signcrafter
- Joined
- May 9, 2012
- Messages
- 12,635
I started looking at a dial type torque wrench a couple weeks ago to do pinion preload measurements, wanted something a little nicer then my cheap beam type I have used in the past. Have a pinion seal to do coming up so figured it was an excuse to get one, I don't like counting the turns like many do. I want to be able to see a measurement when tightening the pinion nut. After talking to Mike(ZMotorsports) I started looking for proto or snap on dial torque wrenches with the 0-75 in/lbs scale with marks for each inch.
Found a used one on ebay that looked in good condition and got a little excited so shot a couple best offers back and forth and the seller accepted. When looking at the pictures it looks to be in good shape with clear lens on the scale and the scale is what I was looking for. But wasn't until after I won it that I noticed the needle was not resting at 0 on the dial. Guess I got too excited I had found what I was looking for and overlooked that part.
Is there a way to reset or recalibrate it so the needle is resting at zero? Or would it have to be sent in to snap on or precision instruments who made these for snap on? It looks like the needle is held on by a screw, is it as simple as loosening that screw and adjusting the needle so when resting it's at zero on the dial? I'd like to do whatever I can myself before I would have to send it in since this is a tool I may use once or twice a year at the most. But also need it to be accurate. Anyone ever adjust their torqometer before? I was googling and saw a bunch of info about calibrating it by taking the back cover off and adjusting a nut on the rod going from the head to the dial. But my limited knowledge thinks that the needle being off isn't a calibration issue. When resting zero is zero and should be able to just adjust the needle to rest at zero. Calibration would be for accuracy as you apply torque turning the nut. But I may be wrong on that. I may end up sending it in anyway because if the pointer is off while resting I'm not sure I would trust it to be accurate. Anyone ever send one of these off to be calibrated before? I'll have to contact snap on and precision and see how much it would cost to get it calibrated.
Depending on price to calibrate I probably should have just bought new but it is what it is now. Don't worry I'm not going to start a rant thread about getting scammed on ebay and amazon because I tried to get a deal!
