Old school residential HVAC tools
Firebrick43
West central Indiana
My 25 year old central AC unit stopped the other day and it needs a new fan motor. In the process of checking everything out I pulled my digital IR temp gun to help figure out superheat and it didn't work. New 9V battery, would start and pull the trigger it would die and restart as if the battery was questionable in current output but another battery same thing. Seen same scenario with digital torque wrenches which is always why I stuck with split beams.
Ended up using the kids rectal thermometer to measure the pressure line (they won't use it again as they are older now) and it did ok. At work I always used a fluke with clamp on thermocouple but my personal fluke isn't that fancy and really don't want to drop coin on another DMM or some fancy thermocouple only device that will be dead the next time I use it. If I was doing it professionally I surely would have a nice fieldpiece digital manifold with the wireless clip on thermometers.
I used a pocket kitchen thermometer to measure Delta T on the plenum and registers(don't tell my wife) and got to thinking, they had to use something like this before the digital age. But how did they hold it against the lines to take the measurements (without just setting there manually holding it for a few minutes)
Doing some google and ebay searches there certainly were analog micron gauges but they looked to be ungainly things. Were they used in the field on residential systems?
All my professional experience came from working on mill water cooled refrigerant chillers for CNC machines well after digital age tools were in play, More curious to what was used back in the day.
bonneyman
Desert SW
I had a few electronic gizmos when I worked in HVAC for almost 30 years. Most of my stuff was analog and/or old school. never had any issues. You don't have to spend $$$ to do A/C for the average home unit. I did mostly R22 systems with some R410a before I retired. Not a few times I had fellow technicians go bug-eyed when I pulled out analog meters and thermostats.
Were they as accurate as their digital equivalents? No. But if I dropped or fried one I didn't have to take out a mortgage to get a replacement.
If you are interested I can put together a short list for you - don't have the time right now.
F
Firebrick43
I would be interested in some pics or a list if you ever have time. Lots of history of other tools here, never seen HVAC stuff
mike93lx
Richmond, VA
It would be, But I am not interested in Jerry rigging it, it makes me feel dirty and cheap. And not in a frugal way
I am interested what the pros used in years past.
Quick, simple, cheap and effective doesn't mean jerry rigged. I take that classification as half-assed or corner cutting. Curious as to what bonneyman or any other former techs will say on it, though
bonneyman
Desert SW
First off, having a good set of various hand tools is a must. Screwdrivers, wrenches, pliers, nutdrivers, etc. can be pulled from your tool boards and shop as all A/C units are put together like most other appliances. I used a Bucket Boss - a multi-pocketed nylon sheath that slid over a 5 gallon bucket. Can carry a tool of stuff in there. Later on I put together a smaller Bare-bones tool kit out of a Husky plastic tote I got from Home Depot. That way, I would carry the small tote up on the roof and could do most jobs, but if I needed anything specialized I'd make a trip down to the truck and put it at the base of the ladder. Then pull it up with a rope and hook. No sense risking falling because you didn't have both hands on the ladder.
Your mileage may vary - set up your tools according to what you need.
bonneyman
Desert SW
I started out with tools I could afford - usually old school ones. I did upgrade some over the years but in most cases went back to the old stuff.
Thermometers - analog dial, or mercury bulb styles.
Gauges - I had one set of gauges and hoses for about 5 years. I finally got a second set when I dropped my first one and got caught with nothing to back it up with. I personally never went with electronic gauges, but started buying used manifolds and rebuilding/repairing them. I'm especially proud of the vintage set I restore, dates to probably the 1940's.
Meters - My first clamp meter was a Johnstone. Did volts, amps, ohms, millivolts, and temperature with an adaptor. Have secured a few others over the years but have migrated back to the old Amprobe "beetle meter". Doesn't need a battery for volts and amps, will work down to -5 deg, and will withstand a 5 foot drop.
Whatever works for ya.
bonneyman
Desert SW
Specialized equipment can be bought as the need/skill set arises.
A good quality capacitor tester is worth it's weight in gold (though with a clamp meter and separate voltage meter you can do long-hand style and check run caps.)
A schrader valve core remover is one expensive bit I'd get. Allows you to remove and replace a valve core without losing the charge.
