Show your new tool arrivals
NitroExpress
Texas
You enabling son of a *****. 🤣 I just made another CAT tools order, but skipped the ratchets.
How are these?
I’m a fan of the Stahlwille ratchets. They are the main reason in going through the hassle of sorting through the Cat catalog and order process. Definitely an improvement over the low tooth Williams on offer at Cat.
NitroExpress
Texas
I’d love to have a private dinner with whomever decided that at CAT, and ask what lead to this. And the Stahlwille ratchets dressed up CAT style look sharp! Hope they serve you well & you’re happy with them!
Kind regards,
Olli
I’m GUESSING that Snap On won’t sell high-tooth count ratchets to Cat and the technicians at Cat are probably looking for more than 36 teeth, being it’s 2026 and all…
d.mcfarland
Western PA
Snap-On won't private label their best selling offerings to a lower priced seller. Every dealer in the country to instantly have a class action lawsuit.
I'd guess they don't mind the yellow handle pliers because 1) they are still wholesaling at the same essential price and 2) not like yellow seems to be a best seller in the automotive world anyways and also 3) the warranty doesn't come out of their pocket.
lund
I’m an electrician and this is mainly for anchors with 1/2” holes. It is not a one size fits all solution nor meant to be. The collection capacity is greater than the universal one I already have that fits via the side handle. This will be just fine to get me through a day of running pipe.
The capacity on this is about the same as every manufacturer’s integrated solution I have seen. Most of those being Hilti.
I also have a 5 gallon rigid vac with a bag in it and a hepa filter. That uses a device that suctions to the wall when holes get bigger and stuff gets serious. This I mainly use for SDS core bits.
There is no such thing as dry grinding masonry on a commercial construction site anymore. Residential is the Wild West and they will be lucky to even have a guard on the grinder.
It makes sense on what you say. Use context always matters. I was hammer drilling many deep holes (100s around 5/8" diameter) to epoxy threaded rod in old concrete in retrofit projects. That generates a large volume of concrete dust (airborne in a fine suspended powder) and non-aresolized powder both in the drilling and subsequent hole clean out (whether vacuum collector on the drill or not, a lot will brush and vacuum out the hole). Anything to cut it down is good. Even cleaning out shop vacs post drilling is a chore and a good HEPA filter is needed. The dust gets everywhere ... somewhat like in drywall compound sanding: no matter what you do in the chain things seem to get dusty.
It is good that commercial construction is now more careful on dust exposure. It is easy to see where long term exposure is bad for ones health. Tradesmen should do the best they can and should certainly never smoke since that can compound potential health problems from inevitable exposure. Wet grinding concrete is definitely the way to go. Wet core drilling is the norm. But to my knowledge, hammer drill holes in concrete seem to be more commonly done dry. SDS is a clear winner for hammer drilling anything more than a very small hole in old and very hard concrete.
oled
Denmark
Knipex Alligator 300mm (12") with plastic grips 88 01 300
... I quickly appreciated some advantages of this design
I prefer the Alligator also, and own several sizes of those, and an NWS with a similar design. On top of the things you mentioned, I feel like its mechanism is less affected by dirt. It just works. It's simpler. The Cobra has some small parts and fine tooth stuff that needs to be clean to work.
oled
Denmark
I wanted a sanding attachment for my Multimaster, but ended up ordering this set instead, as it was on sale (or some kind of Fein campaign, as the box actually has printed "- 50%" on it).
It takes up way too much space in that L-boxx, but maybe I can use the box for something else. All this stuff is going in my drawer with blades etc.
Dankotaru
7000' ASL
Picked up some NOS Klein Scissors at the swap meet for $10. I can't pass up USA made Klein tools when I see them cheap.
That's a killer deal. I've used these on so many different projects around the house, cutting everything from cable to artificial turf. Love these scissors, they're fantastic. (y)
L.Cheapo
Chinese wire wheels scare me to death. I imagine forgetting safety glasses at a key moment or picking porcupine quill-like wires out of my body. I try to find USA, European, or Japanese products and run them well below rated rpms.
