Tchicken
THE Motor City
That color scheme confuses me. If you use the tools enough you can eyeball sizes to some degree of accuracy (like my mechanic gramp, but to be fair he could only spot the difference between 11/16" and 3/4, metric hadn't been invented back then), if you don't use them that often having to reference some easily forgotten color palette doesn't help.
ER70S-2
I love this concept as well. What is the origin of this color specification? I am hoping that it becomes universal with ALL manufacturers, and "every company does it different"
LOL, what exactly do you love about it? No way in hell you're going to remember what those colors mean unless you have a photographic memory.
MichaelP
IL/WI border
At least, while working with two wrenches, you will know which one to pick up next.
But you're out of luck if they are, for example, 7/16" and 5/8". :)
Chuckster in NJ
Hunterdon County NJ
The colors on these wrenches don’t match the colors on my nut drivers…….. The color coding is a stoopid feature and I can’t remember what I ate for breakfast so I can never get use to the colors.
BTW! Buy these for the wrenches NOT the colors.
Ohio Andy
Columbus, Ohio
The color pattern is cyclic and repeats, the problem is that the sets have skips which means that the color pattern is not actually complete... You can use it to immediately tell that you're missing something. But I do have to admit that when I have three of something sitting there, it makes it really easy for me to be able to more quickly grab what I'm getting at least when the color is visible
Tchicken
THE Motor City
I guess I'm just too stoopid to appreciate the cosmetics .. personally preferring clear markings, but a little paint is likely cheaper than large engravings
pcrov
Ontario, CA
Where the logic lost me is some 1/32" skips skip a color and some don't.
Still though the colors are pretty and help make the numbers more visible so I like them anyway.
Aileron
outside
that coloring would make it nice for wrenchs thrown in a draw like mine. i cant read the sizes anymore. However i'm used to nut driver colors yelow being 5/16, blue 3/8 ,etc It doesnt match that standard thats been around for years. Kinda gives me a idea to maybe mark my wrenchs with a band of colored taped. I have the metrics and sae all thrown together, I don't have time nor waste of draw space for all that neatness. I have two bottom 44" roller cabinets and cant hardly shut the drawers as it is.
moemc
the colors seem trivial to me. say i am working on my truck... i know every fastener on there is 10, 12, 14, 17, 19... and a 10 and a 12 do not look similar, you can clearly tell which is which. Aside from that I can tell with 98% accuracy which socket or wrench is what just by looking at it (and i'm assuming most of you can). If you are working on a project that you're not familiar with the hardware on, and you aren't able to tell just by looking at it... how does it help that the wrench is labeled in colors if you don't even know what size fastener you are dealing with anyway? I feel like this conversation about color coding is ignoring the elephant in the room; its not really useful. If you use your tools often enough to remember which is what, then you are probably already to the point of identifying the size at a glance.
Aileron
outside
I know what i am looking for, i just can't find it, I have a ,14, 15, 16. 17, 1/2 9/16 5/8 ie all laying on top each other, can't see the writing on them so your shuffling through them if you don't have your glasses on. Kinda feel like Ray Charles sometimes. gotta grab it, pick it ,look at the engraved numbers and aw **** one size off, and throw it back. If I only had one set it may be differant.
markbinwi
Appleton, WI
It looks like a repeating pattern of Roy G Biv to me. i learned that in the second grade so it is burned in. Its the near time memory that fails me.
Ohio Andy
Columbus, Ohio
These are really nice, works well on rounded bolts... These are pretty tight, which is something I like and also a complaint.
A good price of you only need a 6 piece set...
Here is another Craftsman overdrive socket set with 10 wrenches included.
Sockets and wrenches both have their "torque tight technology" that work well with rounded bolts
Ohio Andy
Columbus, Ohio
The Craftsman 11 piece wrench set is $70 at the moment. It went down to $50 last October at Lowe’s. Maybe they will be a holiday special again. Great set, with a nice carrier. I like them at full price
Can't disagree. I have this set in my basement at home...
Oddly, the 11 set of SAE wrenches has some not included in the big set (and I think the big set had one not in the 11 set, but would need to check my notes).
Chuckster in NJ
Hunterdon County NJ
I have one set of each in SAE and Metric…….. Great set that really "grips" and the length is perfect.
Grab these when they are on sale and you will thank me later!
