Has anyone purchased Bolt Byter from Gear wrench?
Kenskip1
Missouri
From time to time I have run across stripped bolts nuts and had a hard time removing this fastener. I was watching the other "Eric" and this was impressive. Anyway has anyone bought and used on of there products? How satisfied are you with them, Thanks Ken
Fly YX
I was thinking about getting a bigger set I was looking at gr. But I went with Rocket Socket. My billing address is in fl and my shipping is in wi. My account is set up like that on there website but they shipped to my billing address. I called them and they see it should have shipped to the shipping address but it did not. She wanted me to email her also about it because she was working from home. I did that but have not gotten a response back. It has been over a week. I was going to get the 1/4 set if the 3/8 set worked out but there customer service *****. Looks like a great product from the reviews but bad Cs. The old set I have is a USA Irwin and they work great they are just getting old and would like another set.
captain14
Here’s a link to the current thread in Hot Deals. Someone should have some thoughts after using their new set.
javyLSU
New Haven, CT
That was my thread over in the "hot deals" forum. I bought and used the 8pc set that's included in the pack (albeit only once so far). Worked flawlessly getting a rounded 12mm bolt off:
321a0254-e1f8-44ec-8133-9c454e1a530b-jpeg.1633338
Buckgnarly
VT
We have the at school, have been pretty good so far. I have A TON of removers at home, they are not as good as the RBRT stuff but as good as the standard twist/turbo sockets. They do work for reinstalling too, which can be a handy feature.
toddmorr
Prescott, Arizona
Have used them a couple times and they worked really well, so much that I bought a handful of singles to make a set of sorts.
Am also a fan of the proto rbrt hex version, used that on a loctited jeep bleed screw, tore that sucker up but got it off ok.
BarrelRoll
Alaska
I looked at the gear wrench stuff back in January though decided to go with made in USA turbo sockets instead. I have used them a couple times on bolts rusted to odd sizes and am impressed. I picked them up from tools ID and the 13 piece 3/8" drive set is cheaper than the 15 piece 1/4" and 3/8" gear wrench set. I don't often deal with small bolts so the 1/4" drive sizes weren't really a concern though you could buy a couple sockets to add on if that's a concern.
I also picked up a set of Ken Tool extractors that fit in areas you can't get a ratchet in https://www.kentool.com/product/ten-piece-slim-twist-socket-set-with-external-hex/ They are the same as a snapon blue point set for much less. The last time I used them I didn't have enough room to get a bolt biter in the spot and I needed an extractor on both the nut and bolt so having 2 sets was handy.
Hakeem
Chicago
Why do they(GW) provide multiples of the same size? Is it because they are expected to wear out fast?
The sizes with a “-“ after them are slightly smaller, in order to fit a bolt that was rusted or worn down.
I’ve never used these but I’ve heard only good things
Buckgnarly
VT
You reinstall rounded fasteners?
Please stay away from anything I need to work on.
Just did it on my friends 1990's Camry this past weekend, rear caliper bolts. Did not have any in the correct thread pitch and length, but they torqued just fine. The head shape has nothing to do with the bolt integrity, and he did want to drive to work on Monday (the next day).
wafrederick
Holton,Mi
They work well, have had to use them on rear differential cover bolts so badly rusted and corroded rounded off which came out. Had to tap them on with a hammer
nbpt100
Massachusetts
OK. So they provide two different sizes per each nominal size to cover a wider range of nut/bolt damage. Is that correct?
