Above 1200 Sq/FT The Cow Pasture Garage - Australia
K
kitdoctor
Sunshine Coast, Australia
Post #0071g - War of the weeds – Tidying and solarisation continued - Part LXVI
This is the final update in Part LXVI #0071.
The next photo is of the downslope side of the swale drain as it heads towards the gully. Again, it’s dominated by Paspalum sp., whereas today (2026) it’s been overrun by clover.
I’d say the brown patches in the turf are likely the effects of spot spraying weeds with a broadleaf herbicide which tends to cause the turf to suffer slightly. Crows foot grass or Eleusine tristachya eventually became established in a patch to the left and this should be dealt with eventually.
Behind the shed the turf laid in the swale drain was responding well to being mown. Although the push mower was being used, the ride-on was also running over it. This explains the line left by the mower deck’s anti-scalping wheel.
I’d say too that a lot of the brown patches are from the mower deck scalping the turf. I know from more recent experience that’s it’s virtually impossible to avoid this, even with the deck set at the maximum cutting height.
On the bank itself, the Paspalum sp. has taken hold in the disturbed areas, creating the patchiness.
Again, the line left by the mower deck’s anti-scalping wheel is evident, as are the aftereffects of targeted spraying of Paspalum sp..
Behind the garage, the swale drain area is very compacted and the turf was struggling, looking thin and brown. Today, it’s got some thick patches of clover in it. Moving towards the fenceline, there was some nice Kikuyu, so that should develop well.
The last three photos show the bank above the retaining wall at the upper house pad site. This area was reshaped/regraded and thus was heavily disturbed and the regrowth is mainly Paspalum sp. and South African pigeon grass or Setaria sphacelata. This area was initially dealt with in January 2025 using a small machine with a mulching head attachment.
The swale drain itself had a couple of strips of turf laid in it but these didn’t extend to the edge of the retaining wall, hence the patchy areas and Paspalum sp.. The plan was to gradually spray the non-desirable grasses on the bank but the time for this never eventuated (what was I thinking!), so it was left alone. There’s ended up being some nice spread of Kikuyu from the upper areas of the bank into the lower areas.
Again, this swale drain is difficult to mow with a ride-on with a wide deck, as it has some tricky transitions, so there tends to end up being anti-scalping wheel marks post mowing.
The highlighted area is too unsafe to do on a ride on mower and I’ve found it has to be done with the push mower or brush cutter. The ultimate plan is to landscape the entire bank, however, that’s some time away.
So, that brings this series of posts to an end.
Next up, seven bales of sugar cane mulch are placed in various areas to manage weeds and grass.
K
kitdoctor
I've seen your posts on torinocobra for several years. I just notice the link to GJ so i came for a visit.
Hi @jarhead, now you'll understand what I've been up to.
It's been a huge undertaking and at times I've simply had to limit my time on Facebook, forum boards etc. etc.
As you know, I have popped up occasionally looking for a few parts I'm searching for.
I'm sure am looking forward to bringing the Torino home.
K
kitdoctor
On Bring a Trailer only four Torinos https://bringatrailer.com/ford/torino/ have ever sold for more than USD80,000.
One of those was a Cobra Jet (CJ) powered GT convertible and the three others were Super Cobra Jet (SCJ) Cobras. A fifth Cobra SCJ was bid to USD85,000, but at the time was a no sale. This car with less than 25k miles was the lowest ever mileage 1970 Torino SCJ offered on BaT.
In the fastback lineup for 1970, the Cobra was the performance model featuring exterior Cobra graphics on the front fenders or guards and rear tail panel.
Bid to USD85,000 27 March 2021. At Mecum this car has previously sold for USD110,000.
Sold for USD81,500 17 February 2023
Sold for USD85,970 25 March 2023
Sold for USD82,500 12 August 2025
Sold for USD83,000 26 June 2026
In 1970 you could only order a Ford Torino Cobra with a 429 cubic inch engine. Original Ford literature from 1969 lists three engine variants: 1) the base 4V engine, rated at 360 bhp, 2) Cobra without Ram Air, rated at 370 bhp and 3) Cobra Jet with Ram Air, also rated at 370 bhp.
