Between 265 & 485 SQ/FT Woody's Works Garage
D
Denwood
Thunder Bay, Ontario, Canada
Not sure the girls even noticed..ha. At least the ice cubes stay frozen now.
I've been wanting to figure out a way to get differential air pressure readings into the house automation system so I could actively balance my HRV. I've modifed the HRV so instead of an old AC fan internally, there are now two ECM inline fans (one for fresh air, one for stale). I figure the "ultimate" method of varying CFM according to the air quality settings would be to continually ramp up or down on the fresh air CFM (based on what the home actually needs based on air quality), and then actively balance the stale air fan settings so air in precisely matches air out. This is what more expensive ERVs do, but they do it based on current sensing on the ECM fans...not actual pressure sensors!
So, using Home Assistant's "ESPHome" integration, two $9 ESP32 boards, and two Sensiron pressure sensors we get this. It definitely confirms that my ECM fan programming based on manual pressure testing (the HRV has balance ports to do this) was pretty darn close! Next step is to dynamically adjust the ECM fan motors (they are controlled by 0-10V) so the unit dynamically balances itself...
So these tiny sensors, the Sensirion SDP810-125Pa, (one for stale, and one for fresh air) are not cheap at around $40 each. 1/8" tubes go out to the HRV balancing ports.
Each sensor is connected to one of these tiny ESP32 boards (about $9) with four wires.
..and that tiny board hosts the pressure sensor and talks to my Home Assitant box via WIFI.
The ESP Home integration in Home Assistant lets you custom program these ESP32 devices to host all kinds of sensors for temp, humidity, lidar, pressure etc. Super COOL!
Cleaned up the HRV CFM project with a project box, magnetically attached to the HRV door so it's easy to remove...
Stacked the two ESP32 boards on standoffs, and mounted the pressure sensors as well. Power buck is upside down (LED display) so I'm wondering about any OCD tendencies...ha.
D
Denwood
I'd say our camp is 100% touch and go right now, but otherwise, just a ton of smoke and falling ash at times here in town. The yellow circle is our site. Winds today NW at 20-40 so not sure how it's not already burnt....
Friends who were out there last night were raised from their beds at 1 am by the resort owner and were lucky to get out as the only access road was burning shortly after.
D
Denwood
It looks like the entire area burned up yesterday. Now they're advising residents of Thunder Bay (about 140K people in the area) to prepare a 72 hour evacuation kit. That's a situation we have never been faced with. With NW winds forecast 20-40 km/h, today will be, uh, interesting.
Last night via my drone. It was pretty dark at 5pm (car headlights and motion lights all thinking it's night), with sunset at around 10:30pm.
I'm guessing these fires will coalesce somewhat with strong movement SE today on the NW 20-40 wind projections. Zero rain forecast.
The closest fire is about 100km away, 60 miles as of this moment according to NASA FIRMS.
D
Denwood
Swapped out the carbon canister today. The first one lasted about 3 years, but with today's heavy smoke I was faintly detecting smoke smell inside. With the new carbon canister, no smell at all. PM2.5 outside was 113 ug/m3 and inside, just 5 ug/m3. You can see in the video (1 minute long) how intense the smoke is right now.
slim_grim
Central NC
Brilliant. Wishing you and your community all the best.
nicholam77
Minneapolis, MN
Wow, Dennis, crazy with the fires!! Glad your campsite (sorta) survived, hopefully it’s not a total loss even though I’m sure the surrounding area is destroyed.
Stay safe with the smoke! I went for a 40min walk last night and regretted it… air quality in Minneapolis is pretty awful right now, too.
Nice job with the carbon filter and your fancy HRV system.
Love all the ESP32 automation bits. I really gotta try that sometime, I’ve just been swamped lately, and don’t have any experience with electronics, soldering, or development boards so it’s always seemed like an in depth project, but maybe it’s easier than I think. And yeah, do a video! Seems like it really unlocks some unique ideas, and cost effective. I’ve been curious about those ultrasonic distance sensors because some people use them for water softener salt tank levels, which is a problem I struggle with haha. The parking light is a great idea, too.
Anyways, stay safe up there!
D
Denwood
326 ug/m3 is insane. You'll get some relief as the winds clock south. firesmoke.ca models your area too and is quite good at predicting smoke levels, animated over 48 hours.
