Side wall concentric furnace vent verses separate intake and exhaust.
beltfeed
USA
Is there any advantage of one verses the other performance wise. I live in an area that will see winter temps as low as -5F. I have read the Concentric vents may ice up a little more. I'm good with all the requirements for vent location. 3500Sq shop building, 15' sidewall, I am siding the structure currently and I will be placing one or two bezels on the side wall for furnace provisions. Furnace will be a 120K Natural gas force air condensing.
Ohmthis
Outside of Louisville KY
The main benefit to me is one penetration. It doesn’t get that cold here, but definitely below freezing. I’ve had no issues with the ones for my house or the ones I’ve installed. I think it’s more important to keep the pvc runs as short as possible and with the least amount of elbow fittings.
PoorUB
Fargo, ND
I have done both. One penetration or two doesn't really matter as the concentric might be a 5" hole versus a couple 1-1/2 or two inch holes.
What seems to matter is location to windows, air intakes, or what is in the way in the basement that often helps decide which is better.
For example, running a concentric out parallel to the floor joists is easy, but try run on 90 degrees to the joist and get through the rim joist. Often you will have to bore through the rim and the next joist in before you have room. At least in my house it would be a pain, plus others have been in. It that situation might be a lot easier to run two pipes out instead.
Also, if the home has two furnaces in the same general area you can often run two concentric side by side where if you two pipe each furnace you might have to separate the terminations by a few feet.
beltfeed
USA
PoorUB, very good point on the clearance hole diameter. I looked it up and you are correct. I will be running 3" exhaust which will require a 5" hole using a Concentric vent. My bezel plates are Hardie trim 1" thick X 7.25" X 10" tall. I don't think I want to fight with a 5" carbide grit hole saw going through Hardie. It also leaves me only 1.125" material at best on the sides. Separate intake and exhausts for me. Thanks for the pointers, Ohmthis and PoorUB.
Jackfre
N CA
When I represented Rinnai I ended up selling about 400k units total over 30 yrs. 98% of which were concentric and there were very few problems, but that was with Rinnai’s termination. I do not know what your vent looks like so cannot speak to reliability of your termination. Being in Fargo, as I recall it snows. In extreme circumstances your vent can get buried with either single of dual pipe. Get up the wall above the 12” minimum.On clearances, a direct vent appliance <50kbtu has a 9” clearance to a door or window, typically 12” to an inside or outside corner, but in my experience you want more. Air currents around corners can pose problems. DV’s >50kbtu have a 12”clearance to a door or window.
75gmck25
Alexandria, VA
Another consideration for using dual wall pipe is that in my experience its very expensive. I installed a Mendota fireplace that used a 5" concentric chimney that I wanted to run all the way to the roof. The Duravent DirectVent piping I used was quite expensive for a run to the top of a two story house.
Jackfre
N CA
This is the termination of my Rinnai fireplace. 3” pipe and that termination os about 6“ diameter right out the back of the appliance. Rinnai US, mistakenly imho, dropped the gas fireplaces which are manufactured in NZ in the crash of ‘08. Terrific product but didn’t get traction within the company. I ordered this from NZ a couple years ago and it has provided us out heat for the past couple years. QUIET, modulating burner and blower and jsut a good companion in the home.
beltfeed
USA
My exhaust will be about 7' above ground level, and the intake will be directly above at 9' above ground level. If the snow level reaches the exhaust, I need to move. :LOL:
beltfeed
USA
I have a Mendota natural gas fireplace with duel venting all the way up a 35' brick chimney. I have not been impressed with it so far. Ignition is hit or mis with the remote control. Currently it will not ignite anymore. Probably next month I will have to pull it out of the former wood burning fireplace to see what the problem is. For $6500 and five years old I would buy a different brand next time.
PoorUB
Fargo, ND
Back when I did HVAC service I went out to do start up on a 90+ furnace one of the other guys installed. I looked it over and everything looked fine, but the venting caught my eye. Like most installs he went through the wall and 90 degree up a foot or so and 90 degree out on both the intake and exhaust. In this case I asked to the installer why he did that? His answer was that is the way the manual shows it. I told him, yes, to get above snow level, but you came out of the house about ten feet off the ground! You could have came straight out with the exhaust and 90 degree down for the intake and called it good.
PoorUB
Fargo, ND
I will probably 45 degree the exhaust down and leave the intake straight out.
Read the manual for the furnace. Generally the exhaust is directed straight out and the intake might be cut closer to the wall, straight out or angled down.
You said it was a 120K BTU. Probably 3", but pay attention to the instructions. Often you can penetrate the outside wall with 2"
Chuckster in NJ
Hunterdon County NJ
When I would do inspections I always did the inspection according to the manufacturers installation manual along with the code requirement…..…. Basically, READ the installation manual and it will tell you what code to reference along with material types and measurements.
beltfeed
USA
I will install the venting per the furnace manufactures specs. I have not purchased a furnace yet, but it will be a single stage condensing 120K. Most the 120K's that I have seen or worked on do require a 3" vent pipe.
75gmck25
Alexandria, VA
We have had the Mendota direct vent fireplace installed for about 3 years now, and no problems so far. I do think they made the remote control too complicated, with multiple use for some buttons, depending on which function you are controlling.
They should have at least separated the control buttons so you could set all the options once (heat to a certain temp vs. constant on, dual flame vs single flame, backlight in firebox, continuous pilot vs striker, etc.) and then one very clearly labeled button to simply turn it on and off.
For example, if my wife hits the buttons without looking carefully, all of sudden I have a continuous pilot and a fireplace that runs continuously (no temp limit) until you shut it off. Three hours later I realize that the fireplace is still running at full heat, and all she wanted to do is raise the room temp a couple of degrees.
beltfeed
USA
The remote is my biggest complaint. My wife won't even bother trying to turn it on. You have to toggle your way through to many settings. The continuous pilot can be nice when it's really cold outside and you are using it a lot. You don't get the condensation on the front glass like you do when the pilot is in the on demand only mode. But yes the remote as a pain.
Jackfre
N CA
I haven’t had the Mendota apart but if you can remove the glass and access the pilot assembly you can probably get it going pretty easily, you have a spark to pilot. It the pilot gets dusty, which over time it will, it will make the pilot ignition a hit or miss affair. I‘d try that before digging deeper.
caleb383
In sub-zero temperatures, separate intake and exhaust lines are usually less prone to freezing up compared to concentric kits, which tend to gather ice right around the termination cap. For a large shop building in a cold climate, running them separately might save you some winter headaches.
75gmck25
Alexandria, VA
Just to be clear, my Mendota fireplace does have one simple on/off button (universal label of circle with a line through it), but the problem is that there are two other same-sized buttons below it, and then a big rocker switch off to the side.
If you have set it to the options you want already, then simply pressing the on/off button turns it on to the settings (flame height, high low fan, etc.) and temp you want. The problem is that you might accidentally hit one of the other buttons as you turn it on and/or set the remote down. I can get usually it back to a normal mode if I press a wrong button, but try to explain that to a spouse or guest and they will never remember how it works. For some reason the most frequent error is to toggle it to continuous-on instead of automatic mode where it works like a thermostat and shuts off at the set temp.
It reminds me of editing a document in MS Word and you think you are doing something simple in your edits, and all of a sudden the margin is different, you have an extra page break, the paragraph is indented, font is different, etc., and you can't figure out what you just changed. :)