In standard form the Cobra and Cobra Jet ran hydraulic lifters but by ticking the option for either a 3.91:1 or 4.30:1 rear axle ratio, the Drag Pack was added and both engines received different internals and were referred to as the Super Cobra Jet.
Somewhere along the line the three engine variants became known simply as the: 1) Thunderjet, 2) Cobra Jet (regardless of whether it had or didn’t have Ram Air) and 3) Super Cobra Jet (again regardless of whether it had or didn’t have Ram Air).
A one-year only engine option in the Torino, Ford made only 1475 1970 Torino Cobra SCJs, mostly with four-speed transmissions and Ram Air. The rarest SCJ Cobras are the non Ram Air automatic transmission equipped cars. Come 1971, the SCJ could only be ordered in the Mustang.
So, what did you get for ticking the box for USD155 for a 3:91:1 rear end, or USD207 for a 4:30:1 rear end:
  • 3.91:1 Traction Lock or 4.30:1 Detroit Locker.
  • Engine oil cooler.
  • Four-bolt main bearing block.
  • Forged aluminium pistons.
  • Solid lifters.
  • Solid-lifter high performance camshaft.
  • 780 cfm Holley carburettor and compatible intake manifold.
  • Single 3/8” fuel line.
  • No air conditioning!
True estimates of bhp are in the order of 425-450 bhp and gross torque of 480-500 lb-ft.
So, what’s the big deal about this latest 1970 Ford Torino Cobra SCJ? Was it really worth $83,000?
I’ll come right out and say it, that the result fits with the everything bubble.
The three big concerns:
  • Non-matching numbers engine block.
  • No engine oil cooler system.
  • No smog or pollution system.
  • No rev limiter.
Incorrect:
  • Distributor cap.
  • Vacuum diaphragm and possibly distributor.
  • Voltage regulator.
  • Ignition coil
  • Clamps (steel heater tubes, radiator hoses, bypass hose etc.).
  • Valve cover oil cap elbow.
  • Radiator cap.
  • Transmission shifter handle.
  • Trunk/boot mat.
  • No horns.
Day 2 modifications or non-concours reproduction parts:
  • MSD box.
  • Spark plug leads.
  • “POWERED BY 429 SCJ” valve cover decals.
  • Rubber heater hoses.
  • Radiator hoses.
  • Headers (missing cardboard heat riser tube and Wittek No. 34 clamp and cast iron exhaust manifolds).
  • Solenoid activated exhaust cutouts.
  • Rear air shock absorbers.
  • Shelby Magnum 500 wheel centre caps.
  • Exhaust system clamps.
  • Turned down exhaust tips (missing chrome exhaust tips).
  • Grille Cobra badge.
  • Corrugated PVC split tubing for wiring.
  • Front spoiler.
  • Fuel filter.
I truly think the buyer got carried away with the auction. IMO this car was a sub USD50k car.
Geoff289
Melbourne, Australia
I don't know my Torinos but not having the original engine reduces the value very considerably.
Until '67 Mustangs, and quite possibly all Fords, didn't have engine numbers. The concourse world relies on the casting date being within a few weeks before the car's production date (but there were all sorts of production line variables that can mean there can be a longer time difference between engine block casting date and car production date).
I drove the seller of my current Mustang nuts to get the engine casting date to satisfy myself I was buying a matching numbers A code fastback. It's on the side of the block just above and concealed by the starter motor. This was after getting casting dates and codes for the heads, transmission and numerous other components.
Like everything else, classic cars are ultimately worth what someone's prepared to pay for them.
K
kitdoctor
Post #0072a - Long overdue - Shifting and placing mulch - Part LXVII
Way, way, way back in mid-2024 we bought seven round bales of sugar can mulch. The intention was to place the mulch in certain areas to reduce the amount of work we were doing and make mowing easier. So, around the rip rap at stormwater headwalls, up against retaining walls etc.
