r_olson_06
SD
New find. 3/4 drive set with box, and most of the sockets are Los Angeles. The ratchet doesn't belong on this set, so I will need to find a correct one and the rest of the sockets to complete the set.
Nice pick up. The cases are hard to come by in that size.
Smokeshow69
Picked up 2 items today at the Branch 15 swap meet in brooks OR....also ran into ORC while I was there. Paid $2 for both of these items. Pretty stoked because I don't have the upholstery hammer in proto either so now I have one. The extension has a nice detent ball function so I could leave it behind even though I have plenty of these.
r_olson_06
SD
Nice hammer. I just picked up one as well. Also great running into another Plomb collector at the swap. We don't have too many in the Midwest.
Does anyone know what AM stands for?
American Standard Regular. I have posted a few Plomb wrenches marked that way, a slugging wrench, as I recall, and a few of those Extra Heavy Duty DBEs they made. Very uncommon for Plomb to use it or U.S.S. or any other standard (as opposed to Williams, Armstrong, Billings, etc, for whom standards and milled openings were a standard marking convention) but especially uncommon for them to use it so late, in an era when those aforementioned mfgrs who regularly used it in earlier eras had already dropped it in favor of only the milled opening size. I seem to remember a discussion between me and @MR.X on this thread where we remarked on it seemingly being confined to industrial type tools and settings. Search on "USS" because "AM" would probably turn up every instance of the first person singular present tense of the verb "to be".
Looking at this, it might be American Standard Heavy.
No. American Standard HEAVY is equivalent to U.S.S., American Standard LIGHT is equivalent to S.A.E., and American Standard (sometimes qualified as REGULAR) is its own standard. In terms of hardware, Am. Std Heavy (or U.S.S.) was the largest, followed by Am. Std. REG, followed by Am. Std LIGHT (S.A.E.)
Here is an excerpt from a Williams cat for the handiest reference...
The best way to get a handle on this is to think of it from the hardware perspective. Pick a bolt or nut. Let's say 3/8", for example.
/ An Am. Std. LIGHT (S.A.E.) 3/8" bolt/nut needs a wrench with a 9/16" opening (because the AF size of the nut and the head on the bolt was 9/16") to turn it
/ An Am. Std. REG 3/8" bolt needs a wrench with a 5/8" opening (because the AF size of the bolt/nut was 5/8") to turn it
/ An Am. Std. HEAVY (U.S.S.) 3/8" bolt needs a wrench with an 11/16" opening (because the AF size of the bolt/nut was 11/16") to turn it
This seems to be the only catslog a Search found it in
If you mean Plomb, no, it appears in all the catalogs throughout the late 30's into the 40's.
Catfishdan
Central coast, California
Well it’s not multiple shipping crates full, but I did have a good plomb day at the flea market. Several unusual tools.
-5469 hinged speeder
- an odd 3/4” breaker bar marked with the round o Los Angeles and dxth along with a patent number
- two old stamped a. Plomb doe’s. Both 7/16”x3/8”, bit one Appears to be whitworth?
- 3 6528 jet wrenches All marked different. One is round o los Angeles, one is round o only, and one is more modern triangle
- a rope braid 5425, a 6523, and a 5534 socket
- a few more common pieces and a wilpen 8180
i Paid up for the breaker bar, but the rest of the stuff was all from one vender and came cheap.
r_olson_06
SD
Nice scores on the Round Os! The breaker bar is 1930 or prior. If it makes you feel better I paid $80 for my DXTH. The A Plomb could be either ALAM or SAE style which was common back then. The style of the wrenches suggest 1920s.
@Catfishdan
Long story short, dude named Samuel Eagle received a patent in 1921 for a flex head or hinge handle (colloquially, "breaker bar") that had the fork on the handle around the hinge head, with the hinge head pinned inside the fork. Like the overwhelming majority of hinge handles we see today. Back then, companies were forced to either license his design (e.g., Plomb) or make them the opposite way, with the hinge head forked and pinned around the shank. Or they risked a lawsuit. In the early 1930's, Eagle lost an infringement case against P&C and the rest of the industry immediately started making them the inside head way without fear of penalty.
Catfishdan
@Catfishdan
Thanks! You are a wealth of knowledge. Tell me you didn’t know that patent number by heart!
r_olson_06
SD
Thanks. When they come out of the evaporator I might find more markings.
For sure. It likely has a 2 digit date code that starts with the year 8,9,0,1 and A,B,C,D,E which is still widely debated yet on the 2nd digits purpose.
MShaw
York, Pa.
This is my only Plomb tool. A 3/8' drive 3/4" flex socket. Bought used around 1960. Saw a lot of use running down cylinder head bolts with a speed handle.
My difficult to find Plomb 1/2” drive ell handle arrived In the mail yesterday as part of a Plomb lot from an eBay seller. Here are all of the pieces in the lot.
The ell handle will be heading for my Plomb based GMTK. I believe there is a poorly struck 1940 date next to the Plomb marking. Less than ten examples of these have been found world wide. They have no part numbers and aren’t shown in any catalog. IMG_8944.jpegIMG_8946.jpeg
I was happy to see a dual marked 13/16” socket included with the other tools.
The 1 “ chrome plated socket wasn’t in bad condition. It was stamped with a BB mystery code.
I cleaned up the chrome plated 3040 DOE wrench with previous owners markings. The codes on this one looked to be a poorly struck AB.IMG_8950.jpeg
Two different styles of WF-38 ratchets were included. Any of the WF tools/pieces including the speeder are available for trade. IMG_8954.jpeg
Thanks to z281sc for the tip on the ell.
r_olson_06
SD
Nice find on the ell! That one has still eluded me.
I’m not sure about the spinner. It was attached to the rusty 3/8” drive ratchet when it arrived and has remained kind of a mystery. IMG_8961.jpeg
IMG_8962.jpegSpeaking of that rusty ratchet, it came out of the evaporust this afternoon and I did what I could to make it more presentable.
I worked it over with the 3M rotary wheels.
Since it looked better, I took it apart and cleaned and lubed the interior. I was pleasantly surprised that the screws came loose. It came out working really well. IMG_8958.jpeg
This 1/2” drive cad plated 5416 socket came in a Walden 1/4” drive set that arrived from an eBay seller. Here is how it looked as received. IMG_8975.jpeg
I ran it through the evaporust and carefully removed the grease in the grooves and gently wiped it off with brake cleaner.IMG_8990.jpeg
It may end up in my Plomb based GMTK.
