Below 265 SQ/FT DRIVESITFAR IS GETTING ORGANIZED in his 9x15 portion of 2 car garage. DIY’s & COOL VI
All workspaces below 265 squarefeet.
D
drivesitfar
I spent most of the day yesterday learning how to do folded corners with Timbertech. Getting the saw depth figured out, then angle and the pvc glue and activator has a learning curve that is for certain.
Since my technique isn’t exact yet we’ll see how everything looks once installed. I still need to trim everything so there is a continuous gap line coming down the steps sort of like a waterfall but it’s progress.
Have a grand day all while I get a haircut and start looking for some good deck furniture. IMG_1256.jpegIMG_1255.jpegIMG_1257.jpegIMG_1258.jpeg
D
drivesitfar
Making this corner waterfall look happen sure has a lot of moving parts so marking cutting and screwing in each step is just hoping after I cut each piece it looks ok (and that my bride approves). I’m looking forward to getting it done.
My ears are officially lowered for summer now and after our shopping experience I might need to start a go fund me page for new quality deck furniture. Or maybe learn how to build furniture is the other option.
Anybody want to comment on sunbrella fabric or their favorite table and chairs for outside eating furniture please do.
It’s sunny in the PNW so my day is great snd hope yours is grand tooIMG_1259.jpeg
D
drivesitfar
Another day and some more progress. I won’t be doing this for a living that is for certain but the steps are coming along nicely. I cut and installed the corner pieces (we are calling it a waterfall) and finished cutting and installing one side of a step.
Hopefully I’ll have both steps installed tomorrow.
D
drivesitfar
Ollie: thanks for the good words and glad you like how my deck is looking. This deck project is taking more than a little time and working with my bride as my only helper (except her BBF for a few days screwing in blocking and deck boards) it really is coming together. Also living through this with your other half really has further improved our relationship too. Keep checking in cause we should be done soon but lots of projects on the to do list.
Jon: thank you!!
Jay: I’ve never been a big fan of stringers so one of my contractor friends almost 40 years ago no helped me build 3 similar steps out of treated wood and we decided 2 steps was plenty now that we don’t have 5 kids using it daily. There’s a ton of moving parts but my bride has great ideas and a good eye and my OCD and attempts at perfection might have our deck looking good. Thanks for posting a few good words cause you’ve always been positive so keep it up!!
P: thanks and at least I still have all my fingers cause I think I’ve used more than a few of my cutting tools on this deck rehab. I have to give a big shout out to my bride for always pushing me to do what looks best and to all the guys on YouTube that took the time to post some great ideas and how to do it.
52: thank you and it’s mostly my bride that has me doing this when I kinda mention a video or picture looks great and then scratching my balding head more than a few times trying to figure out how to make it happen. Thanks for stopping in.
All: with all the moving parts having the right side of the steps framing not quite level (in the bubble but to the edge of one side) it created some pretty interesting discussions. I was close to taking it somewhat apart and rebuilding it then thought maybe I could fix it with a few shims under the decking. We picked up a 300 pack of plastic shims from 1/32 to 1/4 so I screwed in a few onto the framing and we both are pretty happy with the result.
When working somewhat slow at my 70 year old pace and having my OCD and my bride notice when things are off 1/32 or a 1/16th is interesting but in the end I hope it will last us another 20+ years or until we sell or hopefully go to a finished golden deck elsewhere.
Today steps should be finished and the upper deck will get boards on it.
Have a grand day everyone
D
drivesitfar
The steps are finally finished and the top deck has started to look like a real deck again.
When I installed this 12 inch trim piece on the side of the steps a couple days ago I knew I should have trimmed it an 1/8 to allow for it being an 1/8th to high above the deck and step framing. We don’t like big gaps and there would have been one once the first piece of decking sat on this trim piece. So I thought about removing it, belt sander or even a skill saw but decided to put a new metal cutting blade on my old fien and hand cut it in place. To hopefully give me a guide and keep the surrounding pieces and g tape undamaged I taped on a couple pieces of thin galvanized steel. I could have maybe done a bit better in the cut if I had younger eyes but it worked ok and I got rid of the protruding 1/8th so decking went on nicely. It’s far from perfect but my bride loves it so I’m happy it’s moving forward. I think it looks a lot better than it would have if I hadn’t cut off the 1/8th.