Also, I forgot that this was when we bought our Hi-Cube shipping container. The container was to provide some lockable storage for garden tools, some building materials, Facebook Marketplace purchases etc. The long-term plan is to roof the shipping container (to capture water) and turn it into a garden shed.
The day the mulch was delivered we were house sitting at a location about a 45-minute drive away. I’d prearranged to meet the delivery driver at the top of street to discuss the plan for access. Also, I did pre-warn them that access in was possible for trucks but nothing bigger.
Anyway, Murphy’s law intervened and for the first time ever I misplaced the car keys (later found under the doona on the bed), plus the driver (of a truck and trailer) didn’t wait as agreed, drove down the street and turned into a neighbour’s property to avoid getting stuck at the end of the cul-de-sac.
So, the best the delivery driver could/would do was unload the bales at our neighbour’s place which they’d kindly agreed to. So, that meant the bales were now nowhere near where we wanted them placed and somehow, we’d need to move them.
Now these things weigh around 200 kg (440 lb) and ideally you need a small tractor fitted with bale spears to lift them. Yes, we had a trailer, so we could move them one at a time, but we didn’t have access to a tractor and moving them one-by-one drawing upon the phone a friend option wasn’t that appealing.
So, the solution was to combine moving the bales with the task of relocating and placing the shipping container into position.
Here’s the shipping container being delivered. In preparation for this I’d bought six concrete filled blocks off Facebook Marketplace and set these up in a grid pattern.
Shipping container hooked up with chains and ready to be lifted.
Lift off.
Swinging the container into position.
Lowering the container onto the concrete blocks.
Once this was done, the next task was to collect the bales of mulch.
This next photo just happens to show where the bales really needed to go to. The upper house pad and retaining wall can just be seen on the left-hand-side of the photo, just below the lone tree that’s in the distance.
Continued below.
K
kitdoctor
Post #0072b - Long overdue - Shifting and placing mulch continued - Part LXVII
Fast forward more than year and there was now sugar cane growing out of the sugar can mulch.
As we didn’t have a tractor, all the mulch was moved using a wheelbarrow. Here’s yours truly breaking up and loading mulch into a wheelbarrow.
Given my brush with death from a serious skin cancer, I now fully cover up from head to toe.
First cab off the rank for mulching was the rip rap downslope from the concrete water tanks. This may need some explaining, "first cab off the rank" is an Australian/New Zealand idiom meaning the very first person, organization, or thing to do something, take action, or seize an opportunity. It signifies being first in a series or at the front of a queue.
After this, the three areas (only two photos) of rip rap at the larger headwalls were done.
This first area of rip rap receives stormwater discharge from areas above and adjacent to the upper house pad.
This next area of rip rap receives stormwater discharge from areas above and adjacent to the site of the garage. Not shown is one of the areas of rip rap downslope from the shed.
Next up, the perimeters were mulched on the downslope side of the concrete water tanks.
Then, the upslope perimeter area was done.
To finish the whole area off, the area between the southern concrete tank and retaining wall at the lower house pad was mulched.
To be continued below.
Coolabah
2nd Floor, 3rd on the Right,Narooma, Australia
Fast forward more than year and there was now sugar cane growing out of.......<snip>
Sweet ! (literally)
If it were me I would try chewing the sugar cane. Never tried it , but it's on my bucket list
YMMV !!!
Progress: Looking good all round :)
K
kitdoctor
Post #0072c - Long overdue - Shifting and placing mulch continued - Part LXVII
The last stage of this exercise was to place a row of mulch against the bases of all of the retaining walls.
Here’s the first completed row placed at the lower house pad’s retaining wall.
The retaining wall here varies in height from about 1.4 m (≈4’ 7”) to 2.4 m (≈7’ 10”) at its highest point.
Over at the shed, the area around the rip rap and up against the retaining wall was mulched. The latter was simply inaccessible to the ride on mower.