I had a cheap wire brush explode on me many years ago when I worked in a shop. I looked like I pissed off a porcupine. Bristles were stuck in my clothes, my arm, and my face. Fortunately I wore safety goggles or I'd probably be half blind. One entered my face just below the goggles. Had a no-name cutoff wheel explode back then too. Took a chunk to the cheek.
I only buy USA made wire wheels and abrasives. I'd venture into Japan or certain parts of Europe if I absolutely had to.
lund
Edited since I made a bad mistake on the rpm and diameter scaling (Sorry -- I worked in my head and then wrote the conclusion in reverse -- duh!) This version is fixed.
Some tips to reduce concerns:
* Use good quality wire wheels and discard them after a significant number of hours or they show sign of deterioration (hard for cheapo me to do). A wire breaking off can be a sign that a lot more are ready to break.
* Of course always wear protection, especially for eyes, with wire wheels. Goggles or a full face shield are best. A heavy leather apron also helps. Plus leather gloves.
* Use them on relatively low rpm buffers or grinders with smaller diameter wheels. Yes, this means the work takes longer. But it is way safer. The centrifugal force acting of the wire is proportional to d x (rpm)^2 where d is the diameter of the wheel and rpm is the rotations per minute of the wheel. So larger wheel diameter linearly increases the force. But the force increases with the square (rpm x rpm) of the wheel rotations per minute. So wheels generate much more wire stress quickly as rpm increases. A smaller diameter wheel on lower rpm has dramatically less wire stress translating to dramatically more safety margin. Go lower rpm with smaller wheels and live with slower progress.
Stand a bit to the side of the wheel in case something breaks or the wheel snags a work piece and throws it (another danger).
If you do these the likelihood of a bad mishap is greatly decreased and you can use the wheels with much less stress. Handheld wire wheels on angle grinders probably need even more care in use.
Hope this helps.
Squankum
Southeast
I bought a De Walt nozzle schnozzle. Had it on my wishlist for a few years. Thought it was a just a floppy hose, I was wrong. You can set a curve to it and it holds it, which is neat.
Something screws in here. Uh.... just went and looked and their short hand-sized blow gun (which I don't have) comes with various options to screw in such a hole. For what I'm doing with it first, I think I can do without, just happy to have the wind. Long term, I should figure it out. My set of CAPRI blow gun screw-in tips are of a much smaller thread.
Oh wait, it does come with one venturi tip:
$25.99 Amazon. COO China.
mreisner
North of Detroit
I picked up this old Snap-on Top box and Blue Point cart last weekend for cheap. The top box I'm going to just clean it up as it has some really cool decals on it and the inside of it is in great shape other than I need to come up with a key as that was missing. The cart was mechanically in great shape but look pretty rough and the Chrome had some surface rust. I took it apart and remove all the decals soaked the Chrome in evapor Rust and then hit it with some tin foil and it cleaned up pretty well. I went to remove the adhesive from the decals with brake clean and since it's now acetone based it dissolved some of the paint. I didn't want to totally strip it so I tried a couple of different things and surprisingly the best thing was jdtco cordless tool detailer and a Scotch Brite. It removed the adhesive and any of the grease was not brutal on my hands and only took off the oxidized paint. I hosed it off and then hit it real light with some mineral spirits and then rattle can magic! Rustoleum Sunrise red is really close to Snap on toolbox red and a hell of a lot cheaper. Really hot and humid the last couple of days so I I didn't want to mess around getting a pint mixed up and putting it on with a paint gun so I figured I'd give the spray cans a shot and I am very happy with it. Inside the cart and on a lot of the surfaces it was red but had faded to Orange over the years.Screenshot_20260709_194818_Gallery.jpg20260709_194640.jpg
Squankum
Southeast
Upcoming tile project. Part of it includes cutting some 3/4" thick 2'x2' porcelain pavers so I'm also planning on upgrading the blade that comes with the saw to a Pearl P4 diamond mesh blade.
