M.Brane
1 hr N/W of LA LA Land
Haven't done JS in the garage lately other than retrieve beer, and the occasional tool for minor vehicle/house maintenance. Supposedly my boss will be back on the 1st (he's been gone since Nov) so looking forward to not having to do 2 jobs anymore, and some time off work so I can work on my own stuff for a change.
Beerhippie
Far NE Oregon
Stripped n refinished my nails.
Did you gas-wax 'em?
I was outside in the full sun most of the day--repainting parking lot lines, f'in with the drip irrigation, fixin' picnic tables. Finally had to knock off at three due to 90F and full sun. Got back at it at five, when there was some shade and it had dropped to a nice, comfy 85F and finished fixin' tables.
Parking lot lines had started to wander due to repainting by following what was left too many times, so I got some spikes, line and tape measure out and reset them. Looks much better now, but lots of tedious work under the full June sun. Laid out and added a couple of parking spots where we don't need clearance for semi trucks any more due to adding an access road to the loading dock.
Bob Peach
Cape Cod ,Ma
Took the belly pan off my 2015 Mazda 3 to replace the gas tank and fuel pump, What an awful design ! So much **** stuck in there. The car has no body rust rare for a NE vehicle, everything under the panels I removed is covered with rust. Oil pan started dripping when I poked at the big rust flakes. That's easy. I have to drop the exhaust to change the tank. It is going to a pain, every bolt is going to have to be cut or drilled out.
At least having the new lift makes it easy to work under it, The car is a grand touring 6 speed and only has 135000 miles, I really enjoy driving it, The list of parts is getting longer. Guess it`s better than a car payment.
v6buick
Franklin, IN
Good thing you checked the filter!
I bought a cutter just for the occasion. The engine was making pretty concerning noise after the last 1/4 mile pass. Once I confirmed that the flex plate was still solid and the valve train was tight, I had a bad feeling about what the oil would tell me. The WIX filter was doing a pretty good job, but couldn't quite get it all.
Levaughn
NY
I changed the radiator fan on my 2011 Impala. On Sunday while driving on the highway an hour and a half each way, I hit a deep pothole. I thought nothing of it because the car drove fine. Later in the day after the trip, I noticed the temperature gauge which normally stays in the middle was slightly raised. Although I’ve never seen it move past half I thought maybe it’s just the heat. On Monday I drove about five miles then drove back home. I noticed again the gauge was slightly above half. This time the fan was on high, but the AC wasn’t on. I parked it and left it for the night. On Tuesday afternoon I‘m headed out, but I decided to take a look under the hood to see if I could notice anything. Low and behold the fan housing was broken. The passenger side fan fell off from the housing and was sitting at the bottom unattached to the plug. The housing was so brittle every part I touched snapped like sugar wafers. I didn’t even have to unbolt it to take it out. I think because of the pot hole and the brittleness of the housing it just crumbled.
BlakeTheCarGuy
Roanoke Virginia
The last day and a half has sucked for me lol. I hate interior work but it is nice to do something different for a change. 2018 Highlander with 68,000 miles needed a steering column it had a click somewhere internally and was jerking too. It made me remember why I hate modern cars lol. I diagnosed it last Wednesday and the customer left it for repairs. Doing this job *****. Hopefully won’t have to do one of these for a long time haha. I have never seen bolts where the heads are supposed to come off when you tighten them. They were a pain to get out of the old one. A coworker showed me instead of doing how the manual says where you drill a hole in it and use a screw extractor he said hand me a chisel and a hammer I’ll show you how to get them out. He had them out in 5 seconds. He said you’d be here all day trying to drill those out and use a stupid screw extractor that doesn’t work. I appreciate that helpful tip so I know next time. Good thing we had exactly two of them in stock because I didn’t know these even existed so I didn’t tell parts to order them with the column. Usually we don’t have anything in stock so I was truly surprised lol. I have done steering columns before but never on a modern car so it’s way different and way more annoying haha.IMG_5487.jpegIMG_5492.jpegIMG_5493.jpegIMG_5494.jpegIMG_5495.jpegIMG_5496.jpeg
Jgaz
Where in the column are those bolts used?