The headwall shown is the discharge point for surface runoff collected by the perimeter drainage system that is installed around the slab of the shed and also some of the roof water runoff that isn’t directed to the storage tanks.
The retaining wall is just over 1 m (≈3’) high at its highest point.
The remainder of the base of the retaining wall was then mulched.
At the north end of the retaining wall, near the water tanks, is the dumping area we designated for rocks.
Finally, the last section at the base of the retaining wall next to shed’s lean-to was completed.
That tiny head wall is the discharge point for the sub-surface drainage system for the adjacent sections of retaining wall.
I seem to recall this exercise took a few weeks to do, working off and on. The 10,000 step challenge was regularly achieved.
Next time we should have a tractor available, that can be used to move the bales closer to where we’ll break them up and spread the mulch.
Coolabah
Great progress !
Forgive me for my lazy question- I sometimes forget what I own in my own shed so have no hope of remembering what's in yours !
I know you have a ride on lawn mower that we discussed, have you considered getting an orchard size (so, smaller) tractor ? You can never have too many machines as long as your block is not smaller than 20m x 20m ( maybe like 22 yards x 22 yards for our unmetrificationluddenitenised friends- no insult intended but I love making up words and could not help myself. I was unstopifyable ) . My theory is yet to be disproved and no GJ member will EVER break that code where our spouses might read it:
"Too many tools and machines are never enough :) "
K
kitdoctor
@Coolabah, yep, we went through the process of speccing up a Kubota sub-compact tractor. We settled on:
  • Kubota B2601 HD - 26 hp 4WD tractor with hydrostatic transmission
  • McCormack FA35 detachable loader arms with quick attach/detach Euro implement hitch (Kubota Australia don't have an equivalent)
  • McCormack 4 in 1 bucket with bolt on edge
  • 60" Kubota mid-mount mower
  • 48" Land Pride rear slasher
  • Canopy
  • Industrial tyres.
We've since purchased a rear quick hitch, rear carryall, Rapid Spray 250 L spray unit including boom spray, pallet forks, bale spears, a front tow ball hitch and a front lifting boom. I have planned to do a detailed post on it.
K
kitdoctor
Post #0073a - Upper house pad - Shipping container surrounds tidy up - Part LXVIII
Sometimes you miss taking the right photo needed for an update, and so was the case for this first photo. Our weeding and tidying efforts had generated a large amount of green waste which was being stockpiled behind the shipping container.
When this tidy up was started the compost tumblers were still some time away from arriving, so we decided to cover the pile with black plastic. The was done with the intention of turning it over from time-to-time, adding water as needed and seeing whether it would compost insitu.
That’s the main piece of a Camphor laurel or Cinnamomum camphora tree in the pile. It’s considered an invasive plant and its location was going to be too close to a future retaining wall, so it was removed.
Behind the shipping container is a pile of spoil. It’s a mixture of topsoil and red volcanic dirt. It was saved for future landscaping. Largely covered by grass and weeds, there were also a few wild tobacco trees, some of which had been poisoned and died.
The plan was to pull out the dead wild tobacco trees and break these up, as well as pull out the large weeds. First up, it was tackled from the container side.
This work generated more compost piles.
That’s the wife mowing the swale drain.
Continued below.
K
kitdoctor
Post #0073b - Upper house pad - Shipping container surrounds tidy up - Part LXVIII
The pile was then tackled from the southern side.
By now there was a pallet full of sticks.
Then, more compost piles were needed (next to the Hilux).
The next photo is after some raking and sifting out the rubbish. We ended up moving the pallet and sticks. At this stage we were undecided where the compost tumblers would be located and ultimately we had to move the pallets and sticks again.
Well, job complete.
Now 12 months later in mid-2026, after returning from Darwin, we’re back tidying the same areas again :LOL:
K
kitdoctor
The work never ends.
@Geoff289, similar story for classic/muscle cars 😩
We are back from Darwin having completed the two tasks I have been dreading for years: 1) disassembling and shipping my four-post vehicle hoist and 2) transporting three cars including the daily driver. So far, so good, all have arrived safely.
