All true. This tiller belonged to my wife's granddad and it means a lot to her, which is why it's in pieces on my workbench getting sanded, primed, and painted. I would have been fine buying a newer used one but, again, I'm married.I agree on an entire new bearing. but I doubt this thing will be used much at all, perhaps a bronze bushing would be able to be sourced cheaper .Hard to say if it's worth it but sometimes we fix things because we want to, not because it's the most rational thing.
I'll try to figure out the measurements on a whole bearing. Can't imagine me getting it right on the first try.It's probably time for you to spurge on a "whole" bearing.
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
That's what I thought too. I have a manual similar to that one; I tried to press and the case started to bend. Even if this is some low-production off-brand, I would think they would all use the same design/parts.Looks like those bearings press out: https://www.scribd.com/document/93545132/Merry-Tiller-Manual
Parts appear to be available; google Merry Tiller bearings....
That's a good workaround. Thanks for the tip.If the existing needles are sound I’d be tempted to cut some HSS drill shanks for the few needed.
YMMV
