Yankeefarmer
I’m gonna be helping my nephew install a drop ceiling in his basement. Room will be about 12’ x 50.’ What’s a good laser level to facilitate leveling the grid?
I have that exact level but paid $150 for it. Inflation I guess. It works well.
Hmmmm. 12x50 is a big room. The trick with laser levels is that they can be really faint a distance from the head. I have the Bosch green 12v 3 beam model. Reviews I saw said it was the brightest or close to the brightest. Milwaukee was bright, but the beam was thicker if I recall.I have that exact level but paid $150 for it. Inflation I guess. It works well.
For 1 project use you can probably get a xyz Chinese brand equivalent off amazon for less than $100.
40+ years ago I installed an 18’ above ground pool in our sloping side yard. Got many compliments and questions about how dead nuts level the waterline was. I had leveled the site using a home made water level. Didn’t think to use a valve on it though; had to be careful when moving it!Just an FYI, in the 80's I hung thousands of square feet of suspended ceilings with a water level made from clear vinyl tubing, an empty washer fluid bottle, and a truck Shrader valve .no fancy tools
Stop being so dramatic. Put the laser in the center of the room and you're shooting no more than 6 ft x 25ft. Put a laser receiver on it and shoot up to 200+ ft. A Huepar laser receiver is about $50 works equally as well with my $800 Hilti laser as it does with my $60 Ereoin (on Amazon) laser.Hmmmm. 12x50 is a big room. The trick with laser levels is that they can be really faint a distance from the head. I have the Bosch green 12v 3 beam model. Reviews I saw said it was the brightest or close to the brightest. Milwaukee was bright, but the beam was thicker if I recall.
How powerful the beam needs to be depends largely on the ambient light. I think all of these are tough to use outdoors.
I personally don’t love the advice to get a cheap model off amazon.
Here are some details. I set my laser, but can’t see the beam everywhere I need to. So I try shading the line with scrap wood or using a piece of Azek as a reflector, then marking. But sometimes it’s just too faint. So I leave a mark and move the laser closer. But then you need to adjust the laser to hit the mark.
Good lasers have good adjustable mounts. i use a good quality camera tripod to hold mine. But no camera mount I know has a fine enough adjustment for a laser.
Thank you for this recommendation. Last night I decided it would be worth rolling the dice on this;Amazon delivered it at 5 a.m. Put a quick charge on the battery, and tried it out on the project at 9:30 a.m. To a guy like me who never had one of these, it is a gamechanger. Worked like a champ setting up wall lines, checking plumb, etc. It was money well spent.Honestly.... any generic 3 axis rotary laser off the internet will be awesome
You would be hard pressed to spend $60 better then this
WEIDDW Laser Level 360° Green Cross Line Self Leveling Laser Measuring Tool: Amazon.com: Tools & Home Improvement
WEIDDW Laser Level 360° Green Cross Line Self Leveling Laser Measuring Tool: Amazon.com: Tools & Home Improvementwww.amazon.com
It's amazing how inexpensive these can be purchased today. I can assure you my Milwaukee's were no where near that price. I would not be surprised that yours worked just as well as mine.It was money well spent.
I bought one of these three line green laser levels a few years ago - not this exact model - I think I paid $79, and it has been awesome.Honestly.... any generic 3 axis rotary laser off the internet will be awesome
False economy today...This dinosaur saved the money and used 3/8 clear plastic hose.
i don’t have experience with cheaper models. I’ve had 2 Bosch models, an early rotary, and the newer 3 beam GLL3-330CG.I bought one of these three line green laser levels a few years ago - not this exact model - I think I paid $79, and it has been awesome.
I've used it for a ton of projects, including checking the level on floors in my house, leveling pictures, leveling siding as it was installed and many others.
I would recommend that you don't have to buy a brand name - the generic ones are really good.
Mine came from Amazon it's called IKOVWUK - I don't know how they come up with those brands, but i'm sure you could buy the same one with several names on it. It's a green laser 3 line beam.i don’t have experience with cheaper models. I’ve had 2 Bosch models, an early rotary, and the newer 3 beam GLL3-330CG.