On the ESP32 side, I am not a dev board kind of guy at all. But ESPHome in HA combined with ChatGPT makes it almost elementary. No soldering required. I just ordered up a set of wires like these to do all the connections: https://www.amazon.ca/dp/B0BTT48V7P?th=1
This stand off kit to mount all the boards: https://www.amazon.ca/dp/B07B4BH5VK
The basic process:
1. Plug in the ESP32 boards via USB to your PC or the HA machine directly. These work for me: https://www.amazon.ca/dp/B0D8SXGL9C). This site provides the pin outs, names and specs for those boards: https://www.espboards.dev/esp32/esp32doit-devkit-v1/
2. Then create and upload the "firmware" to them using ESPHome in HA. The firmware includes some YAML code, again have ChatGPT write it for you. You can just power the boards via a USB wall wart. ESPHome creates the firmware upload, and guides you through the process to write it to the ESP32 board.
3. The sensors usually require 3-4 wires connected, again easy if you're using ChatGPT with respect to which wires to connect where.
4. After programming, the boards reboot to your WIFI network, with sensors feeding data to HA. It's relatively simple actually.
This is the code used by ESPHome for the ultrasonic distance sensor (https://www.amazon.ca/dp/B0F19BJDQF) which includes the pins to connect :)
Code:
# Board: DOIT ESP32 DEVKIT V1
# Distance sensor: A02YYUW UART
# Wiring:
# Sensor red    -> ESP32 VIN / 5V
# Sensor black  -> ESP32 GND
# Sensor white  -> ESP32 RX2 / GPIO16
# Sensor yellow -> Not connected
esphome:
  friendly_name: Garage Distance Sensor Rear
esp32:
  board: esp32doit-devkit-v1
  framework:
    type: esp-idf
logger:
  level: INFO
api:
  encryption:
    key: "Your OWN API key HERE"
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  power_save_mode: none
  ap:
    ssid: "Garage Distance Fallback Hotspot"
    password: "**********"
captive_portal:
uart:
  rx_pin: GPIO16
  baud_rate: 9600
  data_bits: 8
  parity: NONE
  stop_bits: 1
sensor:
  - platform: a02yyuw
    name: "Rear Garage Distance"
    uart_id: distance_sensor_uart
    unit_of_measurement: "cm"
    accuracy_decimals: 1
    device_class: distance
    state_class: measurement
    filters:
      - multiply: 0.1
      - median:
          window_size: 5
          send_every: 3
          send_first_at: 1
  - platform: wifi_signal
    update_interval: 60s
  - platform: uptime
button:
  - platform: restart
drivesitfar
Still praying and crossing fingers and toes that both your places especially your home survive this.
Good luck too!!
Nice tech stuff
Just curious if you can recommend a good quality router that has updates regularly to avoid the idiots dirty stuff?
D
Denwood
Some rain today...thank goodness. It won't put anything out, but it will slow things down. On the router question @drivesitfar , that is a good one as I build up "roll your own" routers using pfsense. I think trying to block things at the router may not be the best bet. I would try first setting up DNS to point to CloudFlare family (1.1.1.3 and 1.0.0.3). You can set this up on your existing router in the DHCP section. Try that first.
drivesitfar
I don’t totally understand what your tech talk said or how to do that but I’ll do some research and see what I can figure out. Thanks for the tech help.
Seriously hope this fire stuff leaves you and your friends and family alone do best of luck with that. We just had a day of huge thunderstorms and rains here yesterday that might also be heading your way.
Good luck!!
zanyad
NE Ohio
drivesitfar
Just letting you both know I’m still not positive what the numbers mean but with some research I’m guessing you have headed me (us) in the right direction.
D
Denwood
Whoah. This is great. Thanks!
For those following along:
Thanks for that! From CloudFlare's site, some more information:
Malware Blocking Only
Primary DNS: 1.1.1.2
Secondary DNS: 1.0.0.2
Malware and Adult Content
Primary DNS: 1.1.1.3
Secondary DNS: 1.0.0.3
For IPv6 use:
Primary DNS: 2606:4700:4700::1112
Secondary DNS: 2606:4700:4700::1002
Primary DNS: 2606:4700:4700::1113
Secondary DNS: 2606:4700:4700::1003
Your router will have DHCP server settings (which gives out IP addresses to your phone, computers etc.) In those DHCP server settings you will see a few fields for DNS. In one of them enter 1.1.1.3 and in the other, 1.0.0.3 You'll need to enter your router's IP address into a browser and log into it to change these settings.
