By the time you get two coats of primer, and two finish coats, it still won’t be smooth and joints still show — you could’ve put up drywall. And saved yourself money and time. And it would look nice.
I'm with you on this one!
Drywall is the absolute standard for a reason, offering the best balance of
fire resistance, affordability, and smooth finishing. Yes, you absolutely should emphasize the fire safety of drywall, as it is one of the most effective and common passive fire-resistance materials used in modern construction.. Building my 1,500' attached shop with X rated drywall not only saved my other attached shops, my home, and possibly my life too.
Aftermath of fire in my attached shop.. What the chance of a fire? Doesn't matter when it happens at home..
Hanging and finishing drywall is actually no big deal. I was 75 years old when I hung and finished nearly 10,000 pounds of 5/8” fire rated 4' by 12' sheets of drywall. As far as hanging things from drywall. I use plastic self drilling anchors. A single anchor is rated at 100 pounds in 1/2” drywall. Maybe 40% more in 5/8”. Plus what's the big deal finding a stud and or a joist? Then using lags screws...
Picture on my home workshop today after my rebuild...
