Fixed The Battery Boiler
Worsedog
Central FL
I have a Husqvarna 38" ride on mower I bought off the classifieds on the local dial-up internet provider about 20 years ago. It looked nearly new and the seller brought it to the house after I told him I was going to ride it home. It was probably a mile or so. I really don't much care for the yard work aspect of home ownership, but am far to cheap to pay someone else to do it. But by the same cheap token, I wasn't interested in spending what at the time was a ridiculous amount of money for a new one. Back then the department and box store clones that likely all came out of the same factory in different colors were right around $1K. It is an LTH120.
It's been relatively trouble free over the years. But the one thing that would never last was batteries. When they were $20, $10 a year wasn't too bad, but a U1 battery runs $30-120 depending on the chemistry and the name on it. Refer back to the cheap part above. So for the last four years, I just jump started it with the battery charger and had to deal with not shutting it off. After procrastinating far too long, I decided to address the problem. Something I should have done after the first two batteries was at least figure out why they didn't last. I just assumed that they weren't charging and when it started cranking slowly, just charged the battery. Turns out that was just making it worse. Turns out it was charging over 18v.
Looking at a wiring diagram the charging system was just one of three coils under the flywheel, one to run the ignition, one for the lights, such that they are. and the one to charge the battery. It also had a diode to rectify the coil output to DC. No regulation whatsoever, other than engine speed. At idle it still charged nearly 15v, but wound up to speed to turn the blades, well 18+ volts.
My neighbor gave me the old auxiliary battery from his Chrysler minivan. Not sure why he felt the need to change it, as it tested just over spec. Anyway, in the interest of getting maximum value from my free battery, I thought there must be some simple way to regulate the charging voltage. A bit of research showed that the higher line mowers had an actual voltage regulator. So I bought this Chinese special from Amazon.
Two wires, and the case must be grounded. After I received this one, I found there is one available that would have just plugged into the existing harness, but it was twice as much. Refer back to "cheap".
Because everyone like photos:
The mounting bolt is one of the ones that holds the starter solenoid in place, just had to use a longer one. Rather than counting on the mounting to provide the ground, I ran a wire to a chassis bolt that tested as good ground. Now it charges about 14.1v with the engine wound up.
PCustoms
VT
seems strange that it never had a voltage regulator. I suspect it was removed somewhere along the line for some reason . .
You made me curious.
Searched the parts tree for the mower OP listed, pulled up the engine and Viola:
W
Worsedog
Central FL
I thought the same after seeing it charging at such a high voltage. However, the wiring diagram clearly indicates otherwise.
PCustoms
VT
That's for the tractor, I believe the regulator is an engine component and not shown at that level.
Same reason I could not find it on the tractor parts list, but it was right there when I looked at the engine
firebirdparts
Kingsport, TN
Well, that's a new one on me. Very interesting.
The regulated ones do charge kinda high still. They're not quite like a car. But they don't boil the battery either.
W
Worsedog
Central FL
That schematic shows the entire wiring harness and exactly matches the tractor. The engine electrical from the battery and starter to alternator, to ignition components and all of the safety interlocks and headlights are all there. The later/higher line models is where I tripped over the regulated charging.
theoldwizard1
SE MI
Actually common on older small engines. Lead acid batteries can withstand charging at 15V. Yes, it shortens their life.
About 13.6V would be better, but at that voltage it would take a long time to replace the energy consumed from starting. If you are cheap, diodes are "sort of" a voltage regulator. If you are getting 15.0V out of the magneto to diodes in series would drop that down to about 13.6V. Cheap.
