budget 3/8" torque wrench
stickshift
northeastern US
I have a Harbor Freight Pittsburgh 3/8" torque wrench and I'd like to get a better, but still inexpensive wrench. I don't use torque wrenches often enough to justify spending $100 on one. The HF model I have once failed me (no detectable click), resulting in a snapped fastener, so I'm very nervous when using it and am always checking/retightening the lock knob (which gets loose very easily) and confirming the click by tightening already tight fasteners elsewhere on the vehicle.
Please suggest a budget 3/8 torque wrench (covering roughly 15-80 ft-lb range) suitable for automotive work (no beam style), thanks.
Sub $100 thats a pretty tall order you didn't specify what torque range in/lbs ft/lbs. Look at Tekton, they have lifetime warranty and will calibrate their torque wrenches.
Hakeem
Chicago
I have no personal experience but I’ve heard good things about eTork. They’re made in China but the background of the founder is quite impressive:
FigN⋅m
No beam, or no split beam?
Icon's 3/8" 20-100 ft. lb. split beam is $99.99 and there's always a coupon or sale around the corner.
stickshift
northeastern US
No beam. I didn't even know about split beam torque wrenches until your post. That Icon looks nice, and I love the flex head - definitely been times where I had to skip the torque wrench because no access with a fixed head.
jayemm
up high down low
I have 2 of their eTork TW's. A 0-200 in-lb with the rotating scale in the window on the grip and a 10-100 ft-lb micrometer setting type. My S-K 10-100 ft-lb was made by the founders previous company (JS Technologies) which produced under many labels like K-D, Craftsman, etc. All have been decent.
The youtube channel "Tools Tested" has tested many torque wrenches in various videos with a Snap-On/CDI torque tester. None of these teenagers torqueing their lug nuts in the garage ********.
He's tested 1/4, 3/8 and 1/2" drive TW's. Here's one.
AEAdam
SE PA
Might sound like overkill, but there are inexpensive digital wrenches out there. I just did a search on eBay and found some interesting options around $100.
I think the advantage of digital for you is no need to worry about setting it back to zero or whatever, no issue with it sitting for prolonged periods (I remove the AA batteries after each use). Really easy unit conversions and pretty awesome consistency.
The ACCURACY of torque wrenches, in my opinion, is inconsequential. Most often for automotive, what you really want is consistency.
Maybe there is a GJ thread on the discount digitals, but my sense is, it's pretty simple technology. And cheap may be nearly as good or just as good.
Digital torque wrenches that can do angles are pretty helpful. More and more manufacturers are specifying angle requirements and they aren't always easy to achieve with a wrench that does it.
I agree with you that flex heads are pretty nice to have, but I got away without one for decades.
Other thing to consider is a used truck brand wrench like Snap on, clicker. Even an old worn one will probably still be accurate and consistent enough. To be honest, the cleanliness of the hardware plays such a huge role in torque that the accuracy of the tool is almost insignificant. I would not pay a premium for the most accurate torque wrench.
I have 2 Snap On Techangles (with early gray handles) that I bought for $90 and $150. The $90 one needed to be rebuilt so I sent it to Snap on and they rebuilt it for $80 (a while back). At $170 for a Techangle, I thought that was a good deal. You might be able to find something like that on Facebook Marketplace. Worth a look before you pull the trigger.
AEAdam
SE PA
I have a couple problems with that YouTube video:
1) What kind of tool guy wears a Sony Playstation tee shirt? Are you a video gamer posing as a mechanic? Sure looks like it.
2) He pushed through the click. That results in overtorquing according to testing Snap on did that led to their patented "Early Warning System" on their digital wrenches. A LOT of people do that and then double click it, which is dumb and dumber. To use a torque wrench accurately, you must stop pushing just when the wrench releases. You should never push to the end of the release. In my mind, this puts all his data in question.
#1 is me just joking, but it does seem to fit with #2. Maybe stick to Call of Duty unboxing videos. Don't make videos about tools if you don't know how to use them. I'm sure he's a nice guy and means well. But in my opinion there are too many of these yahoos making "content" as a side hustle and too many of us taking them seriously.
In general, I would say torque wrenches are close to junk science. They are a TERRIBLE way to indicate fastener stretch. Angles are much better but impractical (or impossible) for low torques. You kinda need an initial torque to get an angle wrench to read. The root problem with torque is that bolt stretch (the reason why we torque) is highly effected by technique and friction (which is technique adjacent). In this light, I think a skilled mechanic can probably do better with a junk torque wrench than this video gamer can with a $600 TechAngle.
