Always a 'fun' day when you get to put on the extra layers
cvairwerks
Within hearing distance of Texas Motor Speedway
Kind of... its kind of the same principle... but microwaves transmit in the GHz radio frequency range, whereas our machines transmit in the Mhz radio frequency range... but they are running at between 7~10kW, whereas most residential and commercial cooking microwaves run between 600 ~ 1500W.
Oops...mentally translated the M to a G...
The spar adhesive curing system for my big Fairchild was about 60kW of microwave energy. Replaced a couple of huge autoclaves and reduced production time from tens of hours to less than a half hour. Took several years of concentrated research to develop the dry sheet adhesive that would liquify and then cure in a concentrated microwave energy field.
Metal-Marc
Foothills of the Adirondacks
For those of you in the know about proper arc flash PPE
Yeah, younger me used to work on a 50KW RF transmitter fed by a 15KV line and a few others.
We had none of that PPE stuff. We didn't even knew it was required...
My then boss died electrocuted on a job site a few years after I moved to a different job.
Old Man Roger
Palm Coast Florida
It is a simple RF generator that produces a low amperage, high voltage radio frequency signal at around approximately 4.2Mhz. The signal energy is stored in a "tank circuit" capacitor bank, that when grounded, induces a signal across a copper coil for approximately 6~8 milliseconds once small metal parts have been inserted into ceramic holders in the coil and then de-energizes befofe parts are eiected. Due to the high frequency, the high voltage is induced across the metal parts approximately 5000~6000 times in the 6~8 millisecond run time, causing the metal parts to rapid heat to a glowing state before being ejected through a quench tank and onto a conveyor.
The handler which moves the metal parts runs at approximately 400~800 rpm, which allows up to approximately 1600 parts per minute to be precisely heat threated with controlled penetration, since we are able to fine tune the RF field to concentrate the center of its field at the point in the metal parts at which we want to concentrate the heat treatment.
The parts are induction treated to make them very wear resistant at the points where they need it, while being able to be softer and able to be pressed and spun mechanically to heat treat them further once they are installed on assembly equipment further down the line.
and from this point,I think I'm totally lost :lol_hitti
Just heat treating approximately 27.5 million small parts per day
Ahhhhhhhhhhh! Coulda started with that, just sayin.lol :badteeth:
BreeStephany
Oregon
My first months as an apprentice WAY BACK when were at a stud mill where our jurisdiction started at the 160kV lines entering our substation. Most of my work was at 13.8kV and below... but did have some hands on experience with a couple of our 25kVDC motors and associated controls... was an interesting world to start my career in.
gleman
Michigan And Florida too!
That thing looks like a klystron we used as an RF power amplifier for a Ku band radar.
Is it used as an amplifier?
