Name that twist lock
rslaback
Westcentral Wisconsin
I bought a vintage golf cart recently and I would like to utilize the original mounted charger in it. The charger uses a twist lock cord and I would like to change the cord receptacle but I cannot seem to identify it as a standard NEMA. The key difference is that it does not have any L shaped terminals, just two large and one small curved terminals.
Anyone ever seen anything like this? Based on the male connector it is a 125v 15amp cord.
BillK
Beautiful Southern Maryland
Can you post a picture of the Male connector ?
mikedodge
Non nema makes it harder especially when you don't know the actually amperage it it. A lot of those look the same but the diameter of the circle of prongs and the placement of the prongs themselves are a bit different. See if you can fond somewhere on Hubbell's website that shows the dimensions of the prong circle diameter and placement.
I wanted to get a new plug to use for something with my twist lock outlet and I had to use the chart to get some numbers and try a couple before finding the matching one.
R
rslaback
I believe he wants to replace it with original type. Let’s see if the OP responds.
That is correct. I like to change as little as possible, especially on vintage stuff. The cord end is a candidate for change because I have never considered that style of cord cinch to be safe, the case is missing a bit and one of the screws must have rusted in place and then been snapped off.
dave*99
Coastal NJ
Do you think the 7565C in post #9 is a match?
