Wood Rat wall
Crowbarman55
I am building a 12x16 shed.
It will be wood floor.
The City requires a Wood Rat wall with a wood floor (see pic)
How would you attach this to the floor?
Just nail it to the outside of the rim joist?
Forgive me I need simple instructions and pictures would be better.
Thanks
velocipede
Yorktown, Virginia
Their sample shows rim joists sitting directly on finished grade, What if your shed is on skids over a gravel base? Same requirement? What is your shed sitting on?
readhead
Durango, Co.
I know the answer but we need some more information. Is this a portable storage building? If so, what size?
Superbowl
DC area
I would ask about laying hardware cloth (wire mesh with 1/2" square holes) on top of the joists with the plywood floor on top of that. Then you just nail through both the plywood and hardware cloth. No rat is getting through that. And if you decide to move the shed you don't have to deal with a rat wall going 12" into the dirt.
To answer your question however, nail or screw the wood for the rat wall backing to the 2" side of the 2"x4" shown in your drawing that is laying on it's 4" side.
PCustoms
VT
Thanks
Can you slightly elevate the shed to allow airflow and prevent critters?
LWB
ON, Canada
This may be a dumb question, but since when has wood stopped a rat?
In our chicken coop I put hardware cloth down 12" and 2x6 floor joists on patio stones. I filled every cavity with 3/4" gravel right to the top of the 2x6. No chickens causalities lol
C
Crowbarman55
Ok, so build it a foot off the ground...
I'm thrown off that you can stick build a shed but can figure out a rat wall.
A rat wall wasn't required then and there. I didn't need a permit or an inspection then. I just want to make sure I pass inspection now.
C
Crowbarman55
I don't know. It's the city we live in that has this stupid code to use wood.🙄 lol
  • Haha
Reactions: LWB
C
Crowbarman55
1/2" plywood will not deter, let alone stop, even a moderately motivated rat. Install it in whatever manner is most convenient that will satisfy the inspector.
I agree. I talked to the inspector and he told me to just use 1/2" because it's cheaper.
Superbowl
DC area
Go back and look at the plan in the first post. The plywood is "a continuous nailer" for the rat wall barrier. So the plywood is just a nailer. I suspect metal flashing is the actual rat wall barrier.
carlaisle
Agreed, but since no "rat wall barrier material" is specified, none is required to be installed. The correct solution remains to ask the inspector what is required to pass and then do that.
