What's the next step up from a Harbor Freight ultrasonic cleaner?
GuyInGarage
It seems like the bigger harbor freight ultrasonic cleaner gets good reviews, but if I wanted to go up up a step in size and/or quality, what brands or models do people recommend?
I don't want to go crazy. I don't need something huge or expensive.
geneg
Midwest
Vevor. However, it took some time & effort to get a working unit.
Nessism
Torrance, CA
I had a Vevor unit, which is basically the same as the Harbor Freight, and a multitude of others. Mine broke: a board burnt out and one of the transducers fell off. I fixed it, but it never cleaned all that well. Replaced it with a Branson, purchased used off eBay, and it's been great. Take your time and find a low-hours used unit. It's more money, but totally worth it.
vpd66
Central Wisconsin
I ended up buying a used one off marketplace. It was used for cleaning tattoo gun parts. Just a common avenue to keep your eyes open for.
Rinspeed
NY
I would suggest buying a used industrial unit made by Crest, Branson Blackstone or L&R. For around $500 you should be able to get a tank around 5 gallons that will easily last a lifetime, new they run around $3,500.
Davefr
OR
Elma is another brand that is common for higher end products.
Elma's are excellent units (made in Germany) but be prepared for a hefty price premium over the no name Chinese units. You'll get features like frequency shift, sweep and heaters that bring the tank temp up very quickly.
wafrederick
Holton,Mi
I have a 6L Vevor that has been trouble free here. It does get cleaned out after use, the tank after use with using distilled water cleaning the tank. Also upgraded the plastic fitting that screws into the drain with a brass and a better drain hose from the hardware store. The drain hose it comes with is too thin and kinks easily. I use Pinesol in it for cleaning aluminum since it does not hurt it
