Slowboat
I recently purchased a Kubota L35 with BT900 backhoe. There is a fair amount of slop in the backhoe mount. I have gone through the top of it and everything is decent. Finally decided that my slop is in the bottom hook/rest mounts. The hooks are part of the frame and pretty wallowed out. The “pins” the sit in them are also worn down, but it is a welded rod and part of the hoe frame.
How should I build back up the material? It doesn’t have to be a perfect fit, but the better it is, the less slop in the system.
I have a small plasma cutter and a mig welder.
Options I see
Options I see
- mig on material and grind down
- Cut a tube in half and weld in (or use as a grind guide)
