M.Brane
Break
Out
Another
Thousand
Out
Another
Thousand
Hope the boat works out good for you and your family. My kids love boating from babies to almost adults.
Does it have an alpha drive or a bravo?
Boats require a lot of maintenance for the amount of time used. Ocean use is another level of risk.
At that size/weight I'd guess a 4.3 vs 5.7 is a wash in fuel consumption.
Break
Out
Another
Thousand
This why I have friends with boats instead of owning one. Provide food, beverages, and gas money. No maintenance headaches.Same! I grew up on the water, and I've seen what a lack of maintenance can do to a boat. My dad was never good at maintaining his, and my brother is religious with his.
Thankfully the outdrive is pretty simple and everything is fairly accessible. It's not like a truck where you have to crawl on your back to get to things. This outdrive has been well maintained, but I ordered a rebuild kit to have parts on hand. $100 for a complete overhaul isn't bad.
It's a gen 1 Alpha 1
I think it's fairly significant difference. I should be in the high 2 or low 3mpg range.
Whether on land or sea, I'm not unaccustomed to money pits. I think, largely, the people that use that acronym don't have hobbies outside of fantasy football, or pay to have someone else work on their equipment.
Working on a guy's truck right now - two heims and two uniballs (1" and 1.5") was nearly $300. Offroad trucks just don't have a fun acronym like boats.
Can you even still buy parts for a truck project without spending $300?Same! I grew up on the water, and I've seen what a lack of maintenance can do to a boat. My dad was never good at maintaining his, and my brother is religious with his.
Broken starter mount is a bummer. I'm assuming that it can't really be repaired well enough to trust? Tie into the drive bellhousing? Maybe lake but not ocean.
Do you have to get a 'marine' replacement motor?
Nope! Haha eff.Can you even still buy parts for a truck project without spending $300?![]()
Isn't that a big-*** boat for an Alpha 1? I'm with @rattle_snake - I'd think the torque gains of more cubic inches would offset any fuel economy "gains" of the smaller motor BUT I don't know that I'd bolt a V8 onto an Alpha 1 either. Admittedly limited experience between a buddy's 26' cruiser with a (remanned) 5.7 and a Brave and the in-laws '87 16' Sea-Ray with the orig 3.0 and an Alpha.
Ah Ok so some additional thing with the motor. Are the exhaust manifolds/riser rusted or otherwise not usable? Does it have a closed cooling system?
I guess the boat looks bigger and heavier in the pics. 4.3 should do just fine. Alpha has less drag in the water, weight and power loss compared to it's big brother.
After you get it out and see how it performs, might consider aerating/drilling the prop to help get on plane. Can really make a difference for $0.
Ah one of those types....The previous owner was an engineer ....
Pot, meet kettle.Ah one of those types....![]()
