M.Brane
1 hr N/W of LA LA Land
Last night stopped work before all my tools and parts disappeared. Was trying to sort why the fuel pump isn't working on my 91 Z28...I've replaced the fuel pump previously. Not fun as not only does the tank need to come out so does the panhard bar and muffler.
When I did the fuel pumps in my '94 F-150 I dropped the tanks. Getting them out wasn't bad, but getting 'em back in was a total PITA especially the rear. I swore if I ever had to do that again I would just pull the bed. It would be way less work, and frustration.
CoogarXR
Make a bracket to wall-mount a soundbar under my TV. Cut some L steel from an old shelf, drilled holes to mount the soundbar, some more holes for the studs, then hung it in a tree and spray painted it black. It's still out there twirling in the breeze.
DGersic
DeKalb, IL
Built cribbing. Got the car up on cribbing.
Sitting on the suspension, measured angles and length for the driveshaft. The angles are off, front is 5 degrees down, diff is 1.7 degrees up.
Rough measurement of the old 700R4 vs. the new TKX, it looks like the angle of the transmission is about the same as it was. Rechecked the engine, it’s in about the same place as it was, may have moved 1mm or so at the back of the block. The crossmember is in the same place, and the mount for the trans is about the same.
I could try to correct this by shimming the rear axle. I’m not convinced that I need to.
Reinstalled the shift tower, removed for clearance while getting the transmission in. The floor hole was already there, for the Lokar floor shift. Had to trim the edge slightly to access the bolts that hold the tower down.
Installed the shifter.
Goes in to all six gears nicely. Very comfortable placement for the shifter. Amazing how well this works out.
Ordered my new driveshaft. While I’m waiting for this to arrive, I can rework the wiring harness, get the speedometer cable installed, install the hydraulics for the clutch, and a few other things. The list is getting shorter.
Some minor cleanup and putting things away. Tools back where they go, garbage thrown out.
kaymccampbell
Upstate New York
This is how you can tell the engineers never thought of, or cared about, future repairs and the poor SOB who has to do them. I was overjoyed when I needed to replace the in-tank pump on my Toyota Corolla and found the access panel under the rear seat. Didn't even need to empty the tank and the entire fix was, literally, a fifteen-minute job. Toyota cared back then.
Of course, a week later I put a hole in the tank so had to pull it anyway. Turns out, a Toyota Corolla is not ideal for off-roading.
I have no compunction with cutting holes in the floor for access to fuel sender and pump units. I've done it to at least half my sboxes.
Old Man Roger
Palm Coast Florida
My 1999 Z28 got the hole cut treatment, but oddly my 1999 Buick park avenue had an access panel. My 2001 Firebird had the same engine as the park ave but also needed to be cut.
All those being GM’s, and fuel pumps being normal wear items, you’d think at least the common years would have had the access panel.
Beerhippie
Far NE Oregon
Your rigs look a little better than mine. ;)
Started prep for swapping new tires on the T-van. 2 came today, The other 2 are due tomorrow. It wil be intersting doing the mounting and trying not to further eff up my back since its not 100%
So after dinner I went out and got the dead tire off the 15" rim that will become my spare (old spare was 14"..) and my back tolerated it! I had to be a bit careful, but got it done! (manual bead breaker and tire irons, and my "tire hammer" - just like routine!)
Fordguy1964
Houston County, Alabama
Damn, leave some hammers for the rest of us! 😂
I'm sentimental about my tools. I have tools from my father and grandfather. That's how I end up with so many. At one time we all had working sets of tools. I'm sorting through it all now. I've cut back. I tried something a couple months ago and it seems to be working. I cut back to the bare essentials. That way I don't have 15 different 1/2" wrenches. I only have what I would use. This makes it easier to put them away. Easier to find them when I go to the box. And finally it makes it more important to keep track of them because I don't have all of the spares sitting right next to where the other one was. It makes it more important to make sure to put the tools away when the job is over.
bmwrd0
Beaver Fever Oregon
My fathers old '67 Datsun pickup had a hinged access panel in the bed, made getting to the fuel sender dead easy. My '95 Dakota you either needed to drop the tank, or pull the bed. When I had to replace that part, I was working at the auto electrician and had access to lifts so it was easy to drop the tank when lifting the whole truck. Another friend used a tractor to pull the bed on his.
After two back surgeries, I am pretty careful to leave that stuff to the younger folk.
As far as my shop time, back to working on the Dalton's carriage and apron. Also, clearing room on the bench for my new die grinder:
found an old dentists drill at a garage sale, and seeing as I like old tools, this should work perfectly in my space. I will need to put a longer cord on it though.
WisJim
Menomonie, WI
That makes my mouth hurt. I remember getting my teeth drilled with that kind of device in preparation for a filling when I was a kid. When they developed the higher speed dental drills it was a revelation.
OccupantRJ
Eastern North Carolina
I went out to the shop and put a few things back in place while waiting for a hot rod shop owner to come a hour and a half to buy an assortment of Roper Whitney punches that I had advertised on Marketplace. He happy, me happy. I have a Rotex turret punch so the #8 hand punch dies were just sitting around in storage and can now do someone else some good.
