Between 265 & 485 SQ/FT Uncle Lenny's house of toys and tools
L
LeonardY
Southern California
Another consolidation of life. I posted some of this before elsewhere. I don't remember exactly where and what. So sorry, if I am repeating myself.
I've been working on the house. It started innocently enough. I took my friend to a carpet place. I've been meaning to have my carpets replaced about 5 years ago. I that point, the carpets would have been 25 years old. I picked out the carpet. Got a call from the owner. He said I picked the most expensive carpet in the store. (Not sure how he got the impression I was frugal after the measurements.) First quote, $8500 . Second quote, $6000. After I picked out another that was very nearly the same.
One thing led to another. I figured I should paint all the bedrooms. I take a long time to make decisions when there is nothing pressing. I can make fast and quick decisions when there is a deadline. Picked paint colors.
I needed to move all the heaviest stuff out of the rooms for the carpet guys. Box up for all the nick knacks. Clear out the closets. Things like a Metro shelf unit full of books and models. Shift all the furniture away from the walls. And so forth...
Here's where Murphy's law takes effect.
I had 2 weeks to paint before the carpet install. I thought the quickest way would be to use the airless sprayer. I masked all the rooms which took several days. Ripped up all the baseboards. Nice part was I didn't have to be worried about the carpet.
I started the first room got done with one and a quarter walls. The sprayer stopped working. Took the gun apart and found the filter completely clogged. Tried to flush the filter. Ended up replacing it. Started again. Sprayer worked for a little while stopped again. Cleaned the inlet filter. Worked and stopped. I then proceeded to clean the entire sprayer and pump for a day. (Or should say wasted a day.) I broke the inlet valve and fixed it. Or so I thought. The only thing I did that was smart was to test it with water and then abandon the spray the room option.
Things that happened along the way. I wasted paint trying to spray the one room. The previous color, a bright yellow was showing through the first coat. I went to prime the ceiling first to avoid the second coat. Opened a bucket of primer that the painters had left from doing the outside of the house. and this is what I found.
Rust in the paint. Great... I filtered the paint. Had just enough to do the ceiling. Tossed the bucket. Win...
I started cutting in the front bedrooms and I noticed something wrong but I was so tired from the previous days. I was just pushing through. What I failed to notice was the color was off. When I realized it. I opened the second can which was the right color. The other can was the base. No pigment. I headed to the paint store. I needed another gallon for the first room and a gallon of Navajo white. I finished Saturday evening.
One room, before and after.
Couple of days behind my self imposed schedule but still ahead of the carpet install.
I removed the rest of the baseboards in the closets and hallway. Then moved anything off the floor in the closets.
While in the closet, (Which I know sounds wrong.) I didn't like the way the shelf was carpeted around the legs. I cut them off at 45 to the wall.
The main stair case has been needing some repair since I bought the house. There was a miss cut on the stair trim. You could see a gap. I had complained to builder but they did nothing. Also the seams were done like ****. Not to mention that they painted the trim flat white.
I patched the hole. Sanded, filled and sanded the seams.
1782397809475.pngPeeled back the carpet. I used drywall screws to hold while painted the trim a satin finish.
The last thing I did was add a plywood plate for the safe to sit on. It's better than having it sit on carpet.
I've got a few touch ups to do but I'm ready for the carpets.
L
LeonardY
Southern California
Friday was carpet day. I disassembled my computer and my bed. Moved a few more items before the installers arrived.
They were surprised. They expected to have to move a lot.
Started at about 9 and finished at 2. With a lunch break.
Goodbye old dusty carpet.
Next up is new baseboard and replacing the CAT5 with CAT6 cables.
While they worked inside. I worked outside. I installed a new sprinkler timer.
Also printed this for my niece's wedding cake.
L
LeonardY
Southern California
I haven't been as active in the garden since I started my unplanned renovations. It's a balancing act or more like spinning plates.
I've lost my entire crop of San Marzano tomatoes for the second year. Either it will be crop rotation, sterilize the soil or replace it. I will try crop rotation. Although, I'm leaning towards replacement. It's more of a matter of what to do with the old soil.
I lost a zucchini and cucumber too. Not sure what killed them. It's likely grubs.
On the more positive side. I have a lot of tomatoes. A lot earlier than any year before.
This is about 30 lbs worth.
I'm guesing that this one is close to 2 lbs
The Italian zucchini is happy.
As is the kabocha.
Strawberries are doing well. Still need to make a hanging wall for them.
Just enough for a smoothie.
L
LeonardY
Southern California
X-Wing update.
I've gone down the rabbit hole and then detoured down several tunnels. I've finally settled (For now.) on a direction.
I'll keep it to myself. If I told you the direction, someone might hold me to it.
Here's some of the progress.
I remodeled the interior engines. The cables were a PITA.
Before.
After.
