Building myself a 12x16 storage building
Notgrownup
Snow Hill NC
Decided to order a 12 x16 barn style DIY storage building from the discount lumber place. $2500 delivered. Started last weekend and doing a bit more this weekend. I’m pacing myself as my arthritis is limiting me a bit but it’s coming right along. I’m at the point where i need to instal the T111 sheets today and I forget what I did when I built my shop by myself to hold the sheets. I will think of something but if y’all have any suggestions I welcome them.
N
Notgrownup
Snow Hill NC
You could screw a 2x4 "ledge" on the bottom so that you can rest the sheets on it and then screw / nail them on. Move it as needed. Maybe snap a chalk line all the way around to get it at the right height.
Thanks , I just saw a video on google that did just this, I think I will do it. I will report back
captain14
I have watched several YouTube videos and this is how they did it.
Please keep us updated on your build. I enjoyed your garage build you did several years ago.
cgrutt
Looks nice. You may want to buy a couple of 16's and redo the top 2x4 on ends so they overlap the corner joints it will lock the walls together. I'd also consider painting the inside of T1-11 before you assemble it it. Nice work so far good luck with it.
N
Notgrownup
Snow Hill NC
I am going to strap them together with metal strapping. I thought about the overlapping and I am just going to go with the strapping
Crowbarman55
I have a question, what do/did you put under the skids to keep it from sinking into the ground over time?
N
Notgrownup
Snow Hill NC
Slight progress , critter mesh added. Used my small low profile jack as a 3rd hand to hold the sheets up. The sheets are still wet from the stack . I guess from the treating process? Holy **** does it make them heavy. lol or I’m just weaker .
OccupantRJ
Eastern North Carolina
Like a mouse eating an elephant, one bite at a time will get it done.
As an unofficial building inspector of Wayne and previous resident of Greene I may have to go by one day to check things out.😇 With the critter screen, now you have gone and hurt the feelings of the local stray cats and possums!🙀
N
Notgrownup
Snow Hill NC
The struggle is real
andyvh1959
Green Bay WI
I built my 12x16 yard shed over a gravel "pad" on which I set concrete footers, so the deck joists are at least 2" above the gravel. After I had it up and sided (T11) I placed solid 8x16x4block on edge around the deck, glued to deck frame and to each other, backfilled with gravel to keep most of the critters out from under the shed.
MikeC55
CT
That's a pretty good deal on the shed kit. I'm sure I spent more buying supplies separately on a very similar build. Wrestling those sheets is no fun by yourself.
Codyboy
S.E. TEXAS
No I have to cut them to length and right angles of cut provided,
Looking great so far!
Are you having to build the gambrel trusses like the pic in the OP?
Over 25 or so years ago I built a 10x20 shed with a gambrel roof like that , all from a napkin drawing.
When I built the trusses , I was able to lay out the pieces on the shed decking to make sure it all came out squared and the correct dimensions / angles. I actually marked it out and screwed stop blocks to lay the pieces in to keep the angles correct and fasten the plywood gussets with nails and glue.
I set them aside (I think there were 11 I had to build) until I finished the wall framing.
I hope you have a good flat space to build them on now that the walls are up.
Also just being nosey, but what the heck is that pulley system for?
cgrutt
Thats a good way to build the roof framing for sure but too late for that now with the walls up.
OccupantRJ
That’s for when you need construction help from unwilling family members!
N
Notgrownup
Snow Hill NC
It came with drawings for the length and angles of the pieces and you tie them together with scrap plywood pieces nailed on both sides
CraigStu
Blacksburg, Va
If you build trusses, build the first one and build the second one right on top of the first. Long time ago my brother and I tried to keep building on top. But we realized that at the 4th or 5th, the natural building errors were compounding so we pulled off the ones we had built and did the rest on top of the first. It was a pain in the **** having to move every truss, but we got them all the same size that way.
N
Notgrownup
Snow Hill NC
It requires more effort to stand the walls, but I'd always sheathe with the walls on the ground. Easier to handle and square everything.
Glad you're making good progress!
I wanted to but lifting the section was way too heavy by myself. I probably could’ve but didn’t want to hurt my back more than it already was.
N
Notgrownup
Snow Hill NC
I was thinking about making a jig from the first one on a sacrifice piece of osb or plywood.
