Which toyota adapter for this brake bleeder?
Bennylava
Cleburne, TX
So I got this OMT brake bleeder off amazon and of course the recommended 42mm adapter doesn't fit the brake reservoir. It's screw on, and the 2018 camry hybrid has that other thing they call "twist" or push lock. It functions similar to how a radiator cap does.
I think I might be able to use something like this, but I thought it best to ask all you veterans first:
Beerhippie
Far NE Oregon
I bought the same bleeder, but in the version that is supposed to come with the Toyota/Lexus adapter. It was the same as yours. I bought a kit that had caps that fit my Vanagon and '93 Corolla.
Of course, the adapter kit cost more than the bleeder kit....
But this thing totally changed the brake/clutch bleeding game. One person a a few minutes, no worries about ever letting air back in, no yelling "hold... now pump". Just fill the tank, pump it up some, attach it and start opening bleeders.
My only complaint is that it wastes some brake fluid if you're not using it daily. I'm running DOT 4 in my rigs now and it's a bit more spendy than DOT 3.
signcrafter
I bought a pressure bleeder similar to yours from amazon a while back and it came with 5 or so adapters and I couldn't get it to work on a ford. Ended up order this and so far it's been great. Haven't used the toyota adapter yet so can't say for sure but it has a bunch of adapters and seems well built.
FigN⋅m
The Speedi-Bleed looks pretty slick, and I think I may pull the trigger on one.
One minor question: Do these styles of bleeder end up overfilling the reservoir?
Easy enough to hit it with a turkey-baster, but it does add a step.
Chipm
Georgia
I have a Mityvac pressure bleeder that works pretty well and includes the Toyota adapter. BUT, I have found I really prefer vacuum bleeding for routine fluid replacement. I use an 8-quart oil extractor. The pressure bleeder still works for stubborn caliper replacements and that sort of thing, but I probably don't even use it once a month now.
Bennylava
Cleburne, TX
Yeah I'll just buy that one and send this canister style one back. The vacuum idea is better anyway cause you'll never need any adapter. All you do is siphon out the reservoir and then fill it up, while making sure it doesn't go down too far when you're pumping.
Vacuum method seems like the superior tool for the job.
drtyler
Vacuum bleeding can introduce air into the system. Also, it is sometimes difficult to get all air out unless you finish by old-fashioned bleeding or pressure bleeding.
Pressure bleeding is much better in my experience. Nothing difficult about it.
Beerhippie
Far NE Oregon
Yeah, I don't understand why vacuum bleeding would be easier. The pressure bleeder takes about a minute to set up, then just go from bleeder to bleeder--starting with the furthest from the master cylinder--bleed 'til clean and bubble-free and you're done.
I've never seen nor used anything easier.
A reservoir adapter with the little drop tube is designed to prevent over filling the reservoir.
gizardlizard
Madison, WI
Not at all. Once you remove the Toyota adapter from your reservoir, the level is about perfect. There is a larger reservoir the kit comes with to hold the bulk fluid
drtyler
You can always just use them for the pressure only and not for refill. Have to keep an eye on the reservoir level, obviously, and it does add an extra step when you have to add more fluid to continue bleeding.
Not as big of an issue when the hoses are new, but it does introduce the possibility of spraying brake fluid everywhere if a hose bursts if using it to refill. The speedi-bleed hoses are fairly robust though, and my previous experience was with a Motive bleeder. Hoses are clear and seem to age quick, at least on mine.
Bennylava
Cleburne, TX
Not according to the premier Toyota mechanic - 18:25 here:
Beerhippie
Far NE Oregon
Does pressure vs. vacuum make a difference with ABS? Never had any, so wouldn't know.
I sometimes forget some crazy folks like to drive these new-fangled rigs with all kinda' electronical stuff.
signcrafter
Not really. I have both and have done it both ways depending on why I'm doing it. Just to change the fluid or even replace a caliper you aren't activating the abs module so it doesn't come into the equation. When I replace an abs module I have to use scan tool to do the bleed. It cycles the abs a few times. Most factory service data tells you to hook up a pressure bleeder when doing this.
Bennylava
Cleburne, TX
Might as well use this thread to ask another question - What do you guys use to clean up your brake tools? It occurs to me that you may not want to just leave brake fluid sitting in all the lines and fittings of your brake equipment.
First thought would be water. It would of course merge with, and carry away all the old brake fluid. But if not, maybe... alcohol?
Beerhippie
Far NE Oregon
I would not want to leave water in my tool lines. I blow them out. First use afterwards, I'll give the reservoir a quick rinse with fresh brake fluid and run a bit of brake fluid through the lines to be sure there's no contaminants in there--but I'm using a pressure bleeder.
cgrutt
I usually run a bit of denatured alcohol through pump and hoses of brake bleeder and also in oil pans after using them.
Bennylava
Cleburne, TX
In case anyone searches in the future, the Mityvac one worked great. No issues, and didn't have to buy an adapter that costs more than the tool.
All I did was follow all instructions on that Car Care Nut brake bleed instruction video.
