Vinyl siding repair
RichieP_MechE
Near Pittsburgh
Recently expanded my concrete driveway and am looking for ideas for repairing the vinyl siding. This siding was previously partially buried (note dirt stains of the previous ground level in the picture below). I had the concrete guys just rough cut the siding along the slope of the new driveway with intentions of doing a proper repair later. The siding was installed by a previous owner of the property back in 1998. The siding is attached to furring strips which are attached to the terracotta block walls of the garage.
I plan to remove the bottom three courses of siding and replace them. Not too concerned about an exact color match, it seems Lowes has a gray dutch lap vinyl that should be close enough. I am wondering how to finish the bottom edge since I'm sure my angled cuts to match the driveway slope will not be perfect. Would J channel be appropriate in this case? I am open to other ideas as well.
thammel
Maryland
J channel or starter strip, which is intended for that purpose. Pull off some siding. Look at the back....you may find manufacturer and other info printed on the back.
jack stand
Lakes Region Maine
I would investigate removing any courses below the sill plate leaving a block wall to take any driveway type abuse & shovel snow against.
Pull the furing strip and re parge the block if needed.
Now if they "stepped" the block you can't do this, but I'd keep the siding as high as you can above the driveway.
PCustoms
VT
The siding does not have to be in a straight horizontal line at the bottom. The siding may need to be installed in a stepped fashion leaving brick exposed.
Stepped is still straight and horizontal.
Unless he switches material, the siding at the bottom needs (at least should) follow the same lines as above or else it's going to look incredibly goofy.
R
RichieP_MechE
Near Pittsburgh
Good input here, thanks guys.
The block walls are cosmetically pretty sloppy (prior owner built this garage himself in the '60s from what I can find) . This is a photo from the interior when I was framing out walls to insulate the garage. From other work I have done on the exterior, it looks like it might have been painted before the siding was added in the late 90s.
Removing the bottom courses and parging the block is an interesting idea. I've never done parging before, is it difficult to get a good finish?
jack stand
Lakes Region Maine
I'm no Mason, but I'd think that pressure washing the newly exposed block removing anything loose would be the first step.
Back before poured walls, block was king. I've seen them doing it hundreds of times ( parging block foundation) and like anything, especially involving a trowel, they made it look easy!
I think it's just a Portland/sand mix that I know you start at the bottom.
See what's on YouTube.
The good thing is you don't have that much to do. 👍
manwithtools
Lebanon, TN
Look up Surface Bonding Cement, it's a fiberglass-reinforced Portland cement used to build mortarless (dry-stack) concrete block walls and to waterproof or resurface existing masonry. It's available at the big box stores and it's pretty easy to apply with a rectangular trowel. Videos online for how to do it.
Uncle murph
Harford county
I don’t know about sloppy but he sure was a fan of used building materials,those blocks were all laid somewhere else before. I do the same thing.
CraigStu
Blacksburg, Va
How about a 1x8 PVC board on the bottom of the wall laying on the new concrete. Then standard J channel on the block to finish off the trimmed siding. I think I'd glue the J to the block since it would be a real pain to get fasteners in behind the siding.
PCustoms
VT
Without trim or a starter strip the siding will be loose. Lift it up, use nails or washer head screws to attach the J, then lightly bend/push the siding up so you can push it in the J.
As I said above use some finish trim inside the J to take up the gap, otherwise the siding just flops around
