Between 265 & 485 SQ/FT Nick's Two-Car Detached Vdub Garage
Denwood
Thunder Bay, Ontario, Canada
Funny thing..your basement home theatre switch setup is virtually identical to mine :) With my setup, I put in a aeotec micro relay in the box, so the manual switch works, but I can override it with the automation. One thing that HUE got 100% solid is the fact that even if the lights are powered off, they never lose connection with the hub!
N
nicholam77
Minneapolis, MN
Interesting, yeah, that is a clean way to do it. I only just started experimenting with relays on some light switches in the kids rooms (sonoff zbmini). One of them is not responsive to remote commands, I need to do some troubleshooting.
I do like having the Hue Dimmers on the wall as well, as they are a nice scene control remote and easy dimming.
Agreed!
N
nicholam77
Minneapolis, MN
Please not be water pump. Please not be water pump. Please not be water pump!!!
Got an alert when dropping the kids off for school this morning on low coolant. I pulled over and it was indeed *quite low*.
There appears to be fluid / residue on the plastic under plate of the bumper below the water pump. It's also raining fairly heavily this morning so it's a bit hard to tell if it's coolant or if it's leaking on the garage floor.
But I have a bad feeling about it.
N
nicholam77
Minneapolis, MN
Thats a bummer, but its a known issue with that engine.
Sounds like you may need to go see the guys at Further
Yeah, if that's what it is which I'm sure it probably is, I was expecting it to happen at some point. I'm only at 60k, but some have gone quite a bit less than that especially the earlier model years like mine.
I had an insane day at work today, but I was working from home, so I went out to the garage to take a quick look at lunch. The rain drips on the floor had dried up, but I did notice these two spots on my dirty *** concrete:
I stuck a piece of cardboard under to get a "clean" read.
Came back out around 5:30pm and nothing was on the cardboard. So either it slowed or stopped leaking.
But the reservoir was looking even lower I think? It's almost empty.
I had some G13 on hand, so I mixed some up 50/50 and topped it off.
And then ran the car for a few minutes and did some revs.
No immediate discernible drips on the floor.
After dinner, still no drips on the cardboard, and reservoir level is the same.
But... I haven't removed that plastic underbody panel that it's dripping onto on the inside. So it might just be catching on that and not spilling to the cardboard beneath.
Either way, I think it's a slower drip, and not a 'dump all the coolant immediately' situation.
I'm hoping having topped it off, I'll be able to drive it to a shop to get checked out.
Busy all day tomorrow but Sunday I might throw it up on jack stands and remove that plastic piece and see if I can get a better look from underneath.
If it is the water pump, I'm hoping an independent shop can remove the intake manifold and do a carbon cleaning at the same time, because I'm probably due for that, too.
N
nicholam77
Minneapolis, MN
Got the car on stands to check it out this afternoon.
Without much space to work, I increasingly like using the small driver + Torx bit from the Wera Toolcheck Plus to remove VW trim screws.
I could tell right away where it was dripping off the trim in multiple spots.
The Torx screw right in the center (about directly underneath the water pump) had somehow dissolved. As in the Torx "teeth" were no longer there and it was all rusty. Hmmmm. I was able to get it out with my Knipex Twin Grip. Part of me wonders if coolant dripping on the screw was what made it like that.
And yep, that trim piece has lots of residue on it. Clearly a combination of old dirty stuff and new fresh stuff.
For a moment I thought it could actually be oil because it was very dirty and black and there was residue on the oil pan as well.
However after shining my light up in there, I could see the seam where the water pump and thermostat housing mate was drippy and corroded / gunky. Everything directly below it — hoses, wires, etc had crusty gunk built up. Clearly has been leaking for awhile.
What kinda pisses me off is last time I was at the dealer for the suction pump recall, they did a "full inspection" with a video, and said everything looked great. I'm sure it was leaking at that time. It would have been obvious if that trim piece was wet. The fact that this was completely missed (and they didn't inspect anything under the engine) is annoying. They should have at least seen that the oil pan was all wet.
