Ideas for Outdoor bench and vise setup.
bigredcornhead
Does anyone have a setup outside their shop for a bench and vise? I was thinking if i can get my hands on a scraped expanded metal picnic table top, i can pour some small footings, and either use some metal legs or 4x4 posts. Then add a vise either leg vise or bench top to do all my cutting and grinding outside. Keep some of the filth and grime outside. Any suggestion, ive seen a few people with vises outside might just do that instead of the bench as well.
NUTTSGT
Northern Central Ohio
How about a vise mounted on a piece of tubing that is welded to a steel rim or something similar that can be moved.
Edit: forgot steel rim
lolaetype
North Western Arkansas
All my grinding and most of my cutting metal is done outside. I don't do a lot of it, but I don't want to do it in the garage (too lazy to clean everything). I use a BD Workmate for the bench because it's easy to move around to where I need it and fold it out of the way when I'm done. I've bolted a 4.5" vice to a 12" length of 2X6 that I either clamp onto the workmate or hold in place with a "C" clamp. If I need more table area a have a 2' X 3" piece of 1" thick plywood with a 2" X 3", 2 feet long screwed on center onto the plywood. I can clamp that in the workmate and "C" clamp the vice to it.
Wish the casters were bigger.
Make you a hell of a deal on some new Grizzly 6-inch "all terrain" casters, but shipping would be deadly. Maybe I need to go check out the Wallowas. :unsure:
I found a home-made, rolling metal work cart. My plan is to go over to Earthwise Salvage, have them slice me off a couple pieces of 1-1/2" butcher block, glue them together side-to-side to make a top with an edge around the perimeter which will allow the top to be dropped onto the top of the cart but not slide off, and make a provision for a "quick-on/quick-off" little 4-inch Taiwanese vise I have out in the garage. It would be light enough I could just lift it off or put it on as the situation calls for (as I actually rarely use a vise.)
bigredcornhead
I use this with grinding and dirty ****…I have a nice Vice mounted to a 2” receiver tube that slides into that mount. Works great and gets the vice outa the weather.IMG_5637.jpeg
Now this is what I'm talking about thanks for sharing great idea on the hitch receiver also!
tarmy
Nor Cal
I will try to remember to take a pic of the vice mounted I made and with it installed. You need a big bolt or handle to secure the vice when the BFH comes out…
tool_scrounge
Southern California
Find a vintage cast iron machinery base for cheap. I knew a scrap dealer who found an old overhead pin router cast iron machine base and used that as a nice stand for a vise. Very heavy and he liked the style. The entire top of the machine unbolted and he just added a steel adapter plate for the vise. The fully assembled pin router (image found on the internet) is shown below.
The Metric System
For years at a previous shop I had a ~ 3' x 5' outdoor workbench adjacent to the garage, it was great for exactly the type of dirty work you describe: anything that generates chips/dust/smells/fumes that I didn't want in the building.
A few tips based on what worked well for mine:
  • Build the top out of pressure treated dimensional lumber rather than sheet goods or expanded metal. Something like 2x6s will allow rain to drain through but give you a mostly solid surface that small hardware can rest on safely. If a single piece degrades or is damaged it's easy to replace piecemeal.
  • A cheap no-name knockoff vise will likely work well for the sort of light-duty fixturing you will be doing out here, you don't need something good or fancy. Presumably you have a better vise indoors if you really need to get medieval on a workpiece. The cheap vise I had on mine had some cosmetic rust but otherwise held up fine to the weather; consider all the service trucks you've seen with a vise permanently mounted to the rear bumper exposed to vast amounts of salt and road spray.
  • An air line within easy reach of the bench is handy to blow away those chips and dust you are creating.
  • Get in the habit of checking for wasp nests before you start using the bench. A bunch of stinging insects coming after you when you have your hands full with a grinder is no bueno.
bigredcornhead
As promised…IMG_5776.jpegDang Hip, i want your vise too that is my grail vise, been looking for some time, i will find one eventually!
All great tips need to him my local salvage yard for some expanded metal.
