Tools of Japan
GeoBruin
https://www.esco-net.com/wcs/******/ec/feature/detail?index=130
looks like Esco is the original manufacturer (press 1 for English)
Perhaps they are the original (AI didn't seem to think so but there was no proof I could find in the links) but as I mentioned, they don't make an SAE version.
If you get around to testing on a 1/4-20 or M6 let us know how it went
I did find this video where he cuts a 1/4 - 20 bolt. Obviously takes more effort but it seems to work.
rust in the eye
Chicagoland
<I.S> (within a diamond similar to old SK)
Sorry for crummy photos.
raised center, reverse reads "drop forged JAPAN", curiously JAPAN is(rather lightly) stamped not forged in as all the other markings.
Only example of the brand I can find.
Thoughts? Maker?
Steel_Rain
Thoughts? Maker?
Possible Asahi? The font reminds me of them.
KnurledNut
n/a
I came across a Vessel Cushion Grip #2 crosspoint screwdriver, the regular cushion grip, not the super cushion. Apparently they stopped making it in that size as it’s no longer listed. Anyone know when and why?
rust in the eye
Chicagoland
Thoughts? Maker?
I found a Japanese cutting tool mnfr, Ishihashi Seiko, but their logo is vastly different and I see nothing but cutting tools offered.
Has anyone seen this brand before?
YesIHaveAHammer
Japanese video
New machine screw cutters from Engineer.
No SAE, and no M3.5 for European light/socket face plates.
M2, M2.6, M3
M2.6, M3, M4
M2, M2.6, M3, M4
Exactly like the above one just with one extra hole, oddly.
gmt
SoCal
The super cushion (gel) screwdrivers replaced the cushion screwdrivers. When, maybe 5 - 10 years ago. (just a guest)
Bad Mojo
Have some upcoming automotive work coming up, so no better reason to order tools! Also Japanese tools for Japanese trucks just seems correct. By one of the photos I suspect you'll know what brand I am working on.
First up is items from KTC. The black pry bars are brake adjusters. The little spring clamp looking pieces actually clamp onto the door switch that controls the overhead light. Lastly the blue brush is just for cleaning up afterwards. I like having one by the project sink.
Next up are 3 different kits from Tone. I've been wanting to try out a ratcheting screwdriver. The little black kit will live in a truck for swapping batteries. Lastly, the 1/4" hex drive was a bit of "I know I don't need this, but until I purchase it I will feel a void in my life that only this tool set will fill". Sometimes you just need a fun tool and they call that color of case raspberry which adds to the fun factor. You can also get the get in a black case.
Most of this stuff is all stuff that I have seen before in this thread. I am looking forward to trying out the Eight Tool L-Keys. I am very happy with my Wiha L-key set, but those live in a dedicated travel kit. These will be more for bench work, and yes the SAE and metric have a similar "Magic Ring" to the Wiha. Also the auto punches are much more comfortable in the hand than what is readily available state side. Lastly, the narrow needle nose pliers are a second pair because I find that I use them enough to justify.
Bad Mojo
Moving into long items and Koken stuff. All the red Koken boxes are for pulling studs or installing studs. Interesting to me is all the latches on the boxes are different. Does that matter? No, but just a little random detail thing, yes. Also the Koken ratchet is my first from them. I understand why they get so much praise. Its very smooth! Like I wish I hadn't bought it because the evil thought of have at least one in all the sizes has entered my mind. The only thing that surprised me is I find the handle small and this is coming from someone that wears a medium glove. I prefer the Tone oval handle. Speaking of handles the knurled handle on the Koken breaker bar does get a thumbs up from me. I choose that one because if I am using a 1/2" breaker bar I don't want it slipping in my hands.
Next up is items from Koto and Hasco. Both brands I've not seen much or anything about. The puller is a pilot bearing puller. The bottom pliers are for C-clips for drum brakes. The top pliers are for electrical connectors but the jaws can be adjusted. From what I can tell is Hasco is more for semi-trucks and box trucks and not passanager vehicles for the most part.
I did the dangerous thing of seeing if I could get physical catalogs, and succeeded for some of the brands. Sometimes I just like a classic catalog. I also learned KTC makes a small selection of dental tools. Who knew!
Last, but not least is I think I found Toyota branded Koken sockets. I have heard Toyota is starting to switch over to them for some of their tools.
KnurledNut
n/a
They still have some sizes in their current production, so I assume only part of the line was discontinued?
Dave455
Sussex, England
Nice!