Subaru or Honda? Love the Ko-ken sticker. Now it needs an NGK sticker. Or Nippondenso, whichever one is your bag, baby.
930dreamer
Amarillo,TX and Stinnett,TX
Used Dayton 42" fan. Grainger price $1166 new, seller had three of these $400 each.
KnurledNut
n/a
I've wondered if that will change now that Cynergy is top class.
The Cat yellow plier color is proprietary. You won’t find that available from Snap-on.
If its not too late, I would return that and consider a better saw. My motor died on the first job. Also had problems with the water pump. And the build quality was less than ideal. Quite disappointed considering the price is not cheap.
CHI_Tool&Die
Chicago, IL
Word is that Snappy really took it on the chin from their franchises over the internet meme status of CAT tools. I was talking to a DM and he said that something had to be done by corporate before there was an open revolt. Williams can get away with it because they are a subsidiary and they have limited market exposure outside of industrial suppliers. It wouldn’t surprise me if CAT eventually has a new source for pliers and sockets.
Beerhippie
Far NE Oregon
Thanks to Timm for posting about the Can Gun 1.
I hope they work as well for you as they have for me!
After painting the rockers on both sides of The Brick, mine's still working fine. Not only does it take a LOT of strain off my fingers, it keeps my fingers paint-free without having to wear gloves.
It takes a bit of practice to get the feel of when it's depressing the sprayer valve of the can.
Skyman
Central Maryland
I'm looking forward to giving it a try, Timm. It'll be a little while, because I have other tasks stacked up before I anticipate any rattle-can painting, but I'll get to it one of these days.
lund
I bought one of these also to spray a coating on the bottom of my two vehicles (CRC 06026 Heavy Duty Corrosion Inhibitor -- which works great by the way to slow down corrosion in the rust belt) and I could only (easily) buy in small rattle cans. My finger would go numb using up a few cans worth per car. That made the painting hard. These work well for the task. It allows me to concentrate on painting rather than on my finger falling off!
gilbo
I guess this can be used on large fasteners, but I’ve only used this on small stripped out screws on an electronic enclosure so far. Not really sure how often that the need for this type of hand impact will come up and I have other options for this, which are bulkier though. What’s I found impressive was the bit. It’s a PH2.
Vessel has this style bit for other fasteners, but they have been difficult to source. This video shows them.
VESSEL in the house!!!
Huge fan of Vessel. I snag when they are super cheap on Amazon JP.
Lesserstore
Texas
Went to Walmart and Lowe's today for some odds and ends and these followed along with me:
Hyper Tough 6 in 1 screwdriver, made by Great Neck. It says Made in USA on the package, but it probably should be Assembled in USA because the bits definitely look like Asian imports.
Hyper Tough USA Yardstick, made by Mayes Level div. of Great Neck.
Since SBD is shutting down US production of tape measures I picked this up at Lowe's.
I was looking for the Wilde Hyper Tough pliers but my store doesn't have them nor does Walmart's website.
Mike S.
Charlotte, NC
The sale price, inconvenient magnetic locations, and aluminum hoods convinced me to purchase this light bar.
I like the Icon light a lot, but I wish the lights had replaceable li-ion batteries. It ***** when they die and then you have no light until they're charged up again.
I guess you're supposed to keep spare lights handy to use while the others charge... or work faster and get everything done before they run out of juice.
Kurt4440
Western New York
Everytime I finish up working in the garage I charge batteries, headlamps, and work lights.
These are currently in my Amazon cart as a backup pair of lights.
Squankum
Southeast
I found the Wildes (labeled only as Hyper Tough) not on the tool aisle, but on an end cap kinda in that area, just the other day. And not on the end of the end cap but the side of the end cap.
