kaymccampbell
Upstate New York
I went out to the stone cellar of a shop, and it;s like 90F... for effs sake,,, maybe I should put an AC out there. Never had to before this, but sh***, I;m running pickled cabbage/garlic/oniolns/etc... and its getting HOT in my pickling shed.
Damn this weather.... I hope my experimental grapes survive, but even they are HOT....
Damn....
Put your pickles on the floor. Or bury them.
Water for the grapes.
M.Brane
1 hr N/W of LA LA Land
Determined by pulling all spark plugs that cylinder 1 is leaking around the spark plug tube seal into the tube. I replaced this valve cover only approximately 4k miles ago because cylinder 5 was having this issue. It will be easier to do the job in July than it was in January, however I am not pleased a Dorman valve cover failed in under 5000 miles/ 6 months. The gaskets on these valve covers are internal in the design and cannot be replaced or I'd have reused the OEM valve cover. Needless to say, I am not pleased. I may use this as an opportunity to justify purchasing a cordless ratchet. The job requires removing a lot of fasteners which took a while with just my f80. Any recommendations on cordless ratchets appreciated. considering this kit as Im just a homeowner tinkerer, not a professional.
I have the 1/4" version of that ratchet for about 8 years now, and love it. Just be mindful to keep the head clean, and dry or you'll have to pull it apart to clean it. Not hard to do. If they get oily they will start slipping.
rzims
Grass Valley, CA
Let's hope you don't die. Nice work.
I've done some organizing too. This is a small portion.
Zim
Yeah, still in my early 60s so I have a couple of decades to get this wrapped up. I have about 6 or 7 of the Stanley organizing trays to go through. Its actually pretty nice to sit and have coffee in the morning and work through it
rzims
Grass Valley, CA
Thats the one I have and I love it...
Skyman
Central Maryland
It is a lifetime endeavor, but it also make any trips to find hardware so I can count them on the fingers of one hand annually.
There have probably been times when I could have gone out to buy what I need and returned home in less time than it took me to find (or give up on finding) what I've needed in my inventory. But, I can usually find what's needed here, and fairly quickly, despite the lack of organization.
Did the Church ever come deal with the crypt "left behinds" you found a while back?
DGersic
DeKalb, IL
You've got to have a bit of freon in the system before it will engage. 12psi IIRC.
Yes. With the tank connected, I have 70 PSI. But I’m not even getting that far. The wiring diagram I found looks like it a tenth generation Xerox copy, almost unreadable. I redrew it last night.
I don’t recall that breaker existing from when I wired the car. Need to check that. But I have 12V at the blower motor, so everything up to the blower switch must be ok. I do not have 12V at the drier pressure switch.
Yesterday, quick test, I stuck a jumper wire across the pressure switch, taking it out of the circuit entirely, that didn’t help. That was before I got out my meter and found no 12V on both sides of it.
It kinda has to be either the blower switch (no power out to feed the thermostat), the thermostat switch (no power out), or the wire between them.
evildky
Louisville, KY
Kept it light this evening because I had work to do outside too. I installed a steering stabilizer on the E-Scooter.
I gotta ask, why are you adding a steering stabilizer? I have a slower one and I've ridden a buddies that'll do 45, which is sketchy but didn't feel like the steering was unstable. then I also wasn't trying to make turns at those speeds.
Hooked
League City, Texas
Still dealing with some kinda infection on an ankle so not much shop time. This morning, however, I did get the tractor started for my wife so she could run the brush hog around the pasture.
While doing so I discovered my battery charger wasn't working so had to jump start using my truck. Turns out the wire had broken on the positive connector so I repaired that as well.
Keeping leg elevated for several weeks is really boring.
Lassen Forge
Damn....
And then - it rain 5 hours later.
I feel this is an episode of Clarkson's Farm... Maybe I should do a TV show, Lassen's Landing or something...
413dan
Massachusetts
It never ceases to amaze me what folks on GJ do in regular garages, not professional shops, all over the world. Love this spirit, it drives me to continue on, especially on those days my spirit and will are tested by my formal knowledge or skills/training. Keep up the great work, and I look forward to seeing your progress.