Those Tone bit ratchets have been of interest to me for a while. Obviously made in Taiwan (or at least the ratcheting mechanism is) but a longer handle than most. Good for access, if not leverage.
The KoKen roller stud pullers are the best I have used. Nothing grips as well, with so little damage. One of their “stand out” tools I think.
With regard to the ratchet, bear in mind that is a Z Series ratchet, so they are supposed to be compact!
Bad Mojo
Nice!
I've been pleased with the Tone ratchets overall. I have been filling out the collection with the different drive sizes and fixed head vs flex head. I would say they are a good value especially in a non professional setting, but would be reasonable in a professional setting.
Oh, good to know on the Z series ratchet. Thank you for pointing that out. I need to spend some time in that Koken catalog and do some research.
I'm excited to give those stud pullers a try. In your opinion/experience is it a remove stud with the understanding that the stud will be replaced or reused? I don't mind replacing, but just helpful to know if I need spare hardware on hand.
Fedwrench
Valley of the sun
What's the pink handled KTC tool above the spring hook tool?
Bad Mojo
@Bad Mojo -
where did you source the little "Kurokin" adjustable from?
That one was bought from Yahoo Shopping Japan. I did use a shipment forwarding company to handle the shipping. It looks like it available from Amazon state side. FLS-43-BG is the model number.
It is a brake shoe spring holding tool. ABX-33
Dave455
Sussex, England
I would totally agree!
Yes, the KoKen range is huge, and I’m not convinced many of the importers really do a good job of explaining the different lines. Always assuming they understand themselves.
The Z Series was introduced a few years ago to be a compact range of tools, specifically designed for working on modern vehicles / engine compartments, where space is tight.
Sometimes the gains are marginal, but overall they are there.
Worth downloading, or at least looking at KoKen.jp, where everything can be seen.
I don’t know what the original intention was, but I have certainly re used studs removed this way. I have also needed to run a die over a couple, and totally wrecked others!
I think you have the best chance with the “deep socket” style, as the contact area is so long.
But ultimately they wouldn’t offer the threaded style “stud setters” (which I see you also have) if the roller style never damaged a thread!
BMWBOB2
A good friend gave these pry bars a few years ago and told me they were Japanese made, but they were so filthy I couldn’t find any sort of manufacturing marks until I finally cleaned them up today! They seem to be of high quality: the bigger one was abused rather hard by me, and the edge of the chisel end of the big bar reflects the damage, but I had to work at it
Should this be in the old tools section or the Japanese tool one? Any guesses as to the manufacturer?
Thoughts? Maker?
AA said:
The I.S. in a diamond is the mark of Inoue Seisakusho, which was succeeded in 1984 by Daiya Seiko. The Inoue company operated in Sanjo City, Niigata prefecture beginning in 1930, and by the 1950s was making wrenches for some motorcycle manufacturers.
AA
Daiya Seiko / Daiya Seiko (Daiya Seiki), 1-4-20 Osachi-Katamacho, Okaya City, Nagano Prefecture, 394-0084, Japan / https://daiya.co.jp/en/ / est. 1951 / successor to Inoue Seisakusho / http://alloy-artifacts.org/japanese-tool-makers.html#daiya /
Inoue Seisakusho / Inoue Seisakusho, Inoue Mfg. Inc., 58 Shirane, Isehara-Shi, Kanagawa-Ken, Japan 259-1147 / https://www.inouemfg.com/ / est. 1916 / succeeded by Daiya Seiko, Okaya City, Nagano, Japan / "IS in a diamond" logo stamped on wrench /
rust in the eye
Chicagoland
Thanks for info on my I.S. wrench. The guys here never cease to amaze me.
I think it likely this wrench probably got here in a motorcycle tool kit. I acquired it along with some other "motorcycle" wrenches, those the ubiquitous double open enders from Honda, Yamaha and Suzuki.
Seems a decent wrench so I kept it.
here is a bit better photo of the back side with COO stamped rather than forged
Steve_P
They are. I have the Matco ones, from the VIM closeout page, and that is exactly what I use them for.
Yep. I wish I bought 10 pairs of the Matco on the closeout but I wasnt sure I'd like the handle angle. They're fantastic. I also have the SK-11 that I bought later and wish the handle angle was like the Matco.
rick carpenter
Huntsville, East Texas
Nice haul! You'll feel very confident using your Eight hex keys.
4xdog
Santa Fe, NM
Do you have Toyota (or Ko-ken) part numbers for those sockets?