I’m on this tear about reviews and reviewers. So I’d say for laser levels, if you are doing big spaces or working outside, beam brightness is a really big deal. My old rotary is very stable and accurate, but I just can’t see the beam easily. Every time you have to move the laser so you can see it, you have to re-setup and you lose accuracy. So the super bright lasers can be way nicer to work with and way more accurate if that makes sense. I’d watch some reviews and try to use brightness as a strong attribute to help you choose.
One reason I chose Bosch is that it used tool batteries I currently have. My rotary used D cells and it got dimmer as the batteries aged. With the newer Bosch, the brightness stays pretty flat until it shuts off and I almost always have fresh batteries in it.
Maybe not immediately obvious to all potential purchasers is the importance of the mount. I use. Manfrotto camera mounts because I had them. A stable base is important. Should easily achieve a range of heights, ideally over 6’8” for interior doors. A fine adjustment, which I don’t have on my camera tripod, but comes with the Bosch is pretty important. When setting level, you can shim a leg pretty easily. The problem I encounter is indexing plumb lines. In a perfect world, it would be great to have a little XY table. Otherwise, I find myself messing with it.
My rotary was just a level. I didn’t realize how much I’d like the 3 beam and it really shows in my work. 3 beam is a game changer. I’d also say it’s a very tough boss. If you set up a 3 beam in probably any building, you’ll instantly see how far from level plumb and square it is. Since buying the 3 beam, the quality of my carpentry has greatly improved. I’m currently putting up Hardie siding and I’m trying to chase that beam all the way around the house. Maybe a water level would be a good approach for this. Otherwise, there’s no real practical way to achieve this without a laser.
Last, possibly in favor of lower cost models, I could see leaving a laser set up as a datum for days and days, not always on. In that case, I’ve had use for both lasers on bigger jobs simultaneously. I could see the utility in having a couple 3 beam lasers.
A few things I don’t like about my Bosch:
1) The way it attaches to its base does not allow me to swap battery’s without unscrewing it from the adjustable base. Not a deal killer because you can take it off and put it back and it will be in the same place level wise. But a huge disadvantage for plumb lines, and just annoying.
2) The Bosch adjustable base has a pretty coarse adjustment screw. You can fine tune it, but it’s not super easy and can be stiff. One tip- it’s a plastic rack and pinion gear and super lube really helps. I try to keep it covered so it stays clean when not in use.
3) You can download an app that allows you to turn it on and off with your phone. That’s been helpful to save battery life. I’ve attached it to structure from a ladder in some remote undisturbed location. Didn’t think the app would help me but it has.
4) The base isn’t super easy to attach to stuff. It’s magnetic, but I’m not doing steel studs. It has a hang hole which works okay but feels like an after thought. I’d prefer some easy way to clamp it to studs or joists. There isn’t even a good place on the base to clamp to.
If you watch YouTube reviews on laser levels, I don’t think any of this is discussed. And that’s my problem with the reviews I think many of us are watching. I’ve been building with lasers now for about 8yrs. Disclaimer: I haven’t gotten to kitchens and bathrooms yet. I’m doing fairly big work with my lasers, setting floors, wood and concrete, window and door openings, footings, balconies/decks etc. My sense is most buyers are doing smaller interior work and their needs may be slightly different from mine. But I think regardless of the scale, what I’ve written above will help.
Well, ya see. When your head is in the clouds and you have tunnel vision, and you equate price to quality and features you miss a lot of stuff. The cheap lasers on Amazon such as the Ereoin that I have, has a key fob remote that allows it to switch beams, turn off/on, add the pulse function. It also comes with a small rotary base to fine tune your plumb lines,all in the $60 kit . The Hilti, Leica, Milwaukee, and newer Dewalts 3 beam-360 lasers have a micro adjust build into them. Hilti makes a $99 bracket, magnetic, can clamp to wall angle, threaded inserts for tripod mounting with an adjustable, locking geared height adjustment. There is a Heupar 3 beam,360 that you can plug in a USB cord and run off an A) larger power/battery pack ,or B) plug into the wall if one needed long term power on/power off without moving the laser.i don’t have experience with cheaper models. I’ve had 2 Bosch models, an early rotary, and the newer 3 beam GLL3-330CG.
