Need help sourcing bandsaw blade
shamrock12
South Dakota
My buddy has a vintage horizontal/vertical bandsaw that needs a new blade for metal cutting. Problem is, it is near impossible to find 5/8” x 118” bimetal blades as nearly everything in that length is for butcher meat/bone cutting.
Most likely the blade would need to be custom made. Preferably 18 or 14/18 TPI mainly for cutting exhaust pipes etc.
If you could please point me out to a reputable website that has or will custom build this blade of good quality it would be greatly appreciated.
Thank you
OccupantRJ
Eastern North Carolina
I got lucky in that respect. Where I lived previously there was a saw blade service shop 20 miles from me. After I moved to another town the shop is still now 20 miles from me. Have you checked for a local saw shop in your area? They can tend to be a bit few and far between.
rsanter
visalia ca
Look for a local saw resharpening place, they will often also make band saw blades.
also look online for how to make your own. I have seen tutorials where people TIG or silver solder their own blades at home. I have even seen one guy that might welds them (but this is not nearly as good.
i have two blade welders so I make my own. I would offer to make some for you but unfortunately my skill with the blade welder has not developed and the blades I make often only last 30 to 60 min and break at the weld. Only good point is that I zap hem again and keep going
rsanter
visalia ca
not to derail this thread, but are you annealing the welds ? if I recall in High School Metal Shop there was an anneal after welding to take the brittleness out of the weld joint
I am using the feature on the welder. It’s my understanding that there is a learned “touch” to it. I will say that the first blades I made only lasted 5 to 10 min, so I have gotten better.
on the other hand, if any members are in the area and want to, 1) use my blade welder, or 2) show me how to better used my blade welder……. Come on over
OccupantRJ
The relatively local saw shop to me will cut your own blade stock to length and weld it for $5 per blade. He provided me with 1/4” 6 tooth per inch carbon steel alternate set blades of 140” length for $20 last time I went. I have two Delta 20” vertical band saws with one for wood and one for metal. I use 1/4” 18 tpi wavy set on the metal saw because most of what is cut is thinner sheet material or tubings.
OccupantRJ
Try pulsing bursts with less timing each button push if you have not.
jblnut
In the Middle of MN
I have my oddball blades made by Oxygen Service Co of all places. Maybe seek one of them out. They’ve made me all kinds of oddball things.
Jgaz
In my experience you are so right about a blade welder needing the correct “touch”. It always seemed to me that I had the best results from a particular welder that was attached to a particular saw.
In fact when I was transferred to a different dept I usually came back to use the welder on a saw that I had the best luck with
JuncleJohn
Omaha, Nebraska
Never done it myself, but decades ago (5 to be exact) I knew an old guy that would silver solder blades together. He had a little homemade jig to clamp them together after grinding the non toothed area on a bench grinder so the two ends would over lap each other about 3/8”. He would then grind off the excess solder and it would be good to go.
I never saw one of his blades ever break.
John
JuncleJohn
Omaha, Nebraska
As far as buying the correct length of blade, I’m sure MSC, DoAll (DGI Supply) or any metal working supply house can order what you need.
John
dr_clyde
Holland, MI
John
This is the way.
Most blade welders are tricky to use on bi-metal blades, due to the difference in materials within the blade.
Silver soldering doesn't melt the blade steel, so it doesn't require as fussy of heat treatment/annealing.
I made a little jig to align the blade spine, grind an overlap, flux it, and braze it. Sand smooth and you're rocking in the free world.
To the OP:
Any industrial supply or most welding supply houses will be able to make blades to order. Just bring them the sizes you need and the specs and sometimes they'll be able to do it in house. Most often they'll just order them in for you with a couple days lead time.
I like Bahco, Amada and Lenox for blades, personally.