Big Jimmy
Kansas
After using a 5mm wrench at work, I realized I should probably get some small metric wrenches in case I need them in the future here at home. KTC seemed like a good choice as the set of metric wrenches I have is KTC-made Craftsman BF series and there was not any options available locally that seemed worth the cost. I also got a KTC 10mm 1/4 drive 6 pt. socket because it's neat to have a KTC socket and I was already ordering. The wrenches are 3.2, 4, 4.5, 5, and 5.5mm sizes.
Steel_Rain
Also wanted to say absolutely beautiful tool haul you have there. I own just about all of that (less the long TONE ratchet) as well and couldn't be happier with them.
Bad Mojo
For the 10MM is 3350M-10 and the 8MM is 3350M-8.
However, that is just for the Koken socket and I don't believe will be branded Toyota. I did some searching and I don't see them listed on the Toyota SST list yet. To be honest I lucked out on these. I got these from someone who was selling some used Land Cruiser manuals in Japan and I added them onto that order. I think technically they were used, but are in great shape. It seems like these days that my Japan shipments are a mix of parts, manuals, and of course tools! You might like post #12334 in this thread where I linked a video that mentions Koken becoming a supplier for Toyota.
Bad Mojo
Thank you. I've been happy with just about everything I have bought so far from Japan as well. I think this thread has been a help with seeing that is available. It would be a lie that I haven't thought about trying to find a reason to go Kansas City to go Harry Epstein just so I can see the tools in person. Probably a dangerous thing to do, and I suspect I would come home with a Koken 3/8" drive in a 1/4" body ratchet.
roggy
Oh no, I think I must be deleloping a reputation…!
To quote James Garner “What would a man want with a reputation”?
The important thing to bear in mind is that origins of a bit driver don’t really matter for hand operated / C6 bits.
For power / E6 bits it makes a huge difference. You have to use a Japanese tool with a Japanese bit (or they don’t fit) and it’s best to use a U.S. or European spec bit with the same spec tool, or they have a lot of slop.
But for hand bits, you can use what you like.
In honesty, my favourite non ratcheting bit driver (and we all need one) is probably the PB 186 M.
You do need the magnetic version, but subject to that, these are pretty faultless. The whole tool is durable, but particularly the handle - no useless (but cheap) soft finishes. The bit retention is superb, and they are inexpensive.
For ratcheting, I must admit I prefer the hard handle Snap On. The ratchet is smooth, but most importantly the handles are durable. That is so important.
I like the short version, so handy, but also the ergonomic T handles, if you have space.
The PB Swiss are also superb, and the new ratchets are buttery smooth. Probably better than the Snap On. But.. they only come in soft finish handles now, which suit maybe 10 % of my tasks! The older sprag clutch tools are lovely, and the cross handle are nice too.
And I think honourable mention has to be made of the Facom. A lovely smooth ratchet. Little back drag. Durable handle. And overall very nice to use. Reasonably priced this side of the pond.
If you wanted Japanese then Vessel make a selection. I only have the yellow Powergrip model. It’s o.k. but let down by the plastic bit retainer which doesn’t feel durable.
Great collection, by the way, pb 6510a gearless ratchet screwdriver is discontinued.
Dave455
Sussex, England
Yes, I was aware of that, and I think it’s a bit of a shame as they are superb tools.
The later ratchets are lovely to use, but they are conventional ratchets, and I’m not a huge fan of the soft Swissgrip handles.
The slightly harder Swissgrip Evo handles are probably an improvement.
Ohio Andy
Columbus, Ohio
I marginally prefer the newer handles but not enough to replace all my older handles.
YesIHaveAHammer
Gyokucho Razorsaw Rakunandesu Anvil Pruning Shears
With dual fulcrum leverage multiplication. Probably the most advanced design I've come across in many respects.
NitroExpress
Texas
So, I get my shipping notice from a Harry Epstein order I placed this past weekend and notice I’ve placed an order for these:
This was obviously me fat-********* something during the ordering process as I didn’t purposely order them. I’ll call this a pleasant surprise to myself, as I don’t intend to return them. I can find a home for nearly any wayward tool!
I’m not familiar with them. Do I have something useful? Is the cutter more flush cutter or wire cutter? I’m guessing they are quite small.
Dave455
Sussex, England
Interesting!
What you seem to have are effectively miniature linemans pliers. I must admit I didn’t know such things existed. I could see those being very useful for automotive wiring applications, or even for a road box where you don’t want to carry too many small pliers.
I don’t think they are flush cutters particularly, and probably better for that.
Stainless steel too. Probably limits the cutting capacity a little, but works well for small pliers.
I like ’em.
YesIHaveAHammer
