120v vfd for 3 phase
stinkity stoink
New Jersey
Quite a bit of discussion, but I can’t seem to find the GFCI outlet I’m looking for.
I upgraded my old drill press to 1.5 horsepower three phase motor. I have it wired for the low-voltage 208 on the three phase motor . I am using a VFD that powers off of a 120 V outlet single phase. Everything works great if I plug it into a non-GFCI outlet. It keeps tripping the GFCI outlet.
I have been trying to read, and they say there are GFCI outlets out that are a different classification that would work, but I can’t seem to find any. Or maybe I am just reading wrong. If anybody has any info on where to get it or what it’s actually called please speak up.
thank you
Dave
matt_i
SE Michigan
GFCI is never going to play well with a VFD setup like that. I had similar issues with a diamond wheel/solid carbide scraping tool grinder I built from a double shafted 3ph 1/4hp motor from a scroll saw. Same type of VFD. Make sure all ground paths are solidly connected to your machine and back thru to the outlet and just live that way. I personally don't think you are in very much danger if you can make solid connections and your wiring is touch-safe to start with.
mm08822
You want a GFCI recept labeled "HF". Leviton claims their gfci recepts already meet the requirement and website refers to the HF feature.
But, none of their GFCIs that I've purchased recently have the HF marking. Supposedly, Sept. 1, 2026 is when the ac gfci requirement become effective. So I expect these gfci cb's will contain the HF functionality. If that is the case, then I assume the functionality should easily trickle down to 15/20a, 120v gfci recepts.
Here's a thread that discusses the topic: https://www.garagejournal.com/forum...tion-for-you-contractors.557609/post-11630234
stinkity stoink
New Jersey
I was thinking about just living with it ,but I figured if I find one that works I would use it.
stinkity stoink
New Jersey
Thats one of the several threads I read. I am all over the place 😂
mm08822
Here's a draft to change that timeline that the ac industry is pushing for. I really don't know where the electrical product manufacturer's are with a gfci device that will comply with the UL Supplement B requirements. I would think the first mfr with development completed would be blowing their horn, but I haven't seen anything.....
  • NFPA_70_Proposed_TIA_1924.pdf
u2slow
BC
Feeding 120V to a 208v motor is certainly not ideal. A VFD isnt a transformer.
Thankfully a drill press is a type of machine that runs mostly unloaded or lightly loaded. Watch the temperature and dont be surprised if it experiences a shortened life.
I wouldnt run it on a GFCI at all.
LopezBart
Lopez Island, WA
It works because the 120 VAC is converted to high voltage DC using a voltage doubler rectifier circuit ( https://en.wikipedia.org/wiki/Voltage_doubler ) and then used to produce 208 three phase in the usual manner.
This works for loads up to 1 hp; past that, you need 240VAC input....
u3b3rg33k
120V input VFDs typically have voltage doublers. kinda like old computer power supplies had that 120/220v toggle switch. same thing.
fun fact, you can run a 400v class VFD on 200v class power with... a DIY voltage doubler feeding the DC bus! precharge resistor recommended. as always, try not to die.
u2slow
BC
Noted.
I havent dabbled much with small VFDs, but the ones I have... must be basic ones. Nominal V-in = nominal V-out.
u3b3rg33k
Noted.
there's more than a handful of models meant for small motors that take in 120V.
if we do the math we run out of amps pretty fast on 120V input power.
5.8A*1.73*2=20.068 A
so I assume that's why they stop at 1.5HP. but you can do a lot with 1.5HP
dscheidt
Noted.
The vfd on my ( industrial) sewing machine drives a 400v 3 phase motor. They do it that way because the VFD gives precise speed control, and positioning, and can take 100-250v input 1 or 3 phases. So one setup covers all markets.
(I assume the output voltage is to allow smaller wires from the control (under the table) to the direct drive motor).
stinkity stoink
New Jersey
Thanks for all the responses…I didn’t mean to start a whole new discussion on this because I know there have been several.
I will say the new motor is definitely a treat to use compared to the old one. The speed control and the fact it doesn’t bog down at all is great.
my reason for the post was just to find the part number or name of the gfci that the manufactures are supposedly coming out with.
rattle_snake
Chandler, AZ
I have the same VFD on a GFI and it has never tripped.
A VFD can perform a transformer type function, similar to a 'solid state transformer'.
Cheap VFDs are square wave output, but when connected to a inductive load (like a motor) they are more sine like.
stinkity stoink
New Jersey
Cheap VFDs are square wave output, but when connected to an inductive load (like a motor) they are more sine like.
Your thread on it finally pushed me to do it.
Did you upgrade the gfci to a different one. Mine works fine with a regular outlet
stinkity stoink
New Jersey
Here is something I discovered that the electrical people would know the answer more than me.
The 120v outlets inside the garage are all 20 amp circuits. There are i believe 3 circuits that feed a gfci which in turn feeds 3 more outlets.
There is a homerun 20amp gfci that was put along side the door in case I did a garage door opener. That gfci does not trip when I plug the vfd into it. I have to check and see if it’s a different rating or brand than the others.
mm08822
Check how they are wired by opening the boxes and pulling recepts. Is the gfci recept providing downstream protection or just daisy-chained on the line side? Turn off cb's to also aid in confirming which recept is on which circuit.
Do "downstream" recepts trip the gfci when a gfci tester is plugged into each of them?
stinkity stoink
New Jersey
The gfci provides downstream protection.
The gfci are wired line 120v in than load is out to the next receptacle down the line.
If I test downstream with a gfci tester it trips the gfci.
dscheidt
If the vfd trips on some gfci but not others, it's very likely there's a difference between the GFCIs. It's likely the one that works is one that meets (or essentially meets, if it's older) the HF requirements. The simple solution is to swap the one that works to where you need it, or to get another of the same type, if you can identify it.
dave*99
Coastal NJ
Since high frequency noise has been mentioned when discussing a VFD tripping a GFCI…… perhaps using a down stream receptacle protected by an upstream GFCI performs differently than plugging directly into the GFCI.
Maybe the additional cable between receptacles attenuates some HF noise.
Just a theory. YMMV
ETA: Post 18 would be an example that opposes this theory.
stinkity stoink
New Jersey
not sure if anyone is interested for there own projects. The gfci‘s that trip from the vfd are Lutron. The other gfci in my garage that doesn’t trip is a Pass & Seymour. They are both 20 amp and 60 hz gfci.
Cruzan80
Denver, CO
Sometimes turning on flash allows the shutter speed to be faster, if the garage isnt as well lit. This can help with blurrier photos as well. Other times it is just worn lettering or bad stamp molds, and your eyes are fine.