You can google "DHCP settings" for your brand of router to lead you in the right direction.
nicholam77
Minneapolis, MN
@drivesitfar DNS stands for Domain Name Server — it's a part of the internet. Basically it's a server (computer) somewhere that helps look up the websites you are requesting. So when you type in a human-readable URL like www.google.com, your router sends a request to a DNS server to figure out what the IP address of the website you are requesting is. Because computers and websites are identified by IP addresses (the string numbers that looks like 192.62.346.34).
But really when you enter a URL, the request doesn't immediately get looked up as the website IP itself, rather it goes through a chain of DNS servers to find the correct IP and serve you the website. All of this happens in milliseconds.
And... this doesn't just happen when YOU type something in the search bar. Any internet-connected device in your home is likely making many external web requests per day. And they all go through DNS.
Your ISP (internet service provider) likely has their own DNS servers they gave you. But there are many public DNS servers available across the internet. Many people don't know that they can choose which DNS server they'd like to use. Google, for example, provides public DNS servers. Why might you want to choose your own? Some companies are more committed to running secure servers, not selling your data, not serving you targeted ads, etc. And like the ones @Denwood and @zanyad mentioned, some DNS servers can also provide a filtering function for privacy or blocking types of content. For example, let's say you search a certain website, and the DNS server blocks the request. This can be true for ads... or other nefarious sites and content.
I was not aware of the Cloudflare specialty servers, but that tracks.
Again, there are many out there.
Personally, I run an Adguard Plus extension on my Home Assistant installation. So I enter my Home Assistant local IP as my DNS in my router, and all local traffic goes through that Home Assistant machine, which then reaches out to a special Adguard DNS server that has some built-in protections. I've also enabled a number of blacklists to block malware and ads. It's great because I don't have to install any clunky ad-blocking software on my client devices, but the Home Assistant computer "checks" all the traffic.
Just to give you an idea of how many external web requests are happing in my house, today it's been 54,883 requests, with around 30% of those requests being blocked and never being resolved. I presume the blocked traffic is mostly ads.
drivesitfar
Thank you Woody!! When I was in high school I wrote computer programs that would take a month to get results back. I probably should have stayed with it but I decided to learn just enough how to use computers and technology the last 50+ years since.
It will probably be winter before I do a deep dive on our router, tv, iPhone and such but I think I need to spend the time and learn.
Thanks for explaining what you know and Z too and maybe this will get me started on the right track.
I hope we save you lots of rain. Did we and have the fires died down or taken a different path away from you?
D
Denwood
@nicholam77 thanks for that DNS primer…had no idea HA was capable of filtering…
@drivesitfar we had a day today with some rain, and FIRMS shows fewer hot spots but I know in a few days if we don’t get more rain, it will all be raging again..
Still lots of smoke, we were up over 300 ug/m3 PM25 yesterday.
@manwithtools , @slim_grim, @zanyad thanks for checking in gents. We confirmed that our trailer site did survive, but about half the resort burned the day after the big fire on Tuesdsy due to hot spot ignitions on Wednesday.
D
Denwood
The owner of the resort we camp at is featured in this interview and footage of the fire area:
D
Denwood
With camp access blocked (and an $800 fine for ignoring it) due to "fire crews in the area" (good news!), what's a guy to do? Time for some garage mad science....the garage parking guidance system lives! @patlun , here you go…
This little controller (about $25 runs the free/open source WLED firmware, and can be controlled by Home Assistant over WIFI. I've got a 12V power supply plugged into it and the harness side on the right goes to the LEDs. The strip is a SK6812 RGBW, so that's what you set up in the configuraton on the controller. It's accessable of course via a web browser :)
Each of the 300 LEDs on the 15 foot strips is addressable, meaning each can be controlled with respect to on/off, colour and brightness. I split the strip into 3 lengths.
You can cut these strips anywhere you see that cut line so literally, pretty much every inch.
And then if you are extending that strip, you need to carefully solder three wires onto the copper pads....in this case hidden by the heat shrink/glue tubing.
The other part of the equation are the three ultrasonic distance sensors. It turns out they are quite accurate...with the car in the shop, I'd say better than 5mm accuracy. In any case, there is the ESP32 board programmed by ESPHome in Home Assistant to host each sensor. They are powered by a mini-USB cable.
Mounted the ultrasonic sensor into the enclosure lid.
A puck magnet attached to the rear of the project box holds it in place. One on each lift post...
One at the rear of the shop.
The 15 foot LED is cut into 5 foot sections, but each section is still connected (with my soldered connection wires) so the entire string can be controlled. The WLED controller is setup with 3 "segments" so LEDs 0-100 are for the RIGHT indicator light, 100-200 for the REAR (the lights up top), and 200-300 for the LEFT light array.