I myself have not been under the car in a minute. The last few oil changes I've done top side with an extractor. I guess this is a reminder to get under there once a season and take a look.
Hard to take pics of because it's really crammed in there, but the silver + black bit is the water pump / thermostat connection.
All the brown stuff on the bolts and hoses below is not rust, it's goop.
It's discolored and goopy.
The water pump part looks like this (arrow same as pic where it's probably leaking from.
Reservoir still looks good from my top off. I have to be in my work office downtown tomorrow — I might try driving the car and put some coolant mix in my trunk in case of emergency :ROFLMAO:
But other than that, I need to get it into a shop asap.
I've watched DIY videos on replacing the water pump, and while it's well-documented and I would def save some money, it looks like a huge PITA and time that I don't have.
Looks like parts have gone up, too. FCP Euro has a 3rd party DIY kit for $380, and the genuine VW-Audi one is $780. Which includes the water pump, thermostat, belt, connector piece, coolant, and intake manifold gasket. I feel like I want genuine parts.
Unfortunately VW really buried it in there so it's labor intensive. Will report back, but I'm fully anticipating a quote of around $1500 or more.
I won't lie... this car is starting to drive me bonkers. This, plus whatever the rust fix ends up being (haven't heard anything on the VW warranty yet, losing hope on that), plus carbon cleaning, and a few other items like plugs etc, and I'm probably going to be looking at $5k to keep it on the road minimum. And I don't want to put it through another winter without getting the rust fixed. Or maybe ever. Oh yeah, I forgot I need to do brakes this fall, too!!
Nothing is fully formed, but I'm having strong thoughts of getting my wife get a new car, having me keep her old one (CX-5) as a winter car, and getting the GTI fixed but keeping it as a spring / summer / fall car... non-daily. Or at least non-essential as in I can decide not to drive it any given day. All of that would be a big cost, but my wife is going to *need* a new car sooner than me, anyways, and I really don't want to buy two new cars at the same time, so this would keep the GTI and once I get over the repair humps I would feel much more inclined to do something like attempt to DIY an aftermarket clutch, and go full stage 1, or even add a downpipe and go stage 2. I could actually do bigger mods like that if I didn't depend on it to get to work and drop the kids off.
All thoughts kicking around. But need to get the water pump sorted first priority.
fourmotioneer
Ann Arbor, MI
I think you can do the water pump at home if you have a day to burn. The DIY doesn’t look that bad. Also doesn’t look that fun. And burning a day on your daily is risky
N
nicholam77
Minneapolis, MN
Yeah, I've watched some videos. I think I *could* do it, but my normal experience is it always ends up being harder than I think it will be, and right now I just don't *want* to DIY. I am so strapped for time with work at the moment, still having chronic inflammation / low back muscle pain issues, and not in the mood for a big messy car project right now. We've had so many summer 'obligations', it's hard to find a day to burn, even on the weekend. I think I would need a full uninterrupted day, more if I struggle with it. I also think I'm burnt out in other areas with work and such.
The other thing I was hoping is if they need to remove the intake manifold (seems like this is common with DIY, but not sure if the dealerships do it?), I am hoping they can walnut blast the valves (carbon cleaning) while they're in there. Something I also don't want to buy tools for or tackle at home. I'm low miles, but my commute is short and I do a lot of start stop driving (rush hour, city streets). I'm basically worst case scenario for carbon build up.
But... if the shops give me too high a number, I might reconsider on DIY. Going to make some calls tomorrow morning.
That's one thing about possibly relegating the GTI to non-daily status in the future... I would be much more likely and able to tackle things like this on my own timeline, instead of relying on it for commute and transporting kids.
jonshonda
Wisconsin
Bummer about the reoccurring water pump failure, or I guess you could maybe say that it as a shorter service life then expected? I've done a pretty good job of packing a lot of activities into my weekly schedule, and what I've found is that I am operating right at the edge of my ability to keep up with maintenance. I like my stuff very clean and in excellent working order, and it's not easy with a busy work schedule and a young family to keep up.
