Monoblock heat pumps
jlv03
SE IA
Stumbled across an interesting use of the term "monoblock" a few days ago in regards to heat pump. Up until now, I have associated the term to mean an air-to-water heat pump, where only the water is brought inside.
Looks like Mr. Cool is using the term for an all-in-one heat pump setup:
The price seems reasonable, and it eliminates an outside disconnect and the space for the outside unit.
Other than the limited amount of BTUs and the large amount of needed inside wall space, I'm struggling to find any downsides. Seems like a good fit for my garage situation.
There is a startup that offers something similar, but the price seemed a bit prohibitive to me: https://merinoenergy.com/
manwithtools
Lebanon, TN
The startup's price appears to include installation. It's overall in interesting concept.
It's not really a PTAC, although very similar in packaging, it appears to have a much simpler installation procedure, no need to have a huge rectangular wall opening like a PTAC (which is why you usually see them under a window). This system only requires two small round penetrations through the wal.
pcmeiners
Performance is dismal, sticks out 8", you still need to run electric and a drain, DB level is high, capacity is very low, 1 year warranty. So you trade performance and a good bit of money in electric cost because it is easier to install. Since it is an "hour install" how much are the professional going to charge ?
fitter30
Peace Valley,mo
Can buy these for $1500. Conserser air is built in and two holes In the back get rid of the heat outside along with the condensate that evaporated by the condenser like most window ac.
mrcooldiydirect.com/products/mrcool-monoblock-10000-btu-through-wall-heat-pump-mdm10115d
dscheidt
It's absolutely a PTAC, it's just packaged differently and less efficiently. It needs three holes -- 1" for condensate, and two 8" holes for air. That's smaller than a standard ptac cutout, but a split that size needs a single 3" hole. I get the attraction of easy installation (except drilling 8" holes isn't easy), and there are probably places where it makes sense, but if a split is possible it's the better choice. a window unit might be a better choice for a lot of uses.
WildBill
PNW
Here is what they have to say about it. I can see how in some very specific scenarios this could be useful, but agree 98% of the time something else would make more sense.
Is the MRCOOL Monoblock a PTAC system?
The MRCOOL Monoblock is similar to a traditional PTAC system in that it is a self-contained through-wall heating and cooling solution, but it offers several modern upgrades including DC inverter technology, quieter operation, improved energy efficiency, smart WiFi controls, and a cleaner residential appearance.