I remodeled the wing.
Before.
After.
The other wing is still in process but looks the about the same.
Thanks for following along this haphazard journey.
L
LeonardY
Southern California
I’ll bite … what is it? I don’t think i have ever seen the teepee.
It was on the far side of Tom Sawyer’s island. It was the friendly Native American Village.
1783647884172.jpegIt was fog blown into a chimney. I added heating elements in the chimney to heat the air/fog mixture. That made the fog rise like smoke. I also designed a dampener that would puff the fog.
This was in the early 90’s. I redesigned the burning cabin and upgraded the rapids for the canoe ride.
The village was removed for Star Wars land.
Glycerin and carbon tet make great fake smoke.
It does but we were moving away from that for health reasons. Also glycerin is a consumable that needs to be purchased.
I might still use it in small limited live venues but I wouldn’t for day to day.
Fog / smoke gags was one of my specialties.
L
LeonardY
Southern California
I took my security cameras down. They were NightOwl brand and didn't record well. I replaced the hard drive a couple times. The recorded images looked like what you see on the news. Just a blurry image. I mean you could tell it was a car. That was about it.
My brother gave me all the Blink cameras we had bought for my parents house.
There is a brand new doorbell camera. My only problem is my doorbell is on the side wall. I considered just abandoning the location and putting the doorbell camera on the door trim. Then I would have to use batteries and it wouldn't ring the bell. At least without having to installing another relay gizmo.
I designed a mounting bracket and cover for it.
First version.
But after letting it fester for a while. I redesigned it to this.
First print. Seeing how it looks.
I was happy with the initial print but I made the hole in the bezel too small. After examining it. I found there was no way I would be able to snap the camera in place.
I redesigned the bracket into two pieces. Separating the faceplate from the bracket.
Spent two days hunting down my heat inserts.
Need to paint it to match the siding.
This might have gotten done sooner but my printer was down. I was going through the process of trouble shooting with Qidi. I found you can't jump ahead and tell them what's wrong. You have to let them come to that conclusion for themselves. Once they did. They shipped me a new hot end right away.
L
LeonardY
Southern California
More haphazard posting of life.
My unplanned renovation has me pretty much paralyzed. I start off strong every morning. Lots of chores get done. Mowing, weeding, cleaning and the like. By noon I slow down to a crawl. Projects drag and I am easily distracted.
Today, I made some progress. Didn't take pictures of all the details but here it is. I usually plan out things to the nth degree but lately been just winging it. I was well known at work for this. But I always hated working like that.
It actually starts back several years ago when I bought a TV that was larger than the Media niche. I took the TV down to re-wire the network to CAT6. I've actually have a plan but I'm not convinced of it yet. The cables are run and I need time to do a little exploring.
I removed all the plywood cabinets from the niche.
I had for some stupid reason removed most of the texture. I primed and re-textured the niche.
I remounted the TV with the frame I had designed years ago.
The right side is hinged, I can swing the TV out to get at the stuff behind. Like you guys. I work alone a lot. Although my buddy came over to lift the TV in place.
Thanks for following along.
rharman
SoCal
< snip >
< /snip >
Gotta love the 3rd Hands. I have the tall and shorts. Not needed often but, when you do, they're a godsend.
BTW.... Looks to me like the left side is hinged, correct?
L
LeonardY
Southern California
I've been back home for a week. All the things I thought about while I was away, I barely have touched.
Yesterday, I moved half of the **** out of my studio back upstairs. I decided that I wouldn't just pile them into the closets. I needed to go through and get rid of stuff. It's going in one room and I will sort it in there. The downstairs will be clean and tidy.
The yard needs some work. The temps have been consistently 98 to 105 (36 to 40). I can't work long out in the heat or I should say I don't want to.
I have been sitting in front of the computer.
Update on the X-Wing. Finished cleaning up the wings.
The afterburner.
L
LeonardY
Southern California
I think I've reached my saturation point.
Things are getting done. Just not as fast as I would like.
So what to do? Add another project on.
I sculpted this some time ago for a school of fish chandelier. It printed OK on my old Qidi X-Max. I decided to do a test last night on the new printer.
Turned out so much better.
Added bonus. Backlit the supports look like scales.
Here's the idea.
L
LeonardY
Southern California
I've done a little gardening. Tried out the new Dewalt chain pole saw. Trimmed one tree. Worked well.
Transplanted the tomatoes. Also the peperone but didn't get a picture of them.
The garden is waning. Here's the last harvest.
Transplanted the wasabi. They are finicky plants. I'm hoping the new pots with the watering from the bottom will help.
I pulled the cabinets out of the media niche and decided to make a roll around bench from them. The shop grade plywood is so much better than the new shop plywood I just bought.
Removed the drawer slides and added locking casters.
Cut off four inches off the width.
I haven't done any more to it because of the heat.
