Maximizing stair width for basement stairs
branimal
I'm building a new set of stairs for my basement. I'd like to maximize width. In order to do that I'm going to leave the foundation wall exposed in the staircase area. I'm also going to leave the staircase header exposed.
Any tips or insight appreciated.
Here's a mockup of my best idea so far....
1. Blockout left stringer. Attach skirtboard to blocking
2. Cap skirtboard with 1x2 or 1x3, scribe to the foundation wall. I think this is going to be a long shot to get right. I could bevel the edge of the cap piece giving me a sharp point to scribe to the foundation wall.
I still need to think thru how I'm going to skirt around that pipe.
** foundation wall is shared with neighbors rowhouse. I mention this b/c its not taking on water/moisture from outside.
The Cobbler
I had a similar situation at a family members rental I renovated.
I did non housed stringer at the wall, and housed stringer at the wall side. Just scribe the treads to the foundation wall and cut them to length to fit in the dado on the housed stringer .
don't worry about the pipe.
part of renovations is making the best of a situation, not always perfection
branimal
What pipe?
Are you going to finish the basement?
The pipe is near the bottom of the stringer. Just under that scrap piece of skirtboard. Yes basement will be completely refinished. Drywall, lvp on the floor. Open space with a powder room. Which is just under the staircase. See toilet pipe.
Are you saying to scribe the treads to the foundation wall and skip the skirt board on that side altogether? Interesting. Maybe i'll do a test run. I would have to scribe the risers as well.
branimal
This guy scribed to a stone wall..... Awesome work. I've scribed to flooring and moulding to brick in the past. It's a long, tedious process.
mm08822
I think your first idea of a skirt board is the fastest. All cuts for stringers, treads, risers remain straight cuts.
Even if you botch the skirt board scribing, it could be pieced together and still look good.
Real easy to botch a custom field fit towards the end.
Any stringer should be full width lumber and not reduced with scribing. You would need to double up the wall side stringer if you were to scribe it. This leaves one completely uncompromised.
While I'm thinking about it, doubling up the stringers on both sides would help reduce the deflection as people run up/down the steps.
Stuart in MN
Minneapolis
I like the idea of skipping a skirt board, although scribing the steps to that wall will be tedious, it looks pretty lumpy. On the side facing into the room you could make the treads a little wider and that will help, although of course the limiting factor is the size of the opening in the floor above.
rlitman
Long Island
Widest option would be to build a wall under the header and end the staircase one step from the top, as wide as you want, because you're no longer limited by the doorway. Of course that make the handrail on that side weird, but you could have a narrow staircase that chokes down around the top step (and that joist). If that supporting wall doesn't hurt the layout in the basement too much you could make it feel a LITTLE wider (maybe 2-3").
I too would recommend a third stringer. Any chance these stairs will see a handtruck carrying down appliances or a boiler?
As for skirt board or not, you feel the width of the staircase at your shoulders, not at your feet. It makes the treads wider, but by not making the wall to wall spacing wider, it doesn't widen the stairs.
CraigStu
Blacksburg, Va
Does finishing the basement include covering the stone wall. If so the skirt could somehow provide something to attach the wall covering to I guess. If it were mine I'd figure a clear coat on the stone to make it look a little nicer and reduce dust. I'd skip the skirt board and run both stair tread and riser to the stone. I'd do somewhat of a scribe and trim but wouldn't go anywhere near as nice as the one you linked. I guess it depends on how finished you want to finish it.
carlaisle
This may not work since that's a shared wall, but I have used an angle grinder with a diamond blade to grind a nice flat dado in a rough stone wall. Provided support for the stringer and eliminated all of the individual scribing.
Superbowl
DC area
To finish the stair stone wall just stucco/parge it flat to the highest point and paint it. It will just look like drywall. Unless you are talented, get a pro to get a perfectly flat smooth surface.
branimal
I tried scribing a scrap top cap (1x3) to the wall. The wall goes in and out both side to side and veritcally quite a bit making that job very difficult.
Plan is to finish the basement with 1 5/8 metal studs and drywall EXCEPT in the staircase area to maximize tread width. See blue lines in picture. (there will be a bathroom underneath the stairs) Yes I will have to treat the stone. Clear coat in that area seems like a good idea, but I'd have to remove those paint stains.
Great idea. From what I read it sounds like a multicoat job - based on how far the wall goes in and out. Meaning contractor will have to work there 2-3 days. Maybe I can do a rough coat for two rounds and have the contractor finish it off?
Superbowl
DC area
The base coats for stucco/parging is very important. Find the high spot first. Work in sections. Set straight edges (angle iron?) about four feet apart that you can use to screed from. Attach them with anchor screws. Use shims to set the straight edges plumb 1/4" proud of the high spot. Rough up the surface good and dampen it. It seems to work best to scoop the material onto a trowel and throw it into the wall. Seems like a funny way to get it to stick but it seems to work best. Pile on the material and screed it flat with a piece of 2x4 resting on each straight edge. Just get it level for the first coat, not necessarily perfect. Pull the straight edges and let the first section dry hard. Set another straight edge and this time screed from your first section to the newly set straight edge. Continue until the wall is fairly flat. Patch any voids where the straight edges were mounted. The final coats take a skill to make a smooth flaw free wall.
mm08822
Make a template out of multiple sections of cardboard. Spend a little time fine tuning each piece. Lay them up next to/on top of each other and tape into a contiguous length. Put a few reference marks on the ends to indicate the face of the stringer.
Transfer the outline of the template onto the 1x3 and cut as required with a jigsaw. Fine tune the 1x3 profile. Undercutting the 1x3 will also help.
