Looking for 2 post lift recommendations
ixlr8
Eastern Shore Virginia
Hi folks, I am looking for 2 post lift recommendations, and education. I know NOTHING about 2 post lifts, I see talk of symmetric, asymmetric, supersymmetric, 2 piece, 3 piece and solid arms, I have no idea which is which and what advantages each offer. I will be lifting everything from a golf cart, a sidebyside to my 3/4 ton truck. The slab is 5" thick of 3000psi concrete. It might get used 8 times a year so I don't need anything super heavy duty, but I don't want junk. I'm 6'2' and I want to walk underneath it without banging my head. I have 15' of clearance from the floor to my high lift door. Floor is slightly tapered due to local code requirements so water will drain out the door. I am guessing I will need to shim the posts so they are perfectly vertical. Would prefer it to be a certified lift. Any guidance, or links, that would help me will be appreciated. Thank you
jack stand
Lakes Region Maine
I found a nice used (at a dealership) Rotary brand 10k 2 post lift. For $1000! A fantastic deal.
It had the original selling companies stickers on it with some annual inspection stickers.
I have radiant heat in my floors and between this and no paperwork or familiarity with this lift I called them about installation. They quoted me $400 and I didn't hesitate for a second!
Although I didn't buy my lift from them, they might be worth a call about finding either a new or used lift. They're in the Portland ME area and seem to be a source for general commercial shops with the lifts and oil distribution, probably parts cleaners etc.
From my little dealing with them I can't say enough good things.
They had the few necessary miscellaneous on their truck and did some lubricating along with the assembly and installation for the $400 that they quoted. 2 man crew.
Ever since I got this phone I haven't been able to load pictures here. Other sites are fine. (I took a picture of they're stickers and info for you.)
They're name is AGT (automotive garage tools) and their # is 207 878 8811
Just internet your lift questions to help your shopping knowledge. 👍
mikedodge
Mine is Bend Pak.
While you are waiting for replies you might want to have a look through the various lift posts here and see what makes people say to avoid because a lot of the different makes are used by members here and they're either happy with what they have or you'll see remarks about what they don't like or if they weren't happy with the vendor etc. You'll also get an idea of the common brands that people have been buying.
ToolFanGeoff
So Cal
You shared that you are 6 foot 2 and want clearance to not hit your head when walking under. I am 6 foot and my son is 6 foot 4 (17 years old, and still growing). We wanted a taller lift that he could walk under. We ended up getting a Bend Pak 10APX. The 10APX lifts approximately 6 inches(?) higher than standard lifts. It is a-symmetrical and has 3 stage arms. We use it on our side by side, cars, 1/2 ton crew cab trucks, and our 3/4 ton diesel truck. We got the truck frame adapters and extra extensions when we bought. You did not mention it, but we (I) really wanted a clear floor lift to make rolling transmission jacks and other things easier. The 10APX is very sturdy even with the 3/4 ton truck on it.
You shared that you would use it maybe 8 times a year. If you get a good lift that you enjoy using, maybe you will use it more. My son uses our lift a lot more than I imagined. We used our lift to build our 4th of July float this year.
I
ixlr8
Thanks for the replies. I have been searching this forum and online to learn more. I now understand the differences between symmetric, asymetric and supersymmetric. I'm leaning towards a wide symmetric, need to measure space to see if it will fit where I want to put it. I did see a few recommendations for a certain brand in postings and I was getting tempted to go with that brand. Then I read about when service is needed... the company seems to disappear. Much more research needed. I have a Bendpak HD-9M 4 post, I bought it directly from Bendpak dealing with owner Jeff. I have to say Jeff lied to me about a few things and Bendpak is on my S... list, not in a hurry to buy from them again.
AC-WC
NE, Indiana
Have you tried the search bar for Garage Journal? Lots of info has been posted by the group.
I can say Bendpak is the only manufacturer to have documented concrete requirements in writing on the web. I highly recommend comparing these guidelines to your current slab. Most of the manufacturers just tell you X thickness for the weight capability of the lift.
Because of your various vehicles and height requirements the only recommendation I can give is to go with a 9/10k lb lift. I know my C7000 is too short for you.
There's lots of good info from Redline on the web including install, sizes, symetric, assymetric etc.
Bestbuyautoequipment.com is another good source.