A condensate line cleaner is another fancy bit that I think one should have. Runs off of a CO2 cartridge, hand-held, small, with adapters allows you to safely blow out plugged restricted drains.
bonneyman
Desert SW
After years in the industry I discovered the value of flare wrenches. Bonney made some really good ones, but they can be hard to source. Any good set of flare wrenches will do.
Over time I accumulated various small screwdrivers and thermostat tools to adjust/clean stats and other small electrical switches. You can grab those as you need them.
One cool minidrivers I got was a pair of micro screw starters. Absolutely killer for taking thermostat screws out without dropping them. Works well on computers and stereo equipment, too!
bonneyman
Desert SW
I used a ratchet and sockets for awhile, finally upgrading to ratcheting box wrenches in 1996. Gearwrench. Still have that set. Never broke one, tweaked one, or had one fail. And I wrenched on them hard!
Since then they've come out will all sorts of variations (super long, double box ends, flex, etc.), but whatever set you have handy will usually work fine.
F
Firebrick43
Thank you. The rectal thermometer doesn't look that much different. Yesterday when checking the A coil that little drain buster would have been nice.
The second manifold set looks awesome and I wish modern ones had gauge faces that easy to read
American Locomotive
Rhode Island
Second the valve core removal tool. It makes vacuuming the system down much faster, besides being able to replace valve cores "hot." Get the Appion one (or other brand name). The Amazon ones leak.
You can get multi-input thermocouple thermometers pretty cheap these days.
NOEYEZ
NOVA
We used Pres-tite tape (tar like tape that stuck to itself but could be re-used) to insulate the Taylor thermometer to the suction line or hold it in position against a coil assy.
OccupantRJ
Eastern North Carolina
When I was still working there were 8 rooftop AC units that I dealt with. I also had a Bucket Boss to use for tools, a bucket to pull needed items up with, as a water bottle holder, and as a stool when needed. All the testing tools were analog and included the black beetle Amprobe. There were also folded paper sheets with information and color traced wiring diagrams in the Boss pockets along with alligator tipped jumper leads to allow spending as little time in the direct sun on the roof as possible. A straw hat along with a white cloth to drape from under it onto the back of the neck made it livable when up there. It gets hot around here, and is predicted to be 100 with a 115 feels like this weekend. Staying cool is as important as the other tools.
danski0224
Near Naperville, IL
Almost no one used to pull a vacuum, much less use a micron gauge, "back in the day".
I had a Thermal analog gauge, it was the only game in town.
Now, Blue Vac is the standard. Theirs is still the best.
Used to have a Cooper thermocouple box, used velcro to hold the sensors on. Used a PT chart and did the math. The best analog gauges were maybe 1% accurate, typical were +/- 3% or worse.
I went to digital gauges way back when Digi Cool was first released and never looked back. Absolutely no point in using analog gauges today.
Snapped-off
Indiana
You can pick up k-type thermocouples pretty cheap, and k-type to banana adapters to plug straight into a cheap meter, if you end up doing anything additional in the future.
F
Firebrick43
Well I wouldn't want to have to use a chart to do calculations from mV. I don't have a high end fluke, just a 114, its pretty basic. I do miss the 87 that I had at my previous jobs.
Ironically though I was helping a neighbor with a grain leg motor problem a year and half ago and really wished I had a good clamp on meter to measure amps.
Wife got me a klein CL700 for Christmas that year and I haven't had to use it yet. When you post prompted me to go and look at my meters, stupid me forgot that it not only had the K type adapter but a thermocouple as well. I don't know what's worse, forgetting where you put a tool only to buy a second identical one later(fuel pressure tester earlier this year, found the original minutes after hooking up the new one) or just plain forgetting even what tools you have or what they can do?
So I will just buy a k type clamp on thermocouple and I will be golden. I know I need to buy a new manifold set for 454/r32 as I am going to be putting in another mini split soon and supplyhouse has the appion valve core tool.
bonneyman
Desert SW
Big 10-4! Watching for symptoms of overheating and heat stroke is a must. You don't want to get dizzy and fall off of a roof, or pass out high up where no one can see you and you cook to death unnoticed. Safety is a big concern.
Drink lots of water, rig up a portable umbrella stand, and if you feel yourself getting hot, get the heck off the roof. No job is worth roasting to death for.