I've really been toying with the idea of going German for my next vehicle, and from what I gather as long as you replace things or "anticipate" replacing things ahead of schedule you should be gtg. I've also never been satisfied with dealership's serviced dept. When I had my GX470 timing belt service done at the dealership I left a $40 cash tip under the hood for the mechanic. To show his appreciation he left me a bit of a mess to clean up, leaving greasy finger prints and smudges easily noticeable in what was a very clean engine bay.
N
nicholam77
Minneapolis, MN
Yeah, although from what I can tell it's a "when" not "if" sort of failure on this engine. Low miles, sure, but I got 10 yrs. I've read online anecdotes of people's water pumps failing after only 15-20k miles, and some having the replacements fail down the line as well.
From what I understand the heat from the engine causes the plastic housing to warp or crack over time, causing leaks.
I figure I'll get at least another 60k miles with a replacement, maybe more, which with the amount I drive should last me another 10 years.
The good news is the water pump is really the main concern on the EA888 Gen 3 engine. That and carbon build up. Aside from that, the MQB platform / Mk7 Golf is pretty reliable.
I hear that and I am the same way. I hardly even find time to get the car washed, which I feel guilty about.
Yeah, I would just make sure there aren't any specific failure points red flag failure points (like the Porsche IMS bearing failure for example). I know some Porsche / Audi / BMW models have some quirks to watch out for, but it just depends on what you're looking at.
VW used to have a worse rep with electrical issues and such, but I think once they moved to the MQB platform across most of their fleet, things have gotten a lot better. The engine in the GTI is in many Audi / VW products, and aside from that water pump issue is basically reliable. Aside from the suction pump recall and now the water pump, I've basically had zero issues with the car.
Overall I wouldn't be scared of German cars as long as you feed it quality oil and stay on top of regular maintenance. Yeah Honda and Toyota and Mazda are *probably* a safer bet, but I feel like all new cars have super complicated electronics and engine systems these days. I don't know that German necessarily means money pit compared to other things like it maybe used to a few decades ago.
fouckhest
Greer, SC
***** to hear the WP is on the way out, that is NOT a fun job at all, not really difficult, just time consuming and the, "while your in there" list is certainly worth doing.
Id highly recommend farming that out, speaking from experience, by the time you get into the carbon cleaning, you are certainly locked in for more than a one day job. I worked on the CC over the period of a week, but that was mainly so I could flood the cylinders with degreaser/brake clean, etc to get the carbon softened up, then used a series of picks to scrape it all off and then sucked out with a shopvac.
Knowing your back issues, that would be a killer for the amount of time you'd be leaned over the engine.
Happy to chat about any details if you want!
Denwood
That is NOT cool.
gearhead1960
I hate extended warranties as I never believed in them. The first one I bought was on a 92 VW Passat (4 cyl) only after I beat down the dealer on pricing. I think we paid $700 for it and thought that was way too much money then. However, it did end up paying for itself after several electronic items failed, such as the HVAC controller unit. Regardless if the car is German, or Asian, I worry that the electronics and/or computer will be an expensive fix and have bought the extended warranty only for that. I bought it on a 2022 Outback that we recently got rid of, because we ended up hating the car and actually was able to get a refund on the unused part of it. We recently bought a CX-5 and even though I hated the pricing on the extended warranty, bought it on the wife's insistance. As far as whether you buy German or Asian or English, knowledge is your best weapon. I bought a 2017 Mini Clubman (BMW X1) and have had fairly good luck (no extended warranty). German design, English made. It has it's known issues just like the VW or Porsche products. I've kept up the maintenance on the lubrication and cooling system in hopes that it will forstall any of the known issues.
N
nicholam77
Minneapolis, MN
Thanks for your POV, Mike! I'm 99% leaning towards a shop doing both of those things. I contacted a few in town that specialize in Euros (including Further). They are all around the same cost, which is about $2500 to do both jobs. Interestingly Further said if they just did the water pump alone, they would do it without removing the intake manifold.
