Beerhippie
Looks like you don't need my alchemical recipes. I've never used that brand, so no opinion about it.
So before I just jumped right into the gas tank kit I went ahead with the lye like you suggested. This is the product I used.Looks like you don't need my alchemical recipes. I've never used that brand, so no opinion about it.
Lye crystals is lye crystals. Red Devil is just the brand I mostly see in stores.The Red Devil was not available. I took 1/3 of this 2lb container and poured it into the tank. Then I added about 2 cups of water and a section of chain. Then I sloshed it around for a while. Boy did that did get HOT!
I mistyped... not that it would be much better... it wasn't 2 cups of water. It was about 2 quarts. Still obviously not enough but as you said, it worked like a champ!Lye crystals is lye crystals. Red Devil is just the brand I mostly see in stores.
Your solution got hot because you used too little water AND ignored the warning about adding the crystals to water and not the other way around--but it did the job! BBs, nuts and bolts, chain, whatever really does help to break up crud and rust. Shaking the tank is an excellent workout!
I'm three weeks in, it takes a bit to get your routine figured out. I'm still working on it. But it is good.it's gonna be rough for a while.
i think after i sell off nearly all my "working" tools i'll feel a little better
i just have to "be OK" with not having a job anymore.
i do have a "hobby" i'm a competitive shooter i have my guns and a small stockpile of ammo i just have to pick and choose when/where to shoot
But once again, the warning to "do what you oughter, add lye to water" seems to be what you missed. The difference is, adding the lye crystals to water dilutes them immediately--and water can soak up a hell of a lot of the heat that is released by lye dissolving in water. Adding water to lye leaves you with too little water to dilute or diffuse the heat fast enough. You're lucky it just got hot--often, the water flashes to boiling, resulting in a lye volcano. Lye eats flesh--did I mention that? Lye in the face *****.I mistyped... not that it would be much better... it wasn't 2 cups of water. It was about 2 quarts. Still obviously not enough but as you said, it worked like a champ!
Clutch looked to be in decent shape which scares me, they had said the clutch was slipping.
A routine is important. Wake up, drink coffee. Eat. Be retired and do retired guy things. Sleep. Repeat.I'm three weeks in, it takes a bit to get your routine figured out. I'm still working on it. But it is good.
If you put handlebars on that thing, at least you can pretend you're riding the Bergman Kay!Had plans. Rode the chair instead.
Ok. I read the directions and they said to do it that way... but that was for a drain not a gas tank. Got lucky I guess X3!Lye crystals is lye crystals. Red Devil is just the brand I mostly see in stores.
Your solution got hot because you used too little water AND ignored the warning about adding the crystals to water and not the other way around--but it did the job! BBs, nuts and bolts, chain, whatever, really does help to break up crud and rust. Shaking the tank is an excellent workout!
You accomplished a lot in 1 year.
I thought I was slow..You accomplished a lot in 1 year.
Nice work!
ASA works really well to resist heat and UV rays if you decide to 3D print a replacement.
So I need to buy a 3D printer to fix my window switch? Build an addition to the shop to have somewhere to put it?
Oh, yeah--this is Garage Journal.![]()
Come to think of it, there's probably someone at The Samba who prints these. It's a common problem with our 35+ year-old Vanagons. But my no-dollar fix seems to work just fine--until the rest of the bezel crumbles.
Just doing my due diligence and spending other people's money, as is tradition here
But really I bet you could get someone to print it free for you if you modeled it up.
Think my ASA was $19 for 1kg, and that small panel looks like it'd take between 50g to 150g.
I've mentioned this before but..... Check with your local library. Ours offers 3D printing as a freebie. 1 object every 2 weeks. 6 hour max print time per object. You send them an STL or a link to one.
Yes, Timm, I know you're in the middle of nowhere. Just throwing it out there. If not helpful to you, maybe someone else will benefit.
I haven't encountered asbestos in a cooler, but I guess it's possible.it old enough it is possible its asbestos.