We started the top deck and figured out the angle (43 degrees) to make the gap on the angled pieces look great. Only 17 more boards to cut and install. Also most of the blocking I did on the lower deck framing had joists ending up 12-13 inches on center and it’s super solid. The upper deck framing was going the correct fit for our new decking and even though it’s 16 inches on center it’s very adequate and solid too.
Hope you all enjoy your day cause I know I will finishing up this project. IMG_1267.jpegIMG_1269.jpegIMG_1268.jpegIMG_1272.jpegIMG_1273.jpegIMG_1279.jpegIMG_1275.jpegIMG_1281.jpeg
D
drivesitfar
P: Thanks!!!
So this upper deck installation is going great so far. The angle stayed consistent even when turning the opposite direction. The point miraculously met at the corner do I didn’t have to cut a double sided piece and the full board pattern only had me notching one board on one of the two sides of the partial wall. My bride wanted me to use a scrap 3 foot piece of timbertech for a pattern but since I’ve got a few cardboard scraps I made one out of that. First attempt after transferring the pattern with my whit marker and cutting with my old black and decker 6.5 inch skill saw worked great.
Only 5 boards left to cut and install today on top deck and trim out my brides bottom Garden work area with Timbertech and I’ll go shopping for a few pieces of hardie plank siding and trim to finish the deck.
We still have a little down time to do a few puzzles and of course eat a good meal or two. I’m putting Les’s or no syrup on my crapes and pancakes and I’ve lost 5 of the 15 pounds I’d like to lose before September.
Hope you all have a grand day!!IMG_1288.jpegIMG_1289.jpegIMG_1290.jpegIMG_1287.jpegIMG_1286.jpeg
patlun
Värmland, Sweden
I looked in now as I had not get any notifications from it for a while. Great process with the deck. Some new tools too and some tasty food pictures.
I also like my corded Makita track saw, the last year I have bought some 18V Makita tools, but I will also keep my old Ryobi tools until they dies. I am using my 12V Bosch Professional tools for most things in either case. The heavier 18V tools are only used when I need some more power and don't will bother with cords.
D
drivesitfar
Patlun: Great to see a few good words from you!! I agree Makita tools are amazing and our one armed Mensa gal had an 18 v Makita 18v impact that weighed about half of my Ryobi 18v and it had plenty of power and it was a bit smaller to get into tight spots. I might start slowly upgrading to Makita as my old dewalt and Ryobi batteries wear down. Keep filling along cause now that my bride is fully retired too my to do lists have a ton more honey do’s on it.
All: well the heavy lifting and cutting (and screwing and plugging and…) is done with our deck. Just a bit more than sore but smiling for certain. My notching went great with double and triple measurements and cardboard templates so the upper deck and deck only lacking a bit of trim now.
I’m picking up these great puzzles off Craigslist and other places so started another one. I had a bought of gout a few months ago and we are not going to just go to doctor and ask for pills do after research my old joints (doctors call it arthritis) have been filling up with uric acid. No surprise cause I have a big one or two sweet teeth. Several non medical options are drinking or eating tart cherries or cherries when in season, baking soda in water (figure out your personal doses) and apple cider vinegar in a glass of water.