Question for you... I know it's hard to know what the carbon build up looks like until you open it up, but do you have any POV on what I might expect? I guess I'm wondering given my low miles if I could wait on that, or if you think after 10 yrs / 60k / mostly short trips, that I'd be due to get it taken care of? I've never had carbon cleaning done on a VW or any car, and not sure what to expect, I was just assuming it might be a good thing to tackle at the same time. But of course it's expensive.
Trying to weigh these items in addition to the rust repair if I end up paying out of pocket for that, and how much money I want to dump into this car in a lump sum before winter.
Also... any other "while you're in there" items I should consider?
Thanks!
You do. As doing it once is annoying and doing it twice would be a proper PITA. Always gone genuine VAG parts for this job on my Audis and the VWs.
Dont cheap out, you dont want to do it twice!
For sure. I don't know if it makes a difference for some stuff, but I am kind of OCD about using official VW parts. Not sure what they changed but I think they're on revision 3 or something for the water pump, I definitely want to make sure it's the latest one and OEM quality. Although considering how often they fail, I'm not sure that's really saying much :ROFLMAO:
fouckhest
Greer, SC
Thanks!
No worries at all.....so thoughts:
Carbon cleaning, I would expect if Further doesn't remove the intake, they will have to remove the throttle body, in which case, you could ask them to bore scope it and see what it looks like. I did the CC at 97k, it wasnt bad, but there was certainly some build up, in my ~55k miles of ownership, I know I always used 93oct, and only remember one time my wife put 87oct. All that to say, ask them to check it out and see what they say.
The other thing to consider is you are just over 1/2 way to the timing job, but I would again default to the shop to check the tensioner, if its the newer one, you might be fine to ride it out.
I can't think of too much else, other than making sure they give all the plastic coolant hoses a good once over and replace anything that is suspect.
I think most of the time with those engines the cam seal starts to leak, which ends up dripping down the water pump, so that is where the whole can '0 worms gets opened up.
As far as overall comment, and I think you are there already, BUT, I think your GTi is worth getting back in tip top shape, that is a fantastic platform and if you did a chip on it you'd fall back head over heels in love with it. Those cars IMO are a sleeping giants for an all around great car, so I think its a good long term move to fix the little things and plot moving it to the fun/2nd/fair weather car.
my $0.02:beer:
gearhead1960
Older Minis used to have the carbon build up issue also (none Mini engine). My Mini is Gen 3, with the BMW B46/48 engine that is supposed to be immune to this issue. I have my doubts that it is completely immune so I've been using fuel system cleaners on a regular basis that contain "PEA (polyetheramine), which is the industry-standard, high-performance detergent additive used in premium gasoline treatments to clean carbon deposits. PEA is a powerful nitrogen-based detergent molecule added to fuel system cleaners." (Thank you AI) You want one that contains 30-40% PEA in the treatment. One of the highest rated cleaners (what I use) is the Redline SI-1 Fuel System Cleaner. Is it preventing carbon build-up? I can't be sure, but I figure 15 ounces preventative is worth it every oil change.
N
nicholam77
Minneapolis, MN
Thanks Mike, I appreciate your experience and POV. I will ask them to see if they can scope it, although I was reading they still can't really see the back of the valves if they go in through the throttle body but maybe it would still give some indication on how it's looking.
I think I am going to skip it for now, though. I need to sort this rust problem first. If I can get that fixed properly and know I will be keeping it long term then I will go back and do some of this other stuff. I think right now my priority is to get the water pump fixed and it drivable, and then get the rust tackled. Then everything else.
Because if I can't get a satisfactory solution for the rust, I may have to think about if these other things are worth it or if I should just get into a different vehicle.
Fair, wasn't even thinking of that. I'll ask them to check.
