The slot is to help with transferring dough
I believe the intent is to slide a sheet through it, like parchment or wax paper.Any idea how? The website seems to have some dead pages
Apparently a sheet of pastry cloth goes through the slot all the way around the bottom and clips to make a belt. Then you grab the seam and move it up and down the board in order to pick or place your dough.So not homemade
In my home made pizza dough making, this is definitely a problem i have. I pretty much quit making dough for my pizza oven, because everything sticks to the peel. All three of them. Store bought dough, or recipe from my local pizza guy. Only thing that doesn’t stick is pre shaped pizza.I believe the intent is to slide a sheet through it, like parchment or wax paper.
Feels like a solution in search of a problem
What are you using between the dough and peel?In my home made pizza dough making, this is definitely a problem i have. I pretty much quit making dough for my pizza oven, because everything sticks to the peel. All three of them. Store bought dough, or recipe from my local pizza guy. Only thing that doesn’t stick is pre shaped pizza.
They throw flour on the peel, but they also stretch the pizza OFF the peel and work fast. The more time the pizza spends on the peel, the more opportunity it has to stick. It takes a lot of skill to get as fast as a pro, without tearing the dough.What are you using between the dough and peel?
Pizza shops don't use these shenanigans because they use semolina to make the dough slide
Semolina. Like little ball bearings. But it still sticks like a mother and tears the dough.What are you using between the dough and peel?
It does, and lots of bakers use this cheat on pizza and bagels. But it also completely changes the texture of the crust.Dusting with cornmeal works great also.
Sure does. For the better. Especially when baking with a Crisco rubbed, and cornmeal dusted cast iron pan.It does, and lots of bakers use this cheat on pizza and bagels. But it also completely changes the texture of the crust.
