Are you doing this with Chat thru the desktop app? I haven't downloaded that, looks like I should.
I'm using Chat to work through a business idea a buddy and I are working through, it's been very helpful.
Yes - just an app - phone also.
For the forum indexing in your pal Atlas, are you using âWorkâ?
So the way I understand it is Chat is more more conversation vs persistent project workspace, it's not really better AI vs worse AI. Work is where you have a specific project that you don't have to scroll through conversational pieces - you go right to that project as a folder etc.
For the forum indexing, intersting part is he was having me code it from the beginning since he didn't have access to most sites so I started writing some of the Powershell scripts to get it going - then he took it from there using Python on the backend.
I have a bit of both going right now (Chat/Work). Then there are scheduled tasks - I have him hunting the web all night for F250 Highboys given my parameters of what we are looking for and every morning I get an update like this:
Today 8:00 AM
Watch for Ford F-250 Highboys
New one that actually fits the mechanical filter: a
1972 Ford F-250 Highboy 4x4, VIN
F26YRN40696, has just appeared in the current
Montana Classic Car Auction listing.
It's a
360 V8 + 4-speed manual, runs/drives/stops well, and the listing says the 4x4/drivetrain is solid. It has also just been serviced with a fuel pump, carb kit, oil/filter and other basics. Current bidding is only beginning, so there's no meaningful sale price yet.
This is worth watching, but I am NOT clearing it on our âbone-dry sled truckâ requirement yet. The listing doesn't provide enough textual detail about the bed floor, bed crossmembers, cab mounts or frame to verify that there's no structural rust. That's now the gating item before I'd tell you to chase it.
The other supposedly ânewâ western results were recycled/stale listings, sold trucks, automatics, or known rusty examplesâincluding that green Montana '76 with bed-floor rustâso I'm not cluttering your inbox with them.
Verdict:
Watch closely. The '72 has the right year, F-250 chassis, manual transmission and Highboy configuration. If the underside/bed photos establish that it's genuinely dry and bidding stays below
$25K-ish, this could become a real candidate.
BLUF - no worries I got you covered bro - Highboy inbound - Hell or highwater.
This truck was actually a good find - site I had never heard of so he comes up with good stuff.
So the genius part of the garage journal index is it is constantly revisiting - on its on with no prompt. Once a day I get Atlas the
proactive âInsightsâ/suggestions ChatGPT not a normal message inside one of our chats.
So basically insights that are AI-generated âthoughts while youâre away.â
Instead of waiting for me asking a question per normal prompt, ChatGPT can look at things you've been working on or discussing and surface something it thinks might be useful â a connection, observation, suggestion, or next step.
Think of it as the difference between:
Chat: âHey Atlas, look at this problem for me.â
versus
Insights: âHey Jeff, I've been thinking about that thing we were working on â here's something you might want to consider.â
For someone unfamiliar with AI, I'd probably say:
âIt's like having an assistant who occasionally taps you on the shoulder with an idea based on things you've been working on, instead of only responding when you ask a question.â
Here is an example I got last evening - I was sipping bourbon and this landed on my phone -
Yesterday 6:05 PM
Garage Journal Study
One useful new Highland detail from the actual architectural set: the garage slab is explicitly shown as a
4-inch concrete slab-on-grade, and the drawings tell us to defer to the structural set for the slab itself and to the A1 sheets for control-joint locations.
That sharpens something we've discussed about installing the BendPak 10APX. I would
not assume the general 4-inch garage slab is the lift anchoring section. Before anyone drills the two-post anchors, we need the structural slab plan/as-built pour information showing whether the lift locations received thickened pads, their dimensions/reinforcement, and the radiant PEX routing. The architectural drawing alone isn't enough to authorize drilling. That's especially important because the same project documentation confirms under-slab systems are present.
So the interesting part above is that he does not know I specified heavier pours for lift locations - its just somthing my builder knew and was not in the plans - and the PEX is also designed around those lcoatoins - so for this to work I have to update him and tell him the details - he learns and then makes suggestions off that updated data. If you don't do that - its not a useful tool.