Yes, that's ultimately what I'd like to happen. KBB says my car is worth $11-$13k even with my super low miles, and of course that doesn't factor in the rust or the well over $5k in parts I've put into it over the years. I would think any private buyer / enthusiast would be scared of the rust. It's not much to work with. It feels nuts to probably spend $6k on a 10 yr old car only worth $11k, but I agree with what you said. It's practical. It's manual. It's exciting *enough* for me and I can cart the kids around. I've personalized it. There's nothing else out there that interests me that would be an investment exponentially more than what I could sell for.
It does have a mild stage 1 tune at the moment, but if I can sort a 2nd car for myself and fix all the needed work, I would love to go a little further with it.
Interesting. I've never used a fuel cleaner before. I could be wrong because I am no technician or engine expert by any means, but I'm not sure that would do much to prevent carbon build up on the intake valves? The reason it's a problem on these engines is they are direct injection, so the fuel never cleans the back of the valves since it's injected directly into the cylinder below. And then the PCV system reroutes oil vapors back into the intake air, which builds up on the valves. But... it couldn't hurt to clean the rest of the fuel system.
N
nicholam77
Minneapolis, MN
Some small updates.
I Got Scammed! :mad:
It's my own damn fault, and I'm mad at myself.
So I have a saved search on Craigslist set up for anything Festool, just hoping a deal comes along. Stuff pops up, and it's always expensive. But you always hear about someone not knowing what they have... a partner selling their spouse's tools on the cheap, etc. Many stories like that right here on GJ — "I got X tool for $5"! Everyone: "You ****!"
So a few days ago I wake up to this, posted just a few hours prior. Figured I had a chance.
So I message the person and it all seems fine at first. They are responsive, we have friendly back and forth, said it was still available. I offered to send a deposit for them to hold it for me, since this is basically the deal of a Iifetime and I figured people would be going nuts for it. I find out they are located in Duluth MN. This is about 2.5 hours away from me. They offered this up before they knew where I was located. They verified the machine was in good condition. They said they would hold it until the weekend for me if I wanted to make the drive if I gave a deposit, OR they offered to ship it to me.
I should have realized that was a terrible idea to have it shipped. But it's a Domino. Plus accessory kit. For $300. I thought this was my big break. :ROFLMAO:
I asked to use PayPal Goods & Services and cover the fee, but they wanted to use Zelle. Huge red flag #2.
But it was a Domino. For $300. So unfortunately the heart defied the brain here, and the deal progressed.
It was bizarre, though. They quoted me shipping to approve. It all seemed plausible in my head. Even after I sent money., they stayed in contact with me. Said they were going to get it sent out that day, said they would get me the tracking number I requested, etc etc.
But in those later messages, I started noticing some weird spelling errors. Didn't think too much at first but in retrospect I almost wonder if the person communicating with me had changed.
They never provided the tracking, so I kept bugging them, wanting some reassurance, and eventually they sent me a picture of a FedEx truck, saying it had just "picked up" the package. Well I've been to Duluth many times and I can tell you that pic was not in Duluth. And the truck did not have MN plates. And that's not how FedEx works.
Immediately I realized I'd been had. And with Zelle... it's a wire transfer so... you can't get your money back.
I called them out on it, and demanded my money back ($375), but they ghosted me.
I reported it to my bank as a dispute, and to the FTC fraud reporting, and flagged their ad on Craigslist, but I'm sure nothing will come of it.
I'm mad at myself because there were signs, and my stupid brain chose to ignore them. And now I'm out $375 and I still don't have a Domino. :ROFLMAO:
Anyone else done something dumb like this or just me?
GTI Update
Coolant has more-or-less been holding as I've lightly driven it the past week or two. But a couple nights ago she started drippin' again, significantly. Dash light didn't come on this time, but pulling in the garage I smelled sweet smell, seemed hot when I popped the hood, and sure enough I saw drips all around my driveway and alley, and immediately on parking it was dripping on the cardboard. Reservoir almost empty again.
Haven't driven it since. Topped it off again.
So I biked to work today, 14 miles round trip. Minneapolis has an amazing trail network for bike commuters, so at least there's that and I was able to get to work without driving.
