Funny 1 star Amazon tool reviews
whateg01
doo dah, kansas, usa
I really enjoy 1 star Amazon reviews. They're just oh so good. I'm making this thread to share the good ones I come across.
This genius is using USA made cable cutters to cut steel cable. ☠️ COMEDY
I still don't know why this is so funny. Unless the description says specifically 'not for use on steel cable', why would somebody just instinctively know that? A lot of people don't even understand that not all metal is the same.
whateg01
One time at Autozone I sold a breaker bar and a 30mm socket. The guy went outside, stuck it on his CV axle nut, jumped on it and snapped the breaker bar. Then brought it back inside and got his money back.
I would get my money back too if the breaker bar can't handle that. It would hate seeing a cheater pipe coming its way!
Sparky Six Axis
If you look up images of "cable cutters" and "wire rope cutters" you'll see the difference. Cable cutters are big. You can cut 500 kcmil copper with them. But wire rope cutters are small. Very different tools.
You must not live in the rust belt. You can't just use a breaker bar and a pipe. You need to use heat and PB Blaster on every single screw, nut, etc. Even with that chances are youll need a grinder.
whateg01
Again, why would the average Joe know that? For that matter, I bet the average Joe has not even heard the term wire rope. It's all cable to him.
I dunno. Is Kansas in the rust belt? My f150 thinks so. Still doesn't change the fact that a breaker bar the snaps when you stand on it is pretty useless.
Sparky Six Axis
In Illinois we break breaker bars. Impact tools are the way to go but 50 gallon compressors cost a ton.
I'm glad I make enough money now that I can pay someone to work on my stuff. I don't miss crawling under a truck and getting rust in my eyes.
rust in the eye
Chicagoland
By the time I got to Don's (d42jeep) "Secret Santa" package a couple years ago, I'd already gotten all the other stuff all packed up and ready to go, and I had depleted my "packing material" down to almost nothing.
I went out and tipped over my recycle bin and picked all the plastic bags out of it and used those for packing material. (That was the box that had the big Kennedy cantilevered box in it.
I've had to resort to that in a couple other instances as well. I believe that @Caleb T's "Secret Santa" package had its share of plastic bags jammed into it as well.
Packed is packed.
Having to pull, pick, and peel tape off of tools you've purchased online is a pain in the ***.
Proper packaging method described above. (post #28)
Was it you?:ROFLMAO:
WTF, I didn't mummify them.
dlwilson
West Palm Beach, FL
Bought a $40.00 harbor freight battery load tester.
Directions say “Will smoke on first use” burning off manufacturing stuff.
one star review said” junk smoked the first time I hooked it up”!,
im probably in the minority,even if I know how to use something I read through the literature that comes with new stuff.
I bought that tester. I don't usually read the directions, but I did that time, and was really glad I did when the tester started smoking the first time I used it.
Bubba Fett
Eastern NC
Go look at the reviews for the Klein 11 in 1 screwdriver (32500).
People complain because they can't figure out how to access the other bits, or are mad because it doesn't take standard 1" inset bits. How hard it is to read the directions...or you-tube it?
OccupantRJ
Eastern North Carolina
He wouldn't.
Expecting "average Joe" to know the difference is delusional.
Feel free to tell me I'm stupid, but I had no clue.
I have been doing mechanical work for 60 years and had to look up the difference because I wanted to know. I saw that cable seems to be more flexible and normally used for controls, and 3/8” or below. Wire rope was larger and for more structural uses. Yet with that info I have never heard the term used as a wire rope suspension bridge. It has always been described as a cable-stay suspension bridge.
I live half a mile from a cable suspension bridge - the Narrows.
My 10-speed had "cables" which controlled both the derailleur and the brake calipers. In all my years of cycling and repairing bicycles, I never once heard the term "wire rope".
Only in old literature concerning the John A. Roebling Co. have I seen the term "wire rope" used.
So... I need to "trim" the "cables" on the brake mechanism on my mother's walker. Which tool do I use for that task?
Sparky Six Axis
You should use a cable cutter to cut cables. But don't use a cable cutter to cut cables. Rookie mistake. /thread
OccupantRJ
When I have a ”cable” to cut I tightly wrap tape on each side of the cut, then use a thin blade on an angle grinder to reduce fraying. On construction jobs for temporary cable hand rails or fall prevention the ironworkers cut it with a torch for speed and to prevent fraying.
In my decades of riding bikes with cables, I quickly learned that a household wire end cutter or diagonals just made a mess of them, fraying them badly. We used to just wind up the excess cable, to avoid the splayed ends that happened so quickly. Eventually someone found a pair of something like the Park tool shown above, and life was better, til he moved away.
Beerhippie
Far NE Oregon
I used to solder a section of the cable--a half-inch or so--then use a Dremel cut-off wheel to cut in the middle of the tinned section. No frays, no "pigtail" and an end that can still pass through the housing.
Beerhippie
Far NE Oregon
And rigging.
To further muddy the waters what is clearly wire rope is used on aircraft carrier decks to catch the landing planes but is called an arresting cable.
To continue to muddy the waters, in traditional nautical speak, a cable is generally a large line--regardless what it's made of. Line sizes were measured in circumference, just make things even more confusing. A 6" cable would be closer to 2" dia.
neophyte
Pennsylvannia
Clearly defective linemen pliars
I was confused the first time I bough Linesman pliers, and saw the gap.
I checked different brands at a hardware store, and realized the gap was standard.
It probably wouldn’t hurt if tool manufacturer literature or packaging actually explained that this was standard. ( “1/16” gap in jaws as is standard on Linesman pliers” or some similar statement).
Felco cable cutters actually come with instructions on how to properly apply pressure on the cutters so the user doesn’t hurt themselves.
neophyte
Pennsylvannia
I think they have been that way for a while.... :unsure:
Yes, they have, I just had no formal training in wiring, where I was taught about the gap, so I just thought of “Linesman pliers” as extra long “Combination Pliers”.
It was only after I ordered a pair, and saw the gap, and wondered “WTF” and then looked at others at a hardware store, that I realized that the gap was normal and intended, rather than crappy manufacturing.
Regular “Combination Pliers” which are also sold as “Linesman Pliers” don’t usually have the gap, so the gap can be confusing to those unfamiliar with the patterns that do have the gap.
I’m actually uncertain how many different types of “Linesman Pliers” actually have the gap, since there are a number of different types, and the gap is usually found on the “New England” style.
neophyte
Pennsylvannia
“Wire Rope” is a standard term that goes back at least 150 years or longer, and which is still used.
“Guy Strand” is another term used for similar products, although possibly not identical “Steel Cable”.
Similarly “Guy Wire”, and combinations of the above terms.
Also, “Steel Cable”, “Iron Cable”, etc.
All refer to multi-strand high tensile cable, usually made from steel or iron alloys.
“Wire Rope” usually has finer wires, which would likely require closer tolerances, and sharper jaw edges to cut cleanly, and this may be why some cutters specifically use one or another terminology in their names.
Felco uses the term “Wire Rope” for their hard cable cutters.
I only found out that hard cable cutters existed while in a university shop, because despite the shop routinely being cheap, they bought a pair of Felco C7 cutters for cutting small stainless cable that was being used for something.
This was a few decades ago, and at the time, hard Cable Cutters seemed to be a niche thing only found at actual industrial suppliers, and there weren’t many brands available, and the Felco version was superior to the two separate versions HK Porter sold that were both made in Japan.