And then the oil switch debacle for the Disco -
I also found a useful baseline for future Disco oil-pressure troubleshooting in the factory D2 manual we have indexed. For the V8, Land Rover specifies
minimum hot idle pressure of 0.7 bar/10 psi and 3.4 bar/50 psi at 2,000 rpm, while the low-pressure warning switch opens at only
0.24â0.41 bar (3.5â6 psi). That means the dash oil light is an extremely low thresholdânot a meaningful oil-pressure gauge. Given the recent leaking pressure-switch replacement and the engine's mileage, if we ever see flickering at hot idle, I want a
mechanical gauge measurement before drawing conclusions about viscosity, bearings or the oil pump.
Ubiquiti stuff for the house -
The technology package also confirms another design philosophy that should stay in the project record: Highland's network/security system was deliberately specified around
future expansion, minimal subscriptions and a clean/serviceable utility-room rack, rather than merely buying enough hardware for today's devices. So when we finalize the UDM Pro Max, switch, UPS and camera storage, spare ports/rack space aren't wasteâthey're part of the original design requirement.
No new Highboy or Defender finding today changes our current criteria. The most actionable addition is
do not drill the Highland two-post lift anchors based on the architectural 4-inch slab callout; verify the structural thickening/rebar/PEX plan first.
Anyway - interesting stuff -
Back to the oil pressure nightmare...its just the access. You need a deep 24mm but the waterpump and oil filter hosing and oil cooler lines prevent using anything close to that.
Patient prep -
Its a mess under there -
Removed splash shields and oil filter -
Other part was just unclipping the dumb switch - not really enough access to push in the release so I just popped the clip - which flew to parts unknown - added 30 minutes for search and rescue.
The other size is 15/16 is a little larger but more tool options. There are no mid size sockets (at least at the big box stores) you either get tall or short - short no way works. I cursed my buddy since both of my 15/16 sockets in my tool box had been "consumed" by wheel locks.
He came over in a panic one day as he was at the local Costco getting tires. They stripped 2 of his 4 wheel locks and they did not have the tools to remove (I know right?) They said it was a risk and take it to a shop - then come back and get your tires. But they stripped them?? "Anyway he is like dude in a jam can you help?"
Of course bring the Tahoe over and we will work it out - I have removed dozens of these. Easiest thing is jam on a slightly smaller socket with a sledge and get out the impact driver and warp speed ahead.
I have no vise big enough to free these up - they will require serious holding power and serious beating power to unlock and only come out the top. The wheel lock has been "blended" with the socket. So I tucked these away for Idaho - big table, vise etc thinking there is no way I will need a 15/16 until then. Wrong.
Off to the store for "for a mid sized socket" which will not end up working anyway.
Came home with this:
The wratchet end is clutch - I thought I could heat it up, bend it up worst case. I was able to burn my arm on the block and break if free so bending the wrench was unnecessary. Pretty bad burn - pull out the break fix box for bandages. "why is there blood everywhere"....
Anyway its out -
New and old.
Issue is that shoulder washer on the new one - factory manual says you need the crush washer as new but that washer will not sit flush with the shoulder washer on the new one. This is where Atlas shines - and he gets it - I take these same pics and go "wtf Atlas?"
Immediately he is like - that won't work - stop. Let me research - so he does and figures the switch is a VDO - blah blah blah.
Even though the factory manual from Land Rover says you need the additional washer he says "its wrong" I am ready to snip the shoulder washer off of the switch - no he says, "chill"
He finds some obscure dude in the UK with the same question on a board somewhere - "dont use the extra washer - that shoulder one will crush"
This is not right -
So I take his advice - clean up the connector.
Find my spring clip - all good
I used a paint pen to index the orientation since the switch can go backworks with the blank space
Back on -
With oil change - miles and date
So far so good - I have been driving and letting the kid drive it back and forth to work for some cycling but I left the splash off for now to be sure.
On to the next project -
