Old sharpening grinder...
PDXDave
So I'm back after a bit of break with another scrap yard rescue.
Someone dumped this old Intedge sharpening specific grinder.
It runs perfectly and the bearings are nice and smooth with no rough spots or run out.
It came from a cutlery shop that was in downtown Portland for many many years.
As near as I can tell, the company was known for their kitchen knives and not tools at all, so I'm thinking it's probably built by someone else to spec and re branded.
Any information on this old guy would be helpful.
Thanks!
1982fxr
Phoenix
Looks like an old USA made Doerr.
Never seen anything like that double wheel guard.
P
PDXDave
3450rpm seems kinda high for knife sharpening.
I had the same thought, but knowing where it came from most definitely cements it's history.
They did a lot more than cutlery, but it's hard to say how this particular piece was used.
RoninB4
Under My House
-The type of abrasive discs/wheel would be an indicator for how it was used in general. Hard/rigid wheels would be for removing relatively large amounts of material (rough shaping). Softer/semi-flexible discs/wheel would be for removing less material but improving the surface finish. That's about all you can get, an exact purpose will be speculating unless you knew the department it was used in. Dismounting the abrasive wheels/discs may have markings on them to identify the abrasive itself, which would offer a clue about what it was used on. It's a nice looking grinder.
Lassen Forge
Amazing machine! Can I call it the "3 buck *****"? My WAG is they used it for scissors... which are tricky to sharpen.
I have a geared down dedicated sharpener, the motor runs at 3250 RPM, one side is direct drive, but the sharpening wheel spins at about a 1:20 ratio, and sits in a water bath trough. Found it at a local contractor supply house, it'd been there long enough to get a nice layer of dust....
And it SURE as hell wasn't no 3 bucks! Congrats!