Agreed, analog gauges are not as accurate as digital ones, but the OP was asking about old school options. For DIY'ers - and even beginner techs - quality analog gauges are the best bet. The cost of digital gauges alone was off-putting to me, and then having to worry about batteries, banging the delicate mechanism while you work, and then having to send them in for warranty work means you've gotta have a back up pair. One of my final jobs had a fellow tech missing his R-410a digital manifold in for its third warranty, and didn't have a spare. I lent him my analog set, as I was riding with another tech at the time and didn't need it.
For Yellow Jacket brand, analog for $200 a set and their digital for $1200 a set shows the disparity. One can always upgrade if the want.
I used such a setup when I was working. Last job I had my co-worker measure the temperature with his digital gauge set and I did the exact same unit with my setup. I was 2 degrees off from his as I recall.
The modern version of the one I used.
The Creme de la creme Fluke version which I snagged used.
Most new meters have a temperature function already built in like you mentioned. There was a new multi-tap digital thermometer available that my final job would have required me to purchase if I was going to work there. Didn't take the job, but the tool was pretty impressive.
bonneyman
Desert SW
No calculations needed. The probe adaptor converts the temperature it's reading to mv, so the millivolt scale on your multimeter displays the temperature.
F
Firebrick43
Do you have a link to share for that type of thermocouple to banana jack adapter, or did I miss it?
I was ready to say BS myself but there are active converters apparently. Good to learn something. Of course there is yet another battery to be dead when one needs it.
OccupantRJ
For my retirement use I think I might try one of the dual reading clamp on models of thermometers available on the jungle for less than $50.
bonneyman
Desert SW
A close-up of the low side gauge for your viewing pleasure. When was the last time you saw R-12 and R-22 on the same faceplate? You can find old style manifolds on ebay for reasonable, and put on your own gauges and hoses. I prefer the larger 3 1/8" gauges over the standard 2 1/2", but they can get a bit pricey. And get hoses with self-sealing valves on the ends - or buy a set of Yellow Jacket add-on quik connects. Come in all sorts of configurations - and will save your fingers from burns.
I am a sucker for old HVAC tools and equipment. I also love multi-purpose tools.
Take a propane torch, for example. Good for soft soldering and other general heating purposes. But I have an adaptor to use a 14 ounce propane cylinder to run my Coleman camp stove.
Also, I have an old halogen detector that uses propane. Of course, you shouldn't use it in an enclosed area, as burnt freon creates toxic gases. And it also works on R-410a! (Personally tested) The flame turns bright yellow, rather than the greenish purple with R-22. The copper reactor disc is easily replaceable, and in a pinch you can make one out of a piece of soft copper tubing.
Plus, no need for an electronic ignitor nozzle (though I do have one of those torch tips). I used a welding striker for years, and then found an old-fashioned self lighter that uses a flint from a Zippo pocket lighter. You outta see the looks on guys faces when I pull that thing out!
Finally, I found a mercury-free liquid thermostat at a pawn shop. Works just like the old silver liquid but non-toxic.
danski0224
Near Naperville, IL
I picked Yellow Jacket because they're a brand I know and trust.
Well, except for the first two iterations of the Digi Cool digital manifold, pretty much everything is now made in China.
There's way more choices now, compared to when the Digi Cool came out, but the Digi Cool was made to be just about bombproof. I recall many, many issues with the early Testo digital manifolds.
There's also so-called smart probes that need an app to work. I have used Fieldpiece and Testo versions.
bonneyman
Desert SW
Pretty much everything is. But CPS stands out.
I have one of their older manifolds, says made in USA. And it's become my go-to gauge set even though I have several other nice ones.
Their website says their manifolds are made in USA - but then further down it's the "Manufactured in USA out of U.S. and globally sourced components". So, older stuff for the win!
bonneyman
Desert SW
Continuing on with some older HVAC tools I have, the following are by no means mandatory. They are just some things that helped me with troubleshooting and repair, and didn't cost an arm and a leg.
One simple device I bought (after a referral from a refrigerator tech) is a line splitter. You can check amp draw on a window unit A/C - or any electrical appliance - without having to disassemble the equipment. Here's a pic of mine with a plug in receptical tester and a lighted plug adapter that lets you know if a line is live without needing a voltmeter.
This one incorporates all the above functions in one unit - as well as a GFCI!
As an afterthought I think a NCV detector is a really good item for the toolbag as well.
Another is measuring air flow at the vents to test/balance the system. Dwyer makes nice equipment - and expensive. This pocket gauge can get you close in the field and it's affordable.
