Champion 80 gallon Restomod has begun
H
Hohn
Diesel Central, Indiana
Here are some estimates of the improved compressor performance by running at constant power and then derating as pressure rises.
Let's assume we never load the motor more than Champion does, and we'll tie the output to the motor load at 17.2 SCFM at 175psi.
And if we discover that Champion is significantly under loading the motor against FLA and we can run it 10% harder?
The VFD lets us run the pump as fast as the 7.5hp models and deliver similar (or more) flow--but as pressure rises, we can no longer sustain that flow within motor load limits. It's possible, however, that the existing system margins will allow 7.5hp flow rates up to usefully high line pressures-- enough to sustain a blast cabinet or similar as if it was actually a 7.5hp compressor.
The derate for motor protection comes in only above pressures that are already sufficient for almost all the tools I use.
A VFD cannot turn a 5hp compressor into a 7.5hp compressor. But it can probably make enough of a difference in your actual working pressure range that it's nearly a 7.5hp compressor in performance.
Which I think is pretty cool.
H
Hohn
Sounds good. I feel since you're going that far, a cheap 12v rad fan controlled by the VFD to cool everything for x amount of time once the motor stops would be a cool addition...
Literally.
I'm thinking of a couple related enhancements like having an air mover blowing on the motor/pump since the air flow of the existing flywheel and ODP motor is rather pathetic.
THis would also decouple the cooling function from the work of the compressor. I like the idea that the compressor doesn't have to pull power to earn a little cooling. Seems counterproductive in some ways.
H
Hohn
Another tweak I'm thinking about doing is a remote air intake. This would remove the air inlet from a lot of the compressor heat and improve volumetric efficiency slightly while also letting me enclose the air filter in a sound deadening box. If you look at how the Eaton "Silent air" units are configured it's nothing special-- use a long hose to draw air from a sound-deadened box
H
Hohn
And now we have a backup/aux pump. Locally seller had an R15 that was very long in tooth and badly in need of some attention. But for just over $100, I couldn’t resist.
I’m thinking a basemount conversion or perhaps an unconventional vertical base mount (think appliance dolly air compressor with a 6-50 plug).
Unlike the R15 that came on the titular compressor that is the subject of this thread, this guy seems to be quite a bit older and much worse off. She’s going to get the full disassembly and rebuild, I think.
finn
The UP, God's country
That’s got the round fins around the barrel, so that confirms it’s an oldie. My R15 has those same round fins and was built in 1970 or 71, per the tank date code. Mine is “numbers matching”, ie the S/N is stamped on the pump and tank tag.
I think there’s a S/n range to build year list somewhere on the web, if you’re interested.
H
Hohn
Can you highlight the area you are discussing?
I can’t see the difference between this old one and the replacement part:
My other R15 on the other compressor was made in 2002 and seems the same?
finn
Well, now I’m confused. I’m getting my information from three sources: Threads on the Practical Machinist forum; Threads from here on The Garage Journal; and my somewhat fallible memory from when I was trying to figure out exactly what compressor I bought (a Champion R15.
They came in 3 versions, R15, R15A, and R15B. Mine is an R15.
As to the differences, it’s largely valves, access to the rod bearings, number of rings, intake manifold design, and some I can’t remember.
The cylinder cooling fins went from rounded to squarish, and back to roundish, according to one post.
I’m not an expert, though.
I distinctly recall looking up the build era on mine in
some Champion service publication. I didn’t copy the link at the time though.
AI says it can identify yours given the S/N and date on the tank. My tank and pump S/N match.
H
Hohn
Thanks to an acquaintance who was at Champion since the early 1970s, I was able to get this information, which should finally clear up the confusion:
Over the years there have been a number of changes and updates to the design including the cylinder block casting.
First, the original 1966 models did use the rounded fin cylinder casting as on the example you have dating to the late 1960s.
In 1978 the cylinder was revised, going to the square-fin profile as in the R15 picture you found. Coinciding with that change were the addition of an Interstage Safety Valve on the 2nd stage Intake manifold (R15 models; the R30 already had this), and the original steel intake filter was replaced by a Plastic Filter as shown also in the photo. Part # Z828 Filter Assembly is still available today, and would fit the manifolds on your old R30.
In more recent years the cylinder was revised again to incorporate a change in high pressure intake Valve diameter along with new manifold and gaskets. The cylinder fin design was also returned to the rounded profile, which I believe was for appearance reasons as well as possibly better cooling air flow.
Hope this answers your questions but please let me know if more information is needed.
So yes, the rounded fin R15 is both the latest AND the older model. The square fin models are post-1978 to apparently early 2000s or late 1990s (year uncertain).
R15 gen 1Round Fin>1966
R15 gen 2Square Fin>1978
R15 Gen 3Round Fin Uncertain inception; late 1990s likely
finn
Good detective work!
H
Hohn
Made a bit of progress tearing into the “old” R15 pump today. Not sure, but for now I’m saying it dates to the late 60s since that’s what the seller told me. It jives with Champion’s guidance also.
Anyway, the good news is that despite the absolutely horrid abuse this poor pump had over nearly 60 years, it’s actually in perfectly salvageable condition. Popping off the cylinder housing I was greeted with pistons that had about 1/4” of rust dust and oil cake crammed on top. The valves in the head were all in very sad shape. I’m not going to try to salvage them, I’ll just replace them.
The pic below makes the pistons look worse than they are. I’m going to leave them as is and just swap rings. There’s very little play at all, bearings feel perfect so I’m going to follow the golden rule of machinery and not touch something that’s perfectly fine.
The bores look OK. The crosshatch is polished out but there’s the tiniest step at the top reversal (barely 0.005” I’d reckon based on not catching a fingernail edge) and the bottom reversal has no perceptible step at all.
A 180 grit Flex Hone job should easily salvage the cylinder.
finn
Check the side clearance in the ring groove to make sure it’s in spec.
Worn grooves will result in broken rings in short order.
H
Hohn
I’ll check, but there’s almost no play at all.
If it’s bad, this whole pump is basically scrap because a pair of pistons is $600.