ObnoxiousFumes
Southwest Sask
Yep my ‘03 Jetta had the same kind of bolts, hammer and chisel works a treat. I replaced them with button head cap screws, in case I ever need to take it apart again.
BlakeTheCarGuy
Roanoke Virginia
I wanted to put some regular bolts in but they wanted me to use the same type that came out of it which I can understand but I think regular bolts would of been fine because who is going to go thru the effort to steal that piece anyways lol.
RivennHewn
PNW
Processed some Oak dunnage that i scavenged out of the dumpster.
Not sure what type, probably White.
Going to give it a Bog Oak look. Started with a rust oxide solution, then it’ll get a fumed and black wax treatment.
I was hoping to retain more of the existing patina, but a lot of it went away from planing and flattening. 😕
Mike65
Horse Pasture, Va.
IIRC they are anti-theft/security bolts. In my 25 years in the automotive business, I have never seen them used, but my time in the business ended in 2000.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Break-away bolts are fairly common with compression flanges on PVC and ductile iron pipe 4" and larger. Also some structural bolts.
The difference here is the ones I've used have 2 hex heads, one to break and the other stays with the bolt.
Never seen them on cars though.
slomaro3.4
SW Pennsylvania
Well good news bad news, I wrapped up my Green Egg repairs cured for the cement for 2 hours, ran the low heat cycle at 100 degrees and then put it all together and brought it up to 500 degrees (this was all the process from the manufacturer). The cement bubbled and cracked on the inside of the base. It seems structurally sound, but no way this is going on my wooden deck pavers underneath or otherwise.
The good news, this is obviously not under warranty, but my local dealer offered me 25% off a brand new base that’ll have a lifetime warranty. So I’m going to be about $500 into a medium green egg.
GrayFlattop
Chicago
The passenger sideview mirror on the Sienna became so discolored and stained, it was useless. I purchased a replacement mirror glass from Bezos for $15 or so thinking the problem was the mirror itself. So I removed the mirror from the housing and put it on the bench. Since it was already FUBAR, I had little to lose.
I used a heat gun to pry things apart and the discoloration improved and moved a bit. This is a fancy auto-dimming, heated mirror with integral turn signal. As it turns out, there is a coverglass over the mirror with some electrochromic gel sandwiched between the two. Sometime last Winte, the seal became compromised and the gel turned dark brown.
I cleaned both surfaces with solvent and was able to restore almost all of the original reflectivity. That goop gave up quite a fight, but ultimately, most goop surrenders to lacquer thinner. Snapped things back together, plugged in the connectors and everything works except the auto-dimming. I'm ok with that. I spent a minimal amount of time trying to find the correct assembly online, but the van is 18 years old, so I'm not too worried. It's used primarily for trips to Menard's, Orange Hell (Thank you Kay for that apt name), landscape suppliers and lumber yards. None of my other work trucks had something so fancy, so I'll live. Now the heated seats; however, those are IMPORTANT.
Sorry. No "after" pictures.
rd65
Granite Falls, WA
Took a look at the driveshaft from the F350. Two piece that will be getting new center support and ujoints since it is out of the truck. Stock units currently but the engine should see good gains in hp & tq. Stock is 165hp, 275 tq; I was told it should now be close to 400/400. Off to Rockauto for some shopping.
ObnoxiousFumes
Southwest Sask
Wrench97
Southeastern Pa
Those are usually to prevent over torque on the flange, the ones he has are used as a antitheft "feature" so thieves cant unbolt the steering column lock.......
Beerhippie
Far NE Oregon
SOS--Same Old ****. Started the morning with plumbing--fixing some stupid stuff other have done. Rerouted the drains of our water-cooled icemaker to a hard drain line, instead of dumping into a floor drain which clogs constantly. Much better. Tried to clean the floor drain, which someone installed a WALL over. Had to give up on that when I found out that the grease trap for the kitchen dishwasher was clogged and overflowing onto the floor of the dish wash area. Got that empty and unclogged.
