Home Depot Laser Level Shopping Spree
jeepinerdeep
South Central PA
I have searched threads a bit but not finding much that narrows me in-
Details-
  • I have $450 in Home Depot gift cards from frequent traveler perks. Budget for this $450 +/- $100 and commonly at Home Depot in store.
  • Needs to be fairly accurate out at the 60-100ft range, so the under $100 models probably aren't it
  • Want to project green cross line and plumb point, indoors. Bonus points if I can project a line across the ceiling somehow instead of a chalk line
  • Was looking at Bosch, Dewalt and Milwaukee products in the 100-300ft ish range
  • I have Milwaukee batteries out the wazoo, but am not married to the brand for this
  • I have zero experience with lasers
2 that come up in search often are Bosch GCL165-42GL and Milwaukee 3622-20, not thru looking at Dewalt models yet.
Anyone have any thoughts that line up with the above?
manwithtools
Lebanon, TN
I have the 3622-20 and I've been very pleased with it's performance. If you want to make it even easier to use when working alone, add the
48-35-1314 Wireless Laser Alignment Base W/ Remote. It's a little pricey, but it really makes setup a breeze when you are working on the opposite side of the room from the laser.
EDIT: I actually have the 3632-20 which is the three plane laser. @signcrafter is correct about the usefulness of the right angle layout planes.
alinc100
Dearborn,MI
Umm, just so you know any of the 3 beam crossline lasers you are looking at under $1K will have a stated accuracy of 1/16" to 1/8" in 33 ft. That goes for the Hilti ,Dewalt , Milwaukee, Leica, Spectra, etc. You will most definitely need a receiver at the distances you've quoted. If it was me, I'd buy something like this Huepar laser on Amazon and use my HD to buy the tripod, the Hilti PMA100 mount, a laser receiver of your choice.
Dig Doug
I have 3- PLS lasers, they are at least 7 + years old
Excellent Quality
if you need to shoot 100 feet set the laser up mid way and shoot 50 & 50.
Hint -
set the laser up w/ an off set of say 2 -3 inch - then use your tape to measure up
Shiftless
East Bay SFO
Outside of establishing a roughly one inch in 10 feet slope for a paver patio, I have no experience in the accuracy needs of you guys. I built a 50 foot long fence and wanted the tops to be level. I just used a carpenters’ bubble level and a string line for that,
I’m just wondering if being one inch off over 300 feet is a deal breaker. Does a guy need to spend $1000+ to get better accuracy ?
J
jeepinerdeep
South Central PA
I'm leaning towards the 3622 pretty heavily at this point. Looks like the bare tool and tripod package can be had for 409, that leaves me a few bucks to buy a packout for it.
Excellent Quality
Hint -
Yeah- thanks, good point. The 50/50 method will work fine for my max use. I would set it up in the middle of a pole building for hanging wall trim and sheathing, setting conduit and air lines etc.
Understood, thanks for pointing it out, aside from the above the 1/8 in 33' will do fine and be an upgrade from a 4' level and a pencil.
Dig Doug
You can use a water level to create a level line if you want to go cheap add some food coloring/ soda pop to color the water,
make a wire hook to hang one end and then add a pole/ 2x4 vertical to hang the movable end
make your marks every 25 feet as a base / reference line then measure up down for your piping runs
notes
just don’t drop one end below the other end or you will pour out the fluid from the tube
both ends need to be left open - no caps
leave about 2-3 feet of tube above the water line on both ends
when at rest both sides will be level
$30 bucks & some colored water
but a laser is more fun !
lol
signcrafter
That one is only a 2 plane and dot laser right? I have an older bosch 3 plane and use all 3 planes. With a 2 plane you won't be able to square up corners for framing or decking or flooring or anything like that. I probably use that feature the most. If I was spending that much again I would get the 3 plane for sure.
As for accuracy I used my bosch to layout 4,000 sq ft of tile for a restaurant remodel. I spent a full day laying everything out because it was going around multiple walls and dividers and all chopped up. Using the 90 degree planes(that the milwaukee you listed doesn't have) to square everything up and line everything up when going around a wall. When I tiled it everything lined up perfectly. Not sure what my accuracy is on that laser but I was impressed on such a big job. My bosch is around 10-12 years old now and still works good but I did think about getting the milwaukee 3 plane laser since I also have a ton of m12 batteries.
danski0224
Near Naperville, IL
Good luck even getting 30 feet outside in sunlight with a line laser and a detector.
I have a DeWalt 12V 3 beam 360*, and the detector was useless outside in moderate sun (just past the brightness level that washes out the beams). Same story with a small Stabila line laser and a universal detector. Both green beams.
Tried a different claimed universal detector from Johnson Tools, and that one didn't even work more than 15 feet away.
Note that not all detectors will pick up all beams.
The GC on that job had a DeWalt spinning point laser and detector, and that worked.
signcrafter
Something sounds off because I can do way further then 30' with my bosch and bosch receiver. My topcon rotating laser and receiver could pick up way way further. Doing concrete we used a milwaukee 3 plane and milwaukee receiver and could get 100' no problem in the sun.
tarbellb
Oregon
@danski0224 are you talking about the green plastic card or the actual battery operated pulse laser finder?
If the later then yeah, something was wrong w your setup, even my sub$100 3axis green lasers will pulse out to 75ft+ no.problem in full day light
OP sounds like you got money in the bank w HD but I'm also in the camp of
Buy the laser off Amazon or similar, get a 3 axis green guy, def grab a battery powered pulse finder. All in maybe $150-200
And spend the HD money on better tools, it's not the place to get a laser
One thought- check out the Bessey STE series of tripods and accessories. Killer system.
$60.... hard to go wrong
alinc100
Dearborn,MI
Can someone recommend a laser finder compatible with a Huepar green laser ?
I have the Huepar LR-6RG and it works just fine. Be sure your laser has a pulse setting or the receiver is a moot point. The advantage I've seen with the LR-6RG is it has a red/green light to indicate when you are correct. This is helpful when we use then to align two points on a floor from across the room. I can visually see when I hit the mark,I can't always here the audio.
Ultradog MN
Twin Cities
notes
lol
This!
110 feet of plastic tubing would be pretty cheap.
I added an 18'x 19' two story addition to our house. Made a water level to level the footings. When the city inspector came by to approve the forms before I poured the concrete he asked " Is that a water level??
I was a little embarrassed and said yes. Im cheap.
He laughed and said "No worries. That's what I used when I built my garage".
Then he told me that a simple water level is often more accurate than a lot of the cheap electronic ones guys are using now days.
Dig Doug
This!
Lasers work really good
although cheap lasers give a false sense of accuracy at some distances
and
the laser beam gets fatter wider and the beam fades - not a crisp sharp line
need to read up on em
but
look for +/- 1/8 @ 100 feet