Confirm if having a floor plate or open floor style is better. If you plan on transmission work a floor plate will be a hassle with a trans jack.
Do you plan to install yourself or pay someone? Can you pick it up from the dealer? It will save you some shipping costs if you can.
22george
SW Ohio
Extra tall and extra wide are well worth the money if you have the room. It is a lot easier getting in and out of the vehicle with the extra wide lift. A floor plate will be a trip hazard also.
Jetfixr320
Which ever brand or model you decide to purchase. Before you pull the trigger, download and read the installation instructions.
I
ixlr8
I have started doing that. I'm finding 4 post lifts don't need rebar in the slab, but the 2 post lifts do. My slab is 5" thick with 3000psi concrete, the $64K question, is there rebar in the slab? I requested it, it is in the plans, but the concrete guy didn't see the need for it and I wasn't there when the floor was poured. I'm hoping I can figure it out with a metal detector.
firebirdparts
Kingsport, TN
I would very much suggest you get asymmetric. I use a symmetric and I push everything between the posts. I can't open the doors and get out of a car positioned to be lifted.
575cat
I have a Triumph 2 post floor pan style in my fleet I use for my own car,s that thing lift,s higher than my other clear floor BendPack,s , 73 inches under the arms
cpakalolo
You say you want symmetric. Don't limit yourself. You might want a bi-symmetric. I just got an asymmetric Tuxedo 11 k, TP-11 KC-DX and installed it. It is almost 12' wide to the outside of the posts and is just over 12 feet tall. Since you specifically want to have the bottom of your lift arms above 74", you will need an extended height. A little harder to get, but they certainly are out there. Usually, if the vehicle is lifted to your height plus some, it is a bit of a reach getting to things. I am commenting here to give some general info I got that is hard sometimes to get. Most lifts will be right at about 71" lift height. It is because they try to standardize parts like the cylinders. Chain drive over cylinder is solid technology, but new ones are often coming out with direct drive cylinders. They mount the cylinders upside down (which is better for seals) and the cylinder pulls rather than pushing. It's why the rod in the cylinder is half the size. All the good ones only take 230 vac, not 110. Chinese lifts. That's quite a subject. If you don't buy a Challenger or a Mowhawk you are probably looking at something made in china. Beyond that, there are the "Chinesium" lifts--they are the ones that you can get from direct sellers like HK or Katool or maybe ME that only cost about 2 grand. I don't recommend these if you can get something better. I would only get a Chinese lift if it carried an American company name and had real guys in the USA handling everything. I didn't see a justification for an ALI rated lift for my home needs. A lot of guys will do what I did and try to find all this information on the internet which is hard to do actually. You just don't get much information to compare and it is hard to find a showroom with one assembled. There is a place in Indiana, though. There just aren't going to be really good technical service advisors or anyone who will give info on anything. Talk about modifying a lift and all the ALI rated lift guys will just hang up. You might try to "buy up" to a higher weight rating to imitate safety in a heavier design. That's doable too. Other things to consider are the stack adapters and truck adapters you might need. Concrete conditions: Whew! That's a big one. I won't even go there because the subject is too deep. I went with Hilti HIS internally threaded epoxy anchors and it cost me a grand to do. I still think this is the way to go if you don't trust your concrete due to microcracks. They all ship by the same company and that is a funny part. LTL shipping will bring it to your commercial address only. If not, ship it to a terminal where you can pick it up in a trailer. In no way will they let you unstack it and unload it by hand. A really small tractor can't unload them either. They are usually loaded where they have to be picked up from the long end. I thought I had everything set. A business friend with a big forklift would unload it if I was present. Well, the shipper didn't call and my friend wasn't happy that I didn't call ahead, but I got it. I'm sure you have read a lot. I am just trying to describe the unusual way these things are marketed so you don't have to, I guess.
cpakalolo
Some of these lifts are so wide, that opening a two door is easy to do.
Rc_Guy
Minnesota
They can also X-ray concrete
mikedodge
Symmetric ones are usually better for lifting small stuff because of the arm setup but not always.
cpakalolo
I asked every salesman I could get a hold of to ask the question of whether symmetric or asymmetric is better for trucks etc... and I never got the same answer. The best thing someone said is "its all about opening the door" I have an assymetric lift and it seems like I'm going to be lifting everything about a foot from center by where I put it. Everyone drives a truck or small SUV around here, so that's what will be on there.