Then I finally got to play outside for a bit. We put up sun shades for some of our outdoor seating for the summer. The guy who used to do that moved on to another job, so a couple of the kids tried to set up the shades when I was still on the invalid list. One sagged over the picnic table to the point that it slapped the top of your head in a light breeze. It didn't do that before. I took a long, hard look at it today and noticed a large line strung high across the seating area. Hmm... I wonder what that's for? Thought about it, looked at the sagging, flapping sun shade...
much mo' betta'!
Put some pictures in a file where I can find them next year.
[rant] I HATE landlubber knots! I had to cut every knot in the guys to be able to rehang that shade. Why the F can't folks learn how to tie proper knots? It sure ain't rocket surgery! [/rant]
Beamer
Northeast
Miss K,
Actually? There is an omission in the diagram.
Position #4....
"Burn the vehicle to the ground"....selection....
Old man what used to service Brit bikes down to Pgh...had one of these on the shelf.
Would oft say, "Gonna cost ya big money to get this smoke ....back in yer scooter."....
I bought a new wire harness presumably with fresh smoke. I have yet to test the assumption but I won't make the same mistake twice even as interesting the event was.
freudianfloyd
Nowhere
Keeping with my detailing / pressure washer obsession at the moment, I decided to make myself a detail cart with an old Harbor Freight roll around cart I've had for years. It has gone from my main toolbox to a welding cart, to a place to stack ****. Well now it's a detail cart.
I git rid of the old sprays, waxes, etc. that I've had for decades and upgraded thanks to Prime days.
Also added an organizer for my wands, nozzles, gun, undercar sprayer, and soap cannon.
Ignore the horrible drywall. I will get to it eventually when I finally get my shop built.
BlakeTheCarGuy
Roanoke Virginia
Diagnosed and replaced the intake manifold on a used car at work. 2017 Hyundai Elantra Sport. Apparently a common problem on these because we had two manifolds in stock which is unusual if it’s not a common problem. Forgot to take an after picture but I will tomorrow. I haven’t been doing much “basic” work lately because they have moved so many techs up that there’s not enough basic work like tires and brakes for everyone haha. But that’s ok I like doing stuff like this. Engine and suspension work are my two favorite things to do so this was right up my alley. Not that hard to do just a little aggravating.
Metallitubby
ATL OTP North
Did some last minute tweaks, inspection, and cleaning before heading to this weekend's race in Virginia.
  • Made a passenger side HVAC vent block-off out of carbon fiber
  • Cleaned the mud from the last race off (out of?) everything under the car
  • Adjusted both interior nets
  • Bled brakes
  • Nutted and bolted every major suspension component
  • Cleaned under-hood
  • Replaced some damged bumper clips
  • Polished the exhaust system using trusty ol' Wenol
Packed up and loaded the car on the trailer. Hoping for less rain this go'round but it's not looking good.
DGersic
DeKalb, IL
“No user servicable parts inside.”
Kinda true, I don’t do surface mount stuff.
This is one of the batteries I inherited from Dad. It wouldn’t charge. So, let’s have a look inside.
Found four cells at ~4V and one at 0V. Rigged up a single cell charge, and got it up to 3.8V
Reassembled. It shows three bars now, but still won’t charge. Goes immediately to green, as if it was already full.
Could be that the four fully charged cells are confusing the circuitry. I‘ll drill some holes tomorrow, then see if it’ll charge normally.
Sanding and assembly on these.
Tomorrow they can start getting some primer and paint.
bugnut
Central Ohio
Put together an nsf wire shelf rack that has been used in the house now in the shop. Added wheels-cheap on amazon now-and filled with **** from odd projects covering workbench, got some flat space back. Then had a barley pop with the neighbor and caught up on chit chat.
OccupantRJ
Eastern North Carolina
I once was getting free nsf shelving from a fast food chain of stores. My brother in law‘s wife was a principal player in the company and had 8 locations save them for me to be called to pick up. The shelves have to be replaced if the finish is compromised in restaurants. They would place undesired shelf sections in the dumpster corral out back and make the call and I would go get them. There were usually 2-5 sets of shelves 2 feet wide and 3-6 feet long per call. Anyone wanting this type of shelf should check with their local fast food managers for discarded units, but ask them to leave them assembled. The employees would initially ruin them beating on them to disassemble them, so I asked for them in as removed condition. It also saved labor for the store. It was a great way to get free shelves.
