What's the one garage upgrade you wish you'd done sooner?
Fav Onefour
MN cold and hot
Power.
I ran a couple extra 20A circuits twenty years ago before I insulated and "finished" the space. If I had it to do over, I'd have put a big sub panel in the garage. My power is tapped out and it's affecting tool decisions. I walked away from a really good deal on compressor yesterday because I'd need to add power.
I'm super glad that I did the work upfront on lighting, insulation, and heating. The space is comfortable and easy to use. That's why I'm running out of power. It's too easy to work on projects so I keep adding good tools. :giggle:
Hohn
Diesel Central, Indiana
Garage was already drywalled and insulated when we moved in.
Probably need a minisplit, it’s crazy hot in summer.
Biggest updates to date have been shop air piping and a nema 6-50. There’s only so much you can do in town on a small quarter acre with a 3 car attached garage.
Superbowl
DC area
1. Dehumidifier. I have lots of machine tools and now they don't rust. I also learned not to open the overhead door when cool inside and warmer and humid outside.
2. Cable TV
Hohn
Air conditioning.
I'd Iike to do a mini split but I'm hoping not to be here long enough to realize the investment. However, I do have window unit.
I have a side door that I NEVER use (it was behind shelving for 15 year and only recently surfaced) and now you have me thinking that replacing that glass and mounting a window A/C unit would be a good idea.
Side door is a missed opportunity.
Heck, maybe I should start by opening it and getting some cross ventilation.
kwb
PNW
Power was a big one for me. I was severely limited on budget (so I thought) and put in the conduit but not the wire to the house. Ran a single 12ga/20A outlet for a couple years. Bought the feeder wire for ~$500. After not having cords everywhere and lighting that was useful the $$$ was a mere pittance.
Forklift all day. I put in a Jib crane which is handy at times but the forklift is so much more useful. About the only time I use the Jib is to get something in the back of the truck when I have too much stuff in the way to use the forklift to do it.
Locke96
Orange, Texas
For everyone that says a mini split or AC, how big is your space and what's a rough estimate it costs per month during summer to run it? Do you turn it on in the morning and run it down to as cool as the house is, or leave it on 24/7 and maybe only set it at something like 80 degrees?
Jgaz
I’m going to try to answer your questions but my use of my mini split may not be typical.
My garage is two bays deep on one side and a single bay deep on the other.
The shop bay shown in the above picture is a bit more than 16 feet deep and 11.5 feet wide.
The two bay area where the vehicles are parked is 20 x20 feet.
Not ideal, but typical for an Arizona builder.
Garage has a 10.5 foot ceiling height throughout the space.
Again, typical of an AZ builder, there was no insulation in the garage walls or ceiling.
House was a spec. so I had no choice with the builders stupid decisions.
I cut an access hatch in the ceiling and had a contractor blow in a **** ton of cellulose insulation.
I insulated the garage door using rigid foam panels and a radiant barrier.
You can see the mini split on the LH wall directly across from my woodworking bench
I use the mini split more like the swamp cooler in my previous AZ house than the use your questions asked about.
The A/C is turned on when I work in the shop bay. It is turned on when I start and turned off when I’m done working. I usually leave it run when I break for lunch.
Note: The garage metal surfaces heat soak to just over 100* during times A/C isn’t used.
Welcome to Phoenix!
Temp set is at 80*, blower speed from 75 to 100% during use
The fact that the unit blows right into the main area where I’m working makes it very comfortable compared to working in the area during an AZ summer of 110*
The fan on the back wall is key. I aim it at the area where I’m working.
For example, I’ll pivot it to the left if I have a lot to do at the drill press or table saw.
The cross wind makes a noticeable difference.
Given the size of the garage and the lack of wall insulation the mini split helps but certainly doesn’t cool the area where vehicles are parked to the same temp as the shop bay.
If I’m under the hood I may add a box fan on the metal bench or table saw table.
Again, maybe unique for the way I work. Not perfect but better than no A/C.
I do miss having the garage door open but……
I really can’t answer about the increased cost. It’s not much.
The average daytime temps outside make more difference in my monthly bill than the A/C costs.
Maybe not the ideal set up, but it allows me to work well into the afternoon during the hottest months of the year.
I built 6 pull out shelves last July. No way would I have started that project at that time of year before installing the mini split.
Hope this helps.
Skellyii
KC Area
Mini-split in an attached garage, 1000sqft 12ft ceilings, insulated. 3 garage doors are south facing with no trees.
It's on 24/7 365. If I'm not working that day, set to 82 during the summer, and FP mode during the winter.
Averages around $25-30/month
aggie113
San Antonio, TX
Since I still haven't done it, water. Plan is to put small room above part of the garage (18ft to rafters) with a bathroom and then a shop sink on the main floor. Will have to connect to house's septic.