Finally is a fan blade pitch gauge. When trying to secure a replacement fan blade it's easy to measure the diameter, direction of rotation, and bore size. What's difficult is determining the pitch of the individual blades. Specifications need to be precise because - if you're off - it might adversely affect condenser air flow. Most warehouse counter help have no way you tell you what you have/what you need. With this little jig, you can directly measure the pitch angle, and any motor shop that sells fan blades can get you the one you need.
F
Firebrick43
I guess the one old school hvac tool I do have is a Dwyer flexible U tube manometer.
The fan pitch tool is interesting, something I guess I would have never thought of being an issue till you described its use.
bonneyman
Desert SW
I also have a bunch of old fashioned meters and gizmos that I've picked up along the way thinking that the day might come when high tech digital stuff won't function but I still need to be able to work.
There's this electronic supply place in town, and they do electrical repairs. If the customer doesn't want to go ahead with the repair and leaves the device, they disassemble the things and throws all the useable parts - including gauges - into surplus bins to sell to the public. Got several great old meters and switches that way.
I found and did minor repairs on a Simpson multimeter. Series 5M, probably around 1969.
Found a AC voltmeter with a plug installed. Perfect for 110-120v residential go/no-go tests.
Also snagged a DC amp meter, probably used on starter circuits for cars. I thought it might come in handy for the newer DC ECM motors. Never got a chance to try it out.
Got an old Chicago Industrial analog gauge. Nice and compact.
A Triplett voltometer. The 10VAC circuit is bad but I wouldn't use that anyway.
bonneyman
Desert SW
The Dwyer U-tube manos were premium tools, accurate and nice quality. But most of us guys keep managing to let them tip over and lose the fluid. Digital was the best way to go for the pros
fitter30
Peace Valley,mo
Graduated in 1971 from two years hvac trade school day school. Mercury manometer for vacuum, gauge manifold with analog gauges. 12,22 500 for high temp ac. R11 for 95% of centrifugal chillers some were R12. Analog muilti meter amp probe and a Yew megger 1000 volt. Serviceman thermometers. 2012 retired still use analog gauges, digital thermometers fluke muili meter and amp probe. Worked on everything from process chillers to high and low pressure boilers from a drinking fountain to 2500 ton comfort cooling centrifugal. With phones ,Internet and gauge manifolds take figuring superheat, subcooling take the fun out of service. Takes the fun out of thinking. Never trust a gauge or a thermometer without checking it out. Last contractor had them fooled for 3 generations and 40 years.
98ssuck
British columbia
Anyone else remember open drive vacuum pumps?
Used an analog scale at one point. Charging cylinder to weight in very small quantities of refrigerant. Don’t forget the Simpson 260 MM. With the leather case
fitter30
Peace Valley,mo
Still have one with 1/3 hp 1750 rpm has a handle made fron 1/2" rod stock that my older brother used after trade school in 1971. Used it about 7 years ago after flushing it with new oil pulled 600 microns Pump must weigh 50 lbs.
bonneyman
Desert SW
I was watching some Youtube videos about guys working in the field, interesting to see they way techs are working the job in todays environment.
The wireless pressure and temp probe set by Fieldpiece looks interesting. Feeds the temps and pressures to what looks like a smartphone, and it read everything in the palm of your hand. Makes it really nice if you work with several different refrigerants - no need to have multiple gauge sets. Just hit the freon tab on the phone, and it pulls up and converts everything right on the screen. Plus it allows read the thing from a distance, means you can be in the house checking the filter and stat and keep instant track of the parameters outside. But at almost $800, I'd be hard-pressed to recommend that to a DIYer.
And have been looking at digital gauge sets. It appears the older Digi-Cool manifold is about the best, as has been stated somewhere previously. If I were to go digital I'd probably consider them.
danski0224
Near Naperville, IL
Maybe.
I wasn't able to maintain a wireless connection with the phone two floors up (wood framing) and about 15 feet over laterally.
Was using Fieldpiece and Testo probes.
Fieldpiece makes (or used to make) a sort of signal repeater, and i believe it only works with their app. Quick search shows that the new tools may not be compatible, didn't really dig into it.
Testo does not have a repeater.
The only other option I'm aware of is "iManifold" (no relation to Apple), which has essentially unlimited range, given enough repeaters. It can also handle multiple sensors/probes.