I was going to return to the build but I'll weave in a few posts from the two months we spent in Darwin doing uplift number 3.
Cris B
Lancashire, UK
Well that’s been a fun couple of days catching up with your progress and the builds. Did you get your waste water unit wired in yet? That felt like the only thing really holding you back from moving in.
Having renovated a few places in the past, living on site lets you do so much more in a day. I remember having pushed it too hard one day and falling asleep on the drive home - fortunately I was not the driver!
K
kitdoctor
@Cris B thanks for bingeing on the build thread and taking the time to comment (y)
Yes, the build thread is looking back in time and that hurdle was overcome. I do wish the time delay between the build thread and present day was smaller but it is what it is.
The wastewater system had to be functional and a council plumbing inspection completed and passed before I could request a final inspection by the (private sector) building certifier. The only concession that the certifier would allow was that they did not insist upon council's written approval being received, simply because council are so slow to issue the written approval.
The last couple of months I've been burning the candle at both ends...We were essentially in Darwin for two months but I did duck back for a week to meet two of the cars that were moved from Darwin, then returned to disassemble the hoist and be present for the uplift.
K
kitdoctor
Post #0074a - Construction work continues - More progress at accommodation module - Part LVIX
With the internal fit out of the accommodation module getting underway, it was time to revisit some material selections to confirm specific choices and ensure they were still available.
Our interior design style is a blend of Hamptons and modern farmhouse. Typically, this includes natural materials, such as light timber floors, linen slipcovers, jute rugs, and rattan or wicker furniture. Colour palette wise, it could feature crisp whites, soft creams, pale greys, and ocean blues or navy.
We ruled out a timber floor for the downstairs level for a variety of reasons but mainly cost. We did want a uniform floor material choice that was easily cleaned, so a tile was the obvious choice.
To incorporate timber, we decided that the staircase and hand railing would be done using reclaimed timber. Two key choices were needed, a hand railing and floorboards. We made an appointment at Kennedy's Timbers at Narangba Queensland and went down for a morning.
First choice was a chunky 5+ m (16+’) section of Blackbutt staircase handrail with a 120 mm x 75 mm (5” x 3”) cross-section. This would be wire brushed to give it a distressed look.
Next was a tongue and groove floorboard which was also Blackbutt with a cross-section of 131 mm x 19 mm (5” x ¾”).
Here they are delivered to site and a close-up photo of an off cut.
Next up we decide upon the bedroom carpet and vinyl tile for the workshop and mezzanine storage room.
K
kitdoctor
Post #0074b - Construction work continues - More progress at accommodation module continued - Part LXIX
For bedroom carpet we decided upon a 100% wool pile fibre to achieve a balance between softness and durability. Typically, these cost about $50-$150+ m2 (10.8 ft2), excluding installation.
The specific selection was a carpet made from New Zealand wool (they have the best sheep!), Oakford Square which is certified by Wool of New Zealand. Its pile height is about 8 mm (5/16”) high. It’s produced by Prestige Carpets, although we sourced it from Kelwin Coastal Carpets here on the Sunshine Coast.
This is the darker colour carpet, Colony.
This is the lighter colour carpet, Eldon.
Here are the two choices side-by-side. For a stronger contrast between the wall colour and to hide minor stains we went with the darker colour, Colony.
In terms of luxury vinyl tile (LVT) three names come up consistently, Amitico, COREtec and Kardean Designflooring.
We went with the latter and limited our choice to products made in South Korea, mainly because they’re known in the industry to be perfectly rectangular. LVT typically costs between $25-$85+ m2 (10.8 ft2).
We looked at a couple of shades of grey that would work with the colour of the epoxy floor coating that was proposed for the main shed area.
First up, a plain, lighter grey, Nisida, with slate grey concrete tones.
Next up, this is Vermont, a gunmetal grey colour with a stone-look.
Here they are side-by-side.
Ultimately, we went with Vermont with the black flecks to tie into the proposed matt black DIY steel cabinets and shelf units.
