas
Well, I thought it was mildew, but how do I know if it's mildew or mold?
Looks like neither to me. And you stated North shady side................also in that pic it appears very even covered and green colored. My vote is for standard green algae.
........oh ya,........and it will clean right off with some washing soda.
