Anybody use a Jack Rod jack stand adaptor?
atikovi
Suburban Washington DC
Allows safely getting under a car supported by just a jack.
AEAdam
SE PA
Where is it made? I see the company is in California and Jack Rod has a US patent. It looks like a ratchet bar? Toothed bar?
Not for me. And what’s the point? To save on the cost of jack stands?
A
atikovi
I was watching a bunch of this guys oil change videos in which he uses this thing,
It's used for a quick drain plug removal during a mobile oil change service since its dangerous to get under a car supported by only a jack. I already have this system that combines a jack and jack stand for longer jobs:
but this seems ideal for something quick you have to do undercar.
Renegade1LI
long island ny
I'm not sure I would trust it, I saw a guy loose his legs when the truck shifted & came off the not so secure stands. Trusting a jack, & an aluminum one at that, I've bent a few of them sideways no thanks.
Pinne
I think the time savings afforded by this device would be substantially less than the time lost should anything go awry. We've all seen cars fall off of 2 post shop lifts, so anything can happen. Plus, a pair of quality jack stands costs less than this device does. To me, this device is like standing on one leg versus two.
I'll stick with extra points of contact.
Basskiller
s cal
I have one. We use it on the trail. It’s nice to have a solid connection holding a vehicle up.
that said, we usually have a tire laying under the frame/differential as well.
tak1313
I have one because it looked interesting and it was on sale - I don't remember how much it was for (yes, it was some time ago).
As with many GJ members, I got it, but haven't gotten around to using it yet. I'm thinking if/when I do, I'll probably use a secondary support at least initially until I can see how stable/strong it is.
Zewnten
I'd trust the stand in your second picture long before I would the other. I also don't seehow it would be any faster than what you already have.
AEAdam
SE PA
I get it. And do what you want. For me personally, when I change oil, I like to be on a creeper. And my right arm and head are under the car. My head is typically directly below the rocker panel, which is one of the stiffest parts of the car. So yeah, I stick a jack stand there. And if the ratchet fails on that jack stand, the base is usually taller than my head is.
Anyway, that's the way I think about it.
whateg01
doo dah, kansas, usa
How would this fall over? It's not for a scissor jack.
It doesn't. The jack does. When jacking with a floor jack, the body of the jack has to nice relative to the lifting pad. Often something obstructs the jack or as the vehicle starts to tilt away from you the jack has to lean sideways or the vehicle has to slip. The traditional jack stand never has to move, and shouldn't, from the time the vehicle touches it until the weight is fully on it.
Maybe this thing could be trusted in a garage on a smooth, clean floor. Mine get used in far too many situations that aren't that. It's a nice concept though.
johnh91
Maricopa County AZ
I use ramps to change my oil and I limit how far under the car I go. I use jack stands if I was going to go under the car for any actual repairs. I change tires without jack stands it's just a tire change and I put the spare under the middle frame of the car in case the jack fails so I dont crush the wheel hubs.
Plombob
Tennessee
At $140, you can buy a nice set of stands and still have money to take the misses to dinner.
AEAdam
SE PA
Yes but this guy uses it in his mobile oil change service and takes 5 seconds to install. Setting up a pair of jack stands would take 5 minutes.
Huh? No!
I’m in my 60s and change oil on a narrow broken asphalt driveway. I jack one side, set the stand, then move to the other side. Jack and second stand stay on that side. My guess is 90 seconds and this isn’t an F1 pit stop.
Twisted Sid
CA
I'd use one when out in the desert for a repair where no stands are available but not at home for maintenance stuff
whateg01
He doesn't show actually getting them put in place and letting the jack down on it so I doubt it's actually 5 seconds and if it takes you 5 minutes to set up a jack stand, you're doing something wrong
Basskiller
s cal
No you wouldn’t. You’d do what people do in deserts or inner cities. You yank the wheels off and use them as cribbing.
This is a device in search of a problem to solve.
Get out and touch some grass. Better yet get out to next years King of Hammers. See the real world, and realize not everything is done in the shop. This device is used frequently by people doing repairs on sxs and trucks.
If you do make it out to KOH hit me up and I’ll give you a ride.
472scout
back 40
I haven't seen it happen but I've seen the aftermath. Multiple factors in it happening but it can and does.
I'm trying to think of a way that could happen without a very high level of incompetence.
So that begs the question what exactly did happen? Was the vehicle on level ground with the parking brake and/or wheels chocked?
Hakeem
Chicago
Never been, but aren’t those off road trucks & sxs lifted enough to get under them without a jack? And even if not, using something like this in an off road setting — ie, soft unstable ground — seems risky.
The only real use case I can see is for jacking up a car from the pinch welds - if your jack is at the lifting point, there’s often no room to place a jack stand.
Personally, I think a Unijack or something similar is a better idea:
