Is anyone running a similar tray like pictured to get some more real estate from their service cart? I dont have access to a sheet metal bender and wanted to see if a tray like this can be purchased.
I have one in my KRL. It’s pretty shallow so all that’s in it are pencils/markers, **** like that.Is anyone running a similar tray like pictured to get some more real estate from their service cart? I dont have access to a sheet metal bender and wanted to see if a tray like this can be purchased.
ive been looking into meat or display trays but havent found the right size. Has to be around 28" wide.Snap-on Store
shop.snapon.com
These are the ones Snap On makes for their boxes / carts. I've been trying to find one similar to see if it would fit my USG cart, but haven't found anything solid.
If it's for lighter stuff, you could probably knock up something from aluminium without a bender?Is anyone running a similar tray like pictured to get some more real estate from their service cart? I dont have access to a sheet metal bender and wanted to see if a tray like this can be purchased.
I've been making some changes lately... moving stuff around and actually buying new tools again.
For anyone curious, all of my diagnostic/electronics related tools are kept in the house. I don't like leaving them in the 120*F+ heat of the garage if I don't have to.
Take the batteries out, also.
Very important.
If they use AA, AAA or 9V, use EverReady Lithium disposable batteries - no leaks, better discharge curve, and 10 - 20 year shelf life.
I still would not keep them in electronics in a high heat environment.
I keep them in things that are stored permanently inside our car and rigs, and those temps get real high. I have one emergency flashlight still on the same battery for over 20 years.
Keeping the electronics out of the heat; understandable. the batteries don't matter if Lith.
A flashlight is generally not difficult or expensive to replace.
A high end scan tool or DMM on the other hand…Not worth taking the risk.
Your're not listening - there is no risk of leakage from the disposable Lith cells ...
Lithium batteries are not going to cause issues to your diag tools and torque wrenches. They're just not.Take the batteries out, also.
Very important.
I am.
I stand by what I recommended.
Furthermore, lithium batteries can leak or rupture, which can damage electronics and circuit boards.
It’s not worth the risk.
If you googled "Can Lithium batteries rupture/leak/catch fire" what would the answers be? If you put "rechargeable" or "disposable" in front of "Lithium" would it change the answers?there is no risk
This just isn't one of those things where one simply can't say there's no risk. Only low risk or high risk. And I think batteries are effected by physical damage, environmental issues etc etc.
Quite a few cowboys around here where spending the two extra minutes to install and remove batteries would be too much effort for them. And they —falsely believe— that there is nothing to worry about and are willing to risk their high end electronics.
This same thinking reminds me of the case of the basketball player and wanting to avoid California traffic by taking the helicopter. The pilot flies in bad weather to save time and the helicopter crashes. No survivors. Same symptoms and bad judgement.
If it is different answers then you are relying on a delusional AI generated response. Do proper research.
That "Cowboy" comment cuts both ways ... But again you do you...
And this is one of the most ridiculous comparisons I can even imagine.
Ability to correctly apply risk mitigation / management and critical thinking in your ‘decision tree’ flow model process should be re-assessed.
The comparison is actually a good one. The same people who make rash and flawed decisions with the simple things are apt to make the same kinds of decisions when human life is on the line.
I don't consider googling stuff "research" but I did google it and got the answer you would expect. Whatever I put in, the answer was YES, there's a risk of combustion of leakage or whatever you typed specifically for whatever lithium battery type. They are batteries. You may have said it earlier: Alkaline batteries have risks. I have some old AA MagLites with swollen batteries to prove it.If it is different answers then you are relying on a delusional AI generated response. Do proper research.
There is most certainly risk. It is lower risk than alkaline, but I can assure you lithium batteries can and do leak.there is no risk
Love the old school!
One question though, do you use lithium batteries in it?![]()
My main box is an ancient Snap-On base cabinet with Craftsman mid and top. I have an old Waterloo base cabinet set up by my drill press for drill bits, reamers, countersinks, taps, dies, etc. I also keep a Kennedy base cabinet up at the house garage for typical home repair tools.