I stripped my hot rod build down to the bare chassis to finalise all the welding, modify a few bits and pieces and then paint!
bmwrd0
Beaver Fever Oregon
I have come across people who say you need a three bay garage with pit and lift if you are even going to change your oil, let alone restore a car, and we prove them wrong every day!
CoogarXR
Pulled the van inside the shop early this morning to unload the shelving units I bought yesterday. Trying to beat the heat.
Got them unloaded and stacked. I need to add some wood supports between the upright beams of the building so I can secure the tops of the shelves for anti-tip/stability. I did this for my existing shelves already. Ran to Menards to buy some more brackets to hold the wood horizontally between the metal beams.
Next step, go through my lumber stash and fish out some suitable wood, cut it to length, install it between the beams, assemble shelves, secure them in place, then move some more hoard/contents onto them, lol.
DGersic
DeKalb, IL
Well, that’s not good.
Got 12V as far as the thermostat. No 12V coming out of the thermostat. Capillary tube is now broken. If I jump across the thermostat, I get 12V to the pressure switch.
Thinking I can jump the pressure switch and the thermostat, just to get the compresorted running and charge the system that way.
jshillin
PA
This one is pretty quick and it just feels more stabile when turning. I adjusted the damper enough to where I feel it, but it doesn't work against me.
OccupantRJ
Eastern North Carolina
After many years of having a workshop and a separate storage building I now have my finding of the smallest hardware or other item down to under 5 minutes. It took a while to get to that point, but it has been well worth the efforts.
rd65
Granite Falls, WA
Cut some pipe for my engine hoist. New ram has a larger diameter rod than the old one. I will weld this to the mount and the new rod will fit inside. The only pipe I have on hand is just a bit too large, so I cut it down the sides. I will drill a hole in each one to plug weld it as well as along the sides and top. It might work?
zimman
Mark Twain National Forest
Operative word here is "coffee" LMAO
Zim
Mezz2006
Clintonville, WI
Patched some concrete that was popping in the house garage. Father-in-law was a concrete man for years, so he lead the charge on this. My boys helped out too... in their PJs. When chipping the popped concrete out, we found the rebar was pulled really high in the slab, so once the rebar rusted, it popped the concrete.
Also got the new shop overhead door openers wired up. Lots of up and down the ladder to drill holes, pull wire, hook up wires, etc. Had to temporarily wire up the wall station as the opener will not function without it.
As a life-long "shade tree mechanic" (currently in search of a shade tree), you've just described my dream world.
Exactly! I was going to add we call them Shade Tree Mechanics...
Yep, I can almost always go directly to where I have the part/fastener/thing. All too often its unobtanium in a local store anyway.
DGersic
DeKalb, IL
Fixed it 'til it broke?
I think Kay had your answer above^.
Good news is that Ranco products are still available.
I suspect the copper tube work hardened from 30 years / 100K miles of road vibration. When I moved it as part of getting the evaporator box out, it broke. Was probably inevitable.
Replacement is on order.
Beerhippie
Far NE Oregon
If you have enough slack when you mount the new one, leave a nice coil of capillary tube next to the thermostat--and the bulb end, if possible. The loop(s) will act as strain relievers, keeping the vibration from being concentrated at the end.
kidsmoke
flyover country
"Farmerizing" has fixed a lot of old machinery and fed a lot of people in this world. I chuckle at your welds but salute you for doing what you do.
There are those that'll tell you 'farmerizing' won the war.
I was told by a WWII vet many years back, 'they' didn't have time to train mechanics, so they made a conscious effort to direct midwest farm boys into the Ordnance Corps because they could make any machine operable in a hurry.
Prospecter
Maine
Love this suggestion. Will tuck that away for some time when I need it.
DGersic
DeKalb, IL
Hot wired the drier pressure switch, and the thermostat switch. Charged the system with r134. Got 45/300 PSI at ~100F ambient in the garage. Output is about 58F.
Shut down, disconnected, and the #*&)* Shraeder valve on the high side port won’t seal.
I’m reminded of why I dislike A/C work. Going to have to recover what’s in there now, replace the shraeder valves, and vacuum and charge it again.