This is with the car parked in exactly the right spot, so the right, rear, and left indicators are all green.
Now what's super cool is that once the door is opened, the automation is triggered (it times out after 2 minutes with no movement, or closing the door) and the lights cycle from RED, to YELLOW to GREEN as you approach the correct distances, and rapidly flashing RED if the car is too close to the posts, or the rear of the shop.
To take things up a notch, I've added a dashboard in Hubitat so the distances can be changed. You can just type in new values for the distance ranges that trigger red, yellow and green.
I will have a "recipe" for each car for work on the hoist. The Home Assistant dashboard is accessible from my phone, so just having it on the dash, I'll be able to dial each car in for the correct lift position without the usual 2 or 3 times getting out, checking, getting back in and adjusting the car position.
And as a bonus the lights will come on at 5000K full brightness when the parking automation is not in play, and motion is detected in the garage :)
This took 7-8 hours to complete, but it’s my favorite shop mod ever!!
drivesitfar
WOW!!’ That is too cool that your campsite survived the fire. AND of course your new garage technology is awesome.
It looks like it might work a tad better than a tennis ball hanging from the ceiling. (Hee hee)
Have a grand evening
D
Denwood
Tennis ball... I had thought of that. A LOT simpler, but way less cool...ha :)
One of the things I like about these sensors is that they are lot more accurate than say a typical PIR motion sensor, and also way less likely to provide false readings. I see a lot of applications other than parking.
The very near miss at camp is great news, but due to all the destruction at the site in general, it may be a month(s) before we get power and water etc. back. We may actually have to "camp" for change. I'll be certainly looking to help out as much as possible with folks who have lost their entire site.
nicholam77
Minneapolis, MN
Wow, great job with the parking automation Dennis! Looks really neat. The lift heights are a great idea, too. The LED strips look cool, too. Not sure what else you could do off the top of my head but now you have some notification lights in place in case there’s other things you want to light them up for.
You have me re-inspired to try one of these for my water softener salt tank. I was going to try to put a weight on a string inside connected to a contact sensor in a 3d-printed pivot mount, but a distance sensor seems like much less work and probably more accurate.
D
Denwood
The sensor is really easy to do..and should work fine for liquids. The A02YYUW range is 3-450cm. These are bits I used for the sensor, maybe $40 per sensor all in. You can connect multiple sensors to one ESP32 board too if you want.
Lemotech Box: https://www.amazon.ca/dp/B0BP79VW3L
ESP32 board: https://www.amazon.ca/dp/B0D8SXGL9C
Distance sensor: https://www.amazon.ca/dp/B0F19BJDQF
These jumper wires making connections easy peasy: https://www.amazon.ca/dp/B0BTT48V7P
Standoffs (to mount the board in the box): https://www.amazon.ca/dp/B07B4BH5VK
You'll need a mini USB cable: https://www.amazon.ca/dp/B07X6CWM3G
You'll need to add ESPHome Device Builder to your HA installation. Select "DOIT ESP32 DEVKIT V1" in ESPHome and add this code to program it. Just change the sensor name(s), WIFI fallback password, and ESPHome Native API to match your setup. If you do decide to try it out, I can send more pics etc. :)
Code:
# Wiring:
esphome:
  friendly_name: Garage Distance Sensor Left
esp32:
  framework:
    type: esp-idf
logger:
  level: INFO
api:
  encryption:
    key: "YOUR ESPHOME NATIVE API"
ota:
  - platform: esphome
wifi:
  ap:
    password: "YOUR SECRET PASSWORD"
captive_portal:
uart:
  rx_pin: GPIO16
  baud_rate: 9600
  data_bits: 8
  parity: NONE
  stop_bits: 1
sensor:
  - platform: a02yyuw
    name: "Left Garage Distance"
    filters:
      # Convert millimetres to centimetres.
      - multiply: 0.1
      # Reject isolated false readings caused by ultrasonic crosstalk.
      - median:
          window_size: 5
          send_every: 3
          send_first_at: 1
  - platform: uptime
button:
  - platform: restart
Pinout for that ESPHome 32 board I linked to:
D
Denwood
28C and humid. Can actually see the sky for a change. Lots of resources on the fires but we’re still travel restricted to camp :-(
I really like this fellow's perspective on the whole wild fire issue. It boils down to taking measures to protect yourself as these things sometimes are beyond control.
