Tools of Japan
nicks78camaro
Pittsburgh, PA
Moving into long items and Koken stuff. All the red Koken boxes are for pulling studs or installing studs. Interesting to me is all the latches on the boxes are different. Does that matter? No, but just a little random detail thing, yes. Also the Koken ratchet is my first from them. I understand why they get so much praise. Its very smooth! Like I wish I hadn't bought it because the evil thought of have at least one in all the sizes has entered my mind. The only thing that surprised me is I find the handle small and this is coming from someone that wears a medium glove. I prefer the Tone oval handle. Speaking of handles the knurled handle on the Koken breaker bar does get a thumbs up from me. I choose that one because if I am using a 1/2" breaker bar I don't want it slipping in my hands.
Next up is items from Koto and Hasco. Both brands I've not seen much or anything about. The puller is a pilot bearing puller. The bottom pliers are for C-clips for drum brakes. The top pliers are for electrical connectors but the jaws can be adjusted. From what I can tell is Hasco is more for semi-trucks and box trucks and not passanager vehicles for the most part.
I did the dangerous thing of seeing if I could get physical catalogs, and succeeded for some of the brands. Sometimes I just like a classic catalog. I also learned KTC makes a small selection of dental tools. Who knew!
Last, but not least is I think I found Toyota branded Koken sockets. I have heard Toyota is starting to switch over to them for some of their tools.
Where'd you find the toyota sockets?
autobon7
Have some upcoming automotive work coming up, so no better reason to order tools! Also Japanese tools for Japanese trucks just seems correct. By one of the photos I suspect you'll know what brand I am working on.
First up is items from KTC. The black pry bars are brake adjusters. The little spring clamp looking pieces actually clamp onto the door switch that controls the overhead light. Lastly the blue brush is just for cleaning up afterwards. I like having one by the project sink.
Next up are 3 different kits from Tone. I've been wanting to try out a ratcheting screwdriver. The little black kit will live in a truck for swapping batteries. Lastly, the 1/4" hex drive was a bit of "I know I don't need this, but until I purchase it I will feel a void in my life that only this tool set will fill". Sometimes you just need a fun tool and they call that color of case raspberry which adds to the fun factor. You can also get the get in a black case.
Most of this stuff is all stuff that I have seen before in this thread. I am looking forward to trying out the Eight Tool L-Keys. I am very happy with my Wiha L-key set, but those live in a dedicated travel kit. These will be more for bench work, and yes the SAE and metric have a similar "Magic Ring" to the Wiha. Also the auto punches are much more comfortable in the hand than what is readily available state side. Lastly, the narrow needle nose pliers are a second pair because I find that I use them enough to justify.
Do you have the part numbers for the raspberry Tone set as well as the bigger ratcheting set? Not finding them
4xdog
Santa Fe, NM
Discussed by @Bad Mojo upthread in post #12468.