Beerhippie
Far NE Oregon
Just getting the Brick ready for some driving around. Top up oil, coolant, clean and re-oil the damned K&N air filter. I think I'll head up the Lostine River road after I cash in my free pizza card at M. Crow's in Lostine.
Lostine River road is locally notorious for its world-class washboard.
Beerhippie
Far NE Oregon
I hate washboarded roads...
Vanagon has one of the best suspensions I've driven for washboard--but I didn't go up that way, as there was one hell of a storm brewing and that road is heavily forested. I didn't bring a chainsaw.
The last time I drove that road was in the Toy. The washboard was so bad, it caused my vision to blur to the point I had difficulty seeing the road.
I decided to hit one of the local honey holes and then take a drive up north, which is open prairie. No falling trees, but I hit a massive duststorm where someone's fallow field was migrating towards Idaho. Dust was so thick I had to drop to a complete crawl in first gear and basically feel my way down the road for a half-mile. ****-clenching adventures with Timm!
Headin' home:
The peak centered in the canyon there is Sacajawea, the highest point in the Wallowas at 9,850ish ASL. Peeking around the right side--the square peak--is the summit and top of the west face of Matterhorn, second highest point in the Wallowas (9,800ish) and one of the tallest vertical cliffs in the US at nearly 3,000' feet of verticality. I've climbed both many times.
Beerhippie
Far NE Oregon
Well-tuned suspension does wonders on washboards.
In Moab, it felt like the washboards weren't there as the trail felt completely flat when I hit them at 40-45mph.
Gotta keep an eye on the shock temperature if you're doing that. I once blew a shock while doing about 55 on a bad dirt road. It overheated and blew the side out. Handling kinda' changes when you suddenly have three shocks. The other shocks were too hot to touch.
The fun part was when I pulled over to see what the loud BANG from under the front driver's side was and why it screwed up the handling so badly. I saw that smoking oil pouring off the front end and immediately thought it was a blown engine--then remembered I was driving a VW Bus.
There's always a little problem with the fact that, when "skipping" over washboard, you're not exactly connected to the road anymore. Sometimes it feels like flying a very low helicopter.
KwikFab
Central Valley, CA
The fun part was when I pulled over to see what the loud BANG from under the front driver's side was and why it screwed up the handling so badly. I saw that oil pouring off the front end and immediately thought it was an engine problem--then remembered I was driving a VW Bus.
Oh for sure - larger shock bodies (especially with a reservoir) will help to dissipate that heat ;)
On my old 4Runner I ran through Moab though, I did end up hitting the reservoir under heavy flex.
Tuned suspension is a must though for sure, especially if it sees daily use.
Beerhippie
Far NE Oregon
^As I wrote above, the Vanagon suspension is pretty damned well designed for washborad and potholes. Makes one wonder what kind of roads the Germans had in the eighties! Add in the HD Biltstien shocks and progressive springs and it's a great combo!
I won't be driving any trails like that--it's a bad road rig, not a no-road rig.
KwikFab
Central Valley, CA
Bilstein yellows?
Yeah those are significantly better than anything factory for sure and overkill for most of the population.
Me, I need to finish installing a few things before hitting Rubicon.
SMOKEYBEAR
Two coats of Poly/stain combo on the bottom of the rod racks, made some "feet" out of square tube aluminum, and sprayed a couple coats of the same poly/stain combo on the rest of the racks. Didn't thin it, just ran the pressure a bit higher than I would otherwise. I had a couple of runs, tipped those out with a throw away brush. I'm keeping the project utilitarian. Pictures no order.
Should get them in place tomorrow after the gym.
phred
NC
4 wheel disc conversion on this pile. I would highly NOT recommend “The Right Stuff” kit. A friend bought this and asked me to help him install it. It doesn’t fit very well and the instructions **** especially since the instructions referenced photos is of a completely different style caliper ans spindle set up.
Spindles are also a couple of .001 over size and made getting the bearings on problematic
Beerhippie
Far NE Oregon
Will that be enough to douse some of those fires?
We can only hope. I'd have to guess about an inch in fifteen minutes--the parking lot and that back area are flooded. Of course, it came with lightning, so the main question is, can it put out the fires it just started?
In general, most large fires are only fully controlled when the snow flies.
We've been fairly smoke free for several days now. Nice!
Old Man Roger
Palm Coast Florida
My old Grand Cherokee is the furthest thing from a well tuned suspension but for some reason it’s as smooth as glass on a road that makes my truck and my car hover at anything above 35. I think it’s actually the tire size and wheel base that make the difference.
Beerhippie
Far NE Oregon
Working on getting the new high-mount turn/brake signals mounted.
I cleaned up the lenses some and painted the housings.
The mounting brackets.
I'll mount the lights to the ends of the solar panel frame on the roof rack.
Getting them wired will be next. I do rather wish the jackoff who decomm'ed them had left those two wires a little longer, but I have a soldering iron and heat-shrink.
The Brick has a trailer light plug already installed. I have no intention of towing a trailer with a Vanagon, so I'll use that to wire the new lights.
I wanted to mount them upside-down, but the "stem" is open on the bottom. Only meant to be mounted upright. The wires in the stem need to be free to move a bit, so filling the stems with RTV is out.