I have an appointment officially booked to get the water pump taken care of, but it's not until 8/25 I could get in. I'm going to try not to drive it in the meantime until I have to drive it to the shop.
Clamp Storage
To end on a more positive note, I did something in the garage. Something small but felt good nonetheless.
I 3D printed some holders for my MFT quick clamps a super long time ago, and decided to make a little plaque to finally mount them to the wall and also store my Bessey in-line MFT clamps.
No real plan, kind of impulsive, I screwed it to the wall above the MFT for now.
Thanks for reading, I hope to have more interesting / better things to share in the coming months.
Xti04
Zelle, cash app, always make me raise my eyebrows to a scam. That being said, I literally just sent 6k to China via stripe, which I had never used before for my truck camper setup. I felt confident to do that only because I had seen YouTube videos by people who had purchased from this company before. Sorry they got you, hopefully they get caught or busted.
cccoltsicehockey
Charlotte, NC
Bummer on the scam. It happens. Not a no product received SCAM but I got sold a complete fake of a discontinued JDM hood for my NSX several years back after paying for it and freight delivery to receive it. I even paid with PayPal. The hood plus freight was $2000 ($1400 for the hood, $600 freight). It wasn't till I had spent $500 at a body shop to get it prepped for paint and everything that we realized it wasn't real. They had gone as far as to replicate the metal badge on the underside of the hood out of fiberglass. I was told the hood was already primed to be painted. That should have been my tip off since who would have painted over the metal authenticity badge. PayPal offered to only let me get my money back if I paid to ship the fake hood back. For some reason, shipping the hood back to Canada was now $700 and they were only going to refund me for the product and not the shipping. I decided to just take my loss and move on.
N
nicholam77
Minneapolis, MN
On the scam…that massively ***** :-(. On the GTI, that ***** too, but at least a fix is in sight :)
Yep, live and learn!
For sure. I think deep down my gut knew it was wrong, but I was too swayed by the 'deal'. And to an extent it seemed believable until it wasn't.
Hi Nick
Sorry to hear about the scam, don’t beat yourself up over it, deep breath and move on.
**** em, they’ll get there’s.
Great festool print out
Steve 🍻
Thanks Steve, and agreed!
That gave me a good chuckle Brad :ROFLMAO:
Wow, that's rough!
Bummer on the scammer and the car....but at least you've got the car booked to get fixed up!
Thanks, Mike. Yep, it's going into Further on Tuesday. Will be glad to at least have the water pump behind me.
Bad news from the dealership :mad:
I've been bugging them for an update since it's almost been 3 months since my corrosion warranty claim was submitted (or so I thought). Multiple voicemails to the tech who took my rust photos with no returned calls. Finally got ahold of him and he said he would contact their body shop for an update and call me back. Never calls. So I call back the next day and talk to someone else. He says he can't find the photos. I press him for how this whole thing works (they've been very vague about it), and he said after they take the photos they upload them to a shared document that both VW and their body shop can see. Well he's looking through a stack of physical papers on his desk, all rust claims I presume, and can't find my info. And can't find the pics in their system. So I ask if the original guy is working and he says yeah and goes to track him down. Leaves me not on hold but just puts the phone down for 10 min and comes back. Doesn't put the original guy on the phone, but instead tells me he can't find the photos he took either, and that he'll have to call me back tomorrow. Says the original tech was having some family emergency around the time I came in and was traveling back and forth to Wisconsin and might have misplaced them. Literally WTF?
I said "WHAT?????!!!!" This was morning time. You can't manage to call me back this afternoon? Nope, Says they have other customers to deal with and rushes me off the phone, talking over me, basically hangs up on me.
I was so pissed.
So he does call me back today around noon, and says they can't find the photos. Yeah well no ****, I pretty much assumed as much yesterday. So the body shop didn't get them, and the claim wasn't submitted. They pissed away 3 months. I had called multiple times during that time and they told me "it takes awhile". Unbelievable.