I’m off to buy some trim and figure out a way to finish off this deck so my day is going to be busy and hope you all have a grand day too. IMG_1292.jpegIMG_1293.jpegIMG_1302.jpegIMG_1294.jpeg
D
drivesitfar
We’ve been looking for some decent options for shade for our new deck and the $100-300 umbrellas were always only lasting a couple summers and barely provided any shade. So my awesome bride has been search for options and found this 10x13 purple leaf umbrella with its 250-300 pound stand on wheels that both crank up and down easily with the same removable crank tool. It has been awesome to get done shade while finishing up our deck the last week or so. Yes it’s not she’s cause one price for umbrella with sunbrella material (anybody want to mention this because it’s got tremendous reviews), add the cover price, and then the stand with 4 removal containers to add sand and or water. I bought 100 pound bags of sakrete sand cause their other sand is gravely and didn’t fill water to top after putting in about 50 pounds in each container. We didn’t fill water to top cause it can freeze and we don’t want these to break. Once it’s on wheels it is amazing how easy it is to move. Also umbrella is perfect size for our deck and it goes up and down super easy. I think it’s rated for up to about a 30 mph breeze. Not cheap by any means but we have both been smiling for days with how well it looks and works for us. BTW we like it do much we were thinking about getting two of them but this model of stand and umbrella is sold out everywhere currently. I think we will put up some sort of sail over the south end of the deck. If you’d like model numbers of umbrella just ask and if you know anything about sunbrella or high quality deck furniture we are all ears.
Our plants and lawn are growing like crazy with a bit of water and a weeding day or two is in our future but we love grow some of our own food. Speaking of food after the tubers drink to start our day and cherries a simple egg and potatoes works for us.
D
drivesitfar
I mentioned these a few times and some of you like other types or make your own wood ones like I have in the past.
That said I found 300 of these plastic shims in 1/32 to 1/4 sizing and different colors to make it easier for I think in the $20-30 range. They sure come in handy so I made up a box to store them until they get a dedicated drawer.
I also saw this very handy storage idea to store yard tools that I’m hoping to find a way to use one that might help some of you with storage space issues.
It’s sunny here in the PNW and loving it. Hope you are all smiling in your part of the world.
D
drivesitfar
Since I’ve only posted from my cell phone since my old laptop died about a year ago I’m not sure how to do it but maybe I can get my bride to help and get it for you. Search big “A” in the meantime cause that’s where I found them. Also when I was cutting off deck ends 1/16 and up I kept the small pieces to add to my shim box.
Are you enjoying the deck build and ready for a new project? Or busy doing yours? Thanks for always following along with my doings.
Speaking of links to good products find your local lumber supplier and this is what we ended up with. Timbertech azek English walnut that is working out well with our current house color and should work well if we re paint it grey or blue or …
D
drivesitfar
Gear: thanks for following along and happy to answer your question. All the black aluminum timbertech railing we need has been installed. The little area from the upper deck is only 19.5 inches from the lower deck so legally no railing is needed, but since we have more than a few young grandchildren my bride has plans for a work area there for her garden. I’m guessing we’ll buy a nice pvc type cabinet or I’ll build one out of cedar.
I did frame in for a couple posts in case we change our mind later for a 5 foot railing.
Yesterday was more clean up and research for trim material. Big box stores have a 3.5 inch by 3/4 composite trim that could work but the lumberyard hardware store we bought our decking from has 3/4 and one inch azek pvc trim that is a bit spendier but I can buy 9.25 inch wide material and rip it to 4 inch so there will only be a 1/16th or 1/8 gap that we like better. IMG_1331.jpegIMG_1093.jpeg
D
drivesitfar
The last couple weeks I found a tree cutter with excess firewood to sell. Since our one armed friend heats with wood I picked up and stacked 2 trailer loads at her place last week and the tree cutter had some black locust he split a couple years ago that he let me have (I traded my old Stihl chainsaw that I wasn’t using) for us for emergencies or romantic fires so I picked it up and stacked it yesterday. My dream girl helped me unload but she with no doubt that this was the last load she’d help unload. We will see about that but I think we and our friend is set now.
Thunderstorms today and quite a show going on and happy that deck is just needing trim work.
Enjoy your day and got all those avoiding the fires we wish you the best and prayers sent!!IMG_1337.jpegIMG_1337.jpeg