So now I have to go to the dealer to take new pics and start over. He claims they will try to expedite it for me, but I have literally zero faith in anything anyone promises me any more.
I've been burned by dealerships many times before, but I am absolutely dumbfounded here. I can't take the car to get new pics and new claim going until after the water pump job so that will waste another week. PLUS he told me their body shop guy is on vacation this week anyways. Go figure.
I am very close to just paying out of pocket and begging the collision center I found to do a good and thorough job. It's a lot of money so I feel like I should attempt the warranty thing one more time in hopes they can push it through, but my hopes are really dim.
Summer's almost over, winter is around the corner. Really feel like time is running out, and not sure the car can survive another winter.
On the plus side, I did wash it for the first time in forever, and clay bar.
And cleaned the interior.
I hope to do another wash and then wax / sealant.
Even though I'm frustrated right now, I still really love the car, and it cleans up good.
Xti04
You need to go to the service manager or general manager of the dealership. Thats unacceptable, and the delay it has caused is beyond frustrating. Hopefully they generated a repair order on the car when you took it in 3 months ago which would help you with askong VW if you have to go over the dealers head to get it resolved. When I worked for Audi back on the day we had a 12 yr rust/ corrosion warranty, but it was always tough to get things approved.
fouckhest
Greer, SC
Agree, on going to the dealer and/or calling corporate to emphasize the time wasted.
Glad you got the car into Further! I will actually be in Eden Prairie for work on next month, flying in on labor day and out the next day. But maybe one of these trips we can catch up for a beer!
gearhead1960
The service department's behavior is totally unacceptable. The service mangler or general manager likely know what's going on because it's happening. I would skip the dealership BS and make a call to VW. At least make them aware of what's happening on the dealer level. Hopefully, VW will push it back to the dealership's upper management for some sort of fire control. I would also make it known to the dealer that you will be posting on every social media platform you can find about their total incompetence.
N
nicholam77
Minneapolis, MN
I would have lost my sh%#^*t too. It does sound like taking this up the ladder to corporate might be in order.
I could do that. I am frustrated, but I didn't want to berate the guy on the phone, because technically it was someone else who screwed up. Also, I'm still hoping to get the claim re-initiated, and don't want to make them angry at me *just* yet, I'd rather get photos taken and resubmitted first. But yeah I will complain at some point.
Can "Corporate" access specific dealer information like repair orders or really make any decisions? I've wondered about going over the dealer's head, but everything I've read indicates you have to go through the dealer for the rust warranty, and then it's ultimately evaluated by a 3rd party claims review company that VW contracts.
A bit ago I sent an angry email to their Customer Care address and the response was empathetic, but basically just told me I have to contact my dealer throughout the process.
Yep, after biking 14 miles a day round trip to work for a week and a half...
... it's finally in! Today is the day!
Car drove there fine, no problems. It was only a 15min drive.
They've already confirmed it's leaking from the thermostat housing. Turns out they had quoted me for a 3rd party pump/thermostat even though I had asked for OEM, so it's going be even more $$$ :ROFLMAO:
I'll post an update when I get the car back, but I can't wait to have this wrapped up and not be stressing. It's a major PITA not to have a car with kid transport and all that!
Cool! Yeah, I will likely be in Wisconsin for Labor day, but for sure if you have another work trip hit me up and we can grab a beer! Mpls has lots of great breweries, there's even a big one right next to Further.
Denwood
It's a good sign that they have a few Vanagons in the lot...no one wants to work on those (I can say that cuz I had one)! Between all the Audi and Porsche logos in the lot, pretty sure you've taken the car to the right place too. We really have no specialist shops here due to the lower population density, but if there was one it would 100% affect my purchasing decision on cars in general.
The downside of getting the car fixed is all those work outs you'll be missing...
On the rust issue, I've got my finger's crossed for you, but based on how companies in general deal with these, it seems they always have an exit clause for their so called corrosion warranty :-( I think that's why I've been so obsessive with the yearly touch ups, cavity spraying equipment and the yearly mess.
